Are Mael-X's still good or will they crap out eventually? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 18 Old 11-16-2012, 08:49 PM - Thread Starter
stgdz's Avatar
Been awhile, been flying RC planes a lot.
Are the mael-X's still good or will they crap out due to the glue issue? I know the glue issue came up at the end of the run, wasn't certain if it was found to be in all runs.
Also since its been a couple of years have I missed any new stuff?
stgdz is offline
post #2 of 18 Old 11-16-2012, 09:20 PM
noah katz's Avatar
Quoted: 1032 Post(s)
Liked: 365
AFAIK the glue issue was only with the last batch of 21"
Noah
noah katz is offline
post #3 of 18 Old 11-16-2012, 10:24 PM
Mrkazador's Avatar
Quoted: 262 Post(s)
Liked: 390
The biggest thing that happened this year is the Seos waveguide.
Mrkazador is offline
post #4 of 18 Old 11-17-2012, 10:30 AM
mjaudio's Avatar
Quoted: 39 Post(s)
Liked: 76
The glue issue would rear it's ugly head quickly so if you get past a month and no problem then the Mael-X should last a long time. It was the later series of 18's and 21's that had an issue with the epoxy not being fully cured but if you have the first gen Mael-X then those are fine.
Like MrK already stated the SEOS is the big news around here along with flat packs and full kits from Erich at http://www.diysoundgroup.com/
mjaudio is offline
post #5 of 18 Old 11-17-2012, 04:12 PM
BassThatHz's Avatar
Quoted: 2317 Post(s)
Liked: 2065
NotNyt bought 8 and I bought 2. All 10 crapped out eventually, I repaired mine (and they are still working to this day) and he threw his in the garbage.
So that's "at least" 10 known failures. I'm not sure what is less reliable those, or clone amps. eek.gif
BassThatHz is offline
post #6 of 18 Old 11-17-2012, 04:22 PM
mjaudio's Avatar
Quoted: 39 Post(s)
Liked: 76
How did you repair your Mael-X?
I still have 2 18's and a single 21 and have never had any problems. Come to think of it I don't recall anybody reporting a failure on the Vegas subs thread, only my 21" is a Vegas sub.
mjaudio is offline
post #7 of 18 Old 11-17-2012, 04:34 PM
N8DOGG's Avatar
Quoted: 1104 Post(s)
Liked: 1201
The glue issue was with the 18's and 21's. That whole ordeal sent Kevin out of business.
N8DOGG is offline
post #8 of 18 Old 11-17-2012, 05:20 PM
BassThatHz's Avatar
Liked: 2065
It was purely electromagnetic inductance that was causing the metal clacking noises, there was nothing physically wrong with the moving parts and could have played on forever without issue, but it sounded like poo doing so.
At first it started around 120hz and then eventually the resonance grew worse until it was all the way down to 16hz, that the clacking was occurring at. At which point I had gone completely insane trying to apply a crossover work-around to push the noise out-of-band.
So I ripped the thing apart and added more glue. It was a PITA that required hair-like-precision; it took 3 hours of painstaking surgery per sub. It was either do that... or throw them in the dump! A recone kit would have made the job easier (but would have done nothing to fix the root cause, I might add), but I wanted to do it for free, so...
post #9 of 18 Old 11-17-2012, 06:45 PM
LTD02's Avatar
Quoted: 2498 Post(s)
Liked: 2830
"It was purely electromagnetic inductance that was causing the metal clacking noises..."
what???
Listen. It's All Good.
LTD02 is offline
post #10 of 18 Old 11-17-2012, 07:54 PM
mtg90's Avatar
Quoted: 469 Post(s)
Liked: 923
what???
The voice coil was inducing a magnetic field into the loose shorting ring causing it to vibrate.
mtg90 is offline
post #11 of 18 Old 11-17-2012, 08:20 PM
LTD02's Avatar
Liked: 2830
ah, ok. inductance and back emf have their problems, but clanking sounds would not be one of them.
LTD02 is offline
post #12 of 18 Old 11-19-2012, 11:04 AM
Kevin Haskins's Avatar
It was a shorting ring that once loose... was just floating around and rattling with any vibration. There was no way to filter the sub in order to avoid the rattle once the glue failed.
I never did get a count on how many of the Vegas subs failed. Many people sent me thank you emails who are still using them today so there were a respectable number of people who lucked-out.
Kevin Haskins
Exodus Audio
Kevin Haskins is offline
post #13 of 18 Old 11-25-2012, 01:05 PM - Thread Starter
stgdz's Avatar
thanks guys, did anyone ever measure the inukes to see if they cut out below 20hz
stgdz is offline
post #14 of 18 Old 11-25-2012, 01:12 PM
Thatsnasty's Avatar
Quoted: 51 Post(s)
Liked: 44
AFAIK they are flat to 10hz-ish.... similar to the EP amps (so ive read)
Are you sure you're not talking about the DSP?
The DSP is unusable under 20hz meaning you can't boost or cut with it that low, like you can with the miniDSP.
I own the NU3000DSP and its a great amp but unless they firmware update I'll probably buy the mini to EQ.
Thatsnasty is offline
post #15 of 18 Old 11-25-2012, 07:23 PM - Thread Starter
stgdz's Avatar
yeah thats kinda what I'm looking for. The 5050 gets down to 5 but I will probably need another one down the road.
stgdz is offline
post #16 of 18 Old 11-25-2012, 08:14 PM
mjaudio's Avatar
Quoted: 39 Post(s)
Liked: 76
Is the DSP in the iNuke similar to the DCX2496? I know my DCX2496 has a 12dB/octave shelving filter which is also limited to 20hz but it raises the level of the frequency band below the adjusted frequency so a shelf filter at 20hz raises the level below that so you are getting boost below 20hz.
mjaudio is offline
post #17 of 18 Old 11-25-2012, 08:42 PM
LTD02's Avatar
Liked: 2830
yeah, technically the corners are limited to 20hz, but you can get lower than that by monkeying around with the various filters. i forget offhand, but using a highshelf with a negative gain provides something close to a 10hz filter low shelf with positive gain. don't quote me on that though. the software is downloadable if you wish to see what it can do.
LTD02 is offline
post #18 of 18 Old 11-25-2012, 09:09 PM
MKtheater's Avatar
Quoted: 1717 Post(s)
Liked: 1251
Yes you can do that with the DCX 2496. You can't make the rolloff lower in frequency but you can raise the bottom so it can be flatter lower but it does create a hump in the teens.
Marantz 7702 Atmos
Outlaw 7140 and 5000
Speakers- DIY mini arrays for fronts and BFM TLAH for surrounds
subs 2 XXX ported SLLT powered by IPR2-7500.
MKtheater is offline
