Low sheen black paint for subs ( professional looking ) - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 11-14-2012, 06:17 PM - Thread Starter
randyc1's Avatar
Quoted: 238 Post(s)
Liked: 40
What paint would be good to achieve a (professional looking) Low Sheen black finish on my mdf subs ??
randyc1 is offline
post #2 of 6 Old 11-14-2012, 06:37 PM
Scott C.'s Avatar
I know a couple of people have used Rustoleum flat black and had success. Not the rattle can, though.
Sounds Good to Me... keeping track of my audio projects.
Scott C. is offline
post #3 of 6 Old 11-14-2012, 08:55 PM
tgse3's Avatar
What kind of performance characteristics are you looking for?
How do you plan to apply it (brush, roller, spray, etc)?
How much use will the coating get (is it an end table, or sub in dedicated theater, etc)?
When you say low sheen do you want it to be as flat as possible or can some sheen(eg-shel/satin) be tolerable?
I feel like I just responded to someone who just said "I have $2000 what can I buy with this?" Sorry in advance for nerding out on paint biggrin.gif
tgse3 is offline
post #4 of 6 Old 11-15-2012, 04:57 PM - Thread Starter
randyc1's Avatar
Quoted: 238 Post(s)
Liked: 40
Dedicated HT Subs ,
Yes I can rent a sprayer ,
Low sheen not completely flat
randyc1 is offline
post #5 of 6 Old 11-19-2012, 05:26 PM
LTD02's Avatar
Quoted: 2341 Post(s)
Liked: 2577
http://www.avsforum.com/t/1334710/3-4pis-are-being-imagined-in-my-head/60
scroll down...
yes, no?
Listen. It's All Good.
LTD02 is offline
post #6 of 6 Old 11-19-2012, 08:03 PM - Thread Starter
randyc1's Avatar
Quoted: 238 Post(s)
Liked: 40
scroll down...
Are you reffering to the black baffles ?? if yes ,i think i would like just a tad more sheen to the black.
randyc1 is offline
