Build headphones? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 11-13-2012, 01:29 AM - Thread Starter
therock003's Avatar
I dont know if this is right category but since i saw the DIY label and i need to make some earphones some certain way i need to ask guys for your advice.
I need earphones for 3.5 jack to connect to mobile. But since they will go under my helmet while i'm on my motorbike, in case i need to briefly answer a call, i need the following,
Bracket that holds the earphone around my ear.
Coiled wire
Embedded tiny mic
So how can i fuse all those pieces together and create something compatible with any mobile phone with 3.5 jack?
therock003 is offline
post #2 of 2 Old 11-13-2012, 12:25 PM
Looneybomber's Avatar
Liked: 27
If a product like that exists (I don't play music with my phone) just use that. It'll have ear buds and a mic then the phone will switch from music to the call. Sew the mic part into the front portion of the cushioning by your mouth, and be disappointed that the people on the other side only hear wind and engine noises. When I ride I wear ear plugs because it's so loud. I couldn't imagine trying to have a conversation with someone too.
YID DIY
Looneybomber is offline
