DIY Bookshelf with Integrated Subwoofer - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 11-13-2012, 07:12 AM - Thread Starter
Ruben Z's Avatar
I'm in desperate need of a new Subwoofer, but the WAF is high at this point after purchasing some huge floor standing speakers. The wife is pissed because my new speakers are preventing her from putting a small bookshelf in the Family room. So I got to thinking. What if I made something like THIS with a subwoofer on the bottom where drawer is? It would be probably a 12" driver and something for like 2600 cubic feet. I just don't know if the sub would nock things off the shelf. It mostly wouldn't be anything breakable on it.
Ruben Z is offline
post #2 of 4 Old 11-15-2012, 11:47 AM
SilentJ20's Avatar
Quoted: 29 Post(s)
Liked: 26
As long as you can get the internal volume for the sub close enough, it should be fine. The only issue will be possibly limiting location possibilities. If the box portion is braced well and the shelf is heavy enough, I don't think it will vibrate much at all.
SilentJ20 is offline
post #3 of 4 Old 11-15-2012, 11:59 AM
LTD02's Avatar
Quoted: 2344 Post(s)
Liked: 2583
have you considered just mounting some shelves to the wall above your speakers for your wife?
Listen. It's All Good.
LTD02 is offline
post #4 of 4 Old 11-15-2012, 12:03 PM
ShaQBlogs's Avatar
Quoted: 27 Post(s)
while you are at it. Consider building two subs if possible. Since that is a decent size room, you would probably want even bass throughout the room, unless you are seated at the same place.
ShaQBlogs is offline
