DIY SEOS for HT upgrade - Page 7 - AVS Forum | Home Theater Discussions And Reviews
post #181 of 238 Old 03-14-2013, 06:01 PM
antisuck's Avatar
Quoted: 112 Post(s)
Liked: 159
Originally Posted by Erich H View Post
There's a MTM center channel coming with dual 8" Eminence Betas. It uses the same compression driver as the Fusion-8 and Fusion-10 Pure.
Awesome, never thought it would work off-axis to be honest - I've been trying to figure out how to make something along the lines of bwaslo's "Daniel" fit in my living room.
Is there a development thread somewhere?
antisuck is offline
post #182 of 238 Old 03-14-2013, 06:28 PM
brian6751's Avatar
Quoted: 1083 Post(s)
Liked: 1077
i would rather make a Big Mal actually
That's not science! - Cyborg
Steam ID: The Barbeerian
Rivers Edge Theater
brian6751 is offline
post #183 of 238 Old 03-14-2013, 06:42 PM
tuxedocivic's Avatar
Quoted: 2139 Post(s)
Liked: 1996
If Erich ever gets me the parts wink.gif I'm working on a 100db 3 way that's 12" tall and 40" wide and configurable for L&R biggrin.gif If it all works out it should be insane!
My youtube channel: Impulse Audio
tuxedocivic is offline
post #184 of 238 Old 03-14-2013, 06:55 PM
Sibuna's Avatar
Quoted: 377 Post(s)
Liked: 432
great googlie mooglie
Sibuna is offline
post #185 of 238 Old 03-14-2013, 07:31 PM
brian6751's Avatar
Liked: 1077
ok. now you have my attention!!!!!
Rivers Edge Theater
post #186 of 238 Old 03-15-2013, 04:55 PM
maxmercy's Avatar
Quoted: 63 Post(s)
Liked: 168
Terrific option for those w/o AT screens that would be...
JSS
maxmercy is offline
post #187 of 238 Old 03-18-2013, 09:58 AM - Thread Starter
cuzed2's Avatar
Quoted: 200 Post(s)
Liked: 255
Actually resumed my delta-light project this weekend.
Got the stands duratexed and assembled
Mounted the speakers to the stands, pre-drilled holes for drivers, and duratexed
Tinkered around with crossover layout (which I hope to solder up tonight)
Cuzed2
CuznEddy Cinema
cuzed2 is offline
post #188 of 238 Old 03-18-2013, 10:33 AM
Sibuna's Avatar
Quoted: 377 Post(s)
Liked: 432
lookin good
When you attached the floor drain to the wood for the stands did you sink it in to account for the lip on it or did you just flush screw it on there?
Sibuna is offline
post #189 of 238 Old 03-18-2013, 11:41 AM - Thread Starter
cuzed2's Avatar
Quoted: 200 Post(s)
Liked: 255
Originally Posted by Sibuna View Post
lookin good
Thanks Sibuna!
They were mounted flush (screwed and glued)
Cuzed2
CuznEddy Cinema
cuzed2 is offline
post #190 of 238 Old 03-18-2013, 12:03 PM
Mrkazador's Avatar
Quoted: 262 Post(s)
Liked: 390
Two coils on the top right, the one standing should be rotated 90 degrees.
Mrkazador is offline
post #191 of 238 Old 03-18-2013, 01:05 PM - Thread Starter
cuzed2's Avatar
Quoted: 200 Post(s)
Liked: 255
Thanks - good point!
I'm also going to increase the distance between them
Cuzed2
CuznEddy Cinema
cuzed2 is offline
post #192 of 238 Old 03-19-2013, 12:02 PM - Thread Starter
cuzed2's Avatar
Quoted: 200 Post(s)
Liked: 255
First XO finished, not the prettiest, however....
(2nd one should be prettier)
Cuzed2
CuznEddy Cinema
cuzed2 is offline
post #193 of 238 Old 03-19-2013, 01:52 PM
Mrkazador's Avatar
Quoted: 262 Post(s)
Liked: 390
I don't like how close the two coils in the center are.
post #194 of 238 Old 03-19-2013, 08:38 PM - Thread Starter
cuzed2's Avatar
Quoted: 200 Post(s)
Liked: 255
That graphic is most helpful! Will be moving that center coil to the bottom edge of the board tomorrow night
Cuzed2
CuznEddy Cinema
cuzed2 is offline
post #195 of 238 Old 03-20-2013, 09:52 AM
drewmc's Avatar
Cused,
It looks a little crowded at the bottom of the board. Maybe you could do like this.
drewmc is offline
post #196 of 238 Old 03-20-2013, 11:23 AM - Thread Starter
cuzed2's Avatar
Quoted: 200 Post(s)
Liked: 255
drewmc,
Thanks - good suggestion!
If I can't find the room on the "bottom", your suggestion will be employed smile.gif
Cuzed2
CuznEddy Cinema
cuzed2 is offline
post #197 of 238 Old 03-21-2013, 09:38 AM - Thread Starter
cuzed2's Avatar
Quoted: 200 Post(s)
Liked: 255
Originally Posted by drewmc View Post
Cused,
OK reconfigured the board by moving that coil to the lower righthand corner (bottom left on this photo)
drewmc/mrkazador - Thanks for the suggestions!
Next two shots are self-explanatory, used Velcro to mount the XO boards (and a connector for easy removal)
Ready to mount drivers and a listening test
Cuzed2
CuznEddy Cinema
cuzed2 is offline
post #198 of 238 Old 03-21-2013, 09:39 AM - Thread Starter
cuzed2's Avatar
Quoted: 200 Post(s)
Liked: 255
Sorry about the disoriented photos - the image rotate function went bezerk on my photo-bucket account
Cuzed2
CuznEddy Cinema
cuzed2 is offline
post #199 of 238 Old 03-21-2013, 09:51 AM
cheezit73's Avatar
Liked: 24
cheezit73 is offline
post #200 of 238 Old 03-23-2013, 01:22 PM - Thread Starter
cuzed2's Avatar
Quoted: 200 Post(s)
Liked: 255
With the exception of the custom logos; the Deltalights are finished. Moving them into the theater now.
Photos and listening first-impressions tomorrow!
Cuzed2
CuznEddy Cinema
cuzed2 is offline
post #201 of 238 Old 03-24-2013, 05:59 PM - Thread Starter
cuzed2's Avatar
Quoted: 200 Post(s)
Liked: 255
OK with the exception of logo emblems in the lower corners, and some REW comparison measurements; I am done !!! smile.gif
Over the last 2 days; watched one movie, and 2 hours of listening to some hi-rez 5.1 music;
I am very happy - Thank You to all the SEOS gang, especially Erich, Bwaslo, drewmc, and numerous others!
Listening comparison is against my Klipsch RF35s (one is resting in the front right corner, for future measurement comparisons). The most obvious difference (verified by my 18year old with better ears), is that the sweet spot now spans across all 4 seats, previous "sweet spot" with the Klipsch 35s was the middle two seats. I currently have them toed-in by 40 degrees. Also when listening to instrumentals and percussion; I am pretty sure I am hearing much more detail. Mid range seems punchier. Other observations; the stands are a love it hate it proposition. My wife dislikes them - but hey it's a man-cave smile.gifsmile.gif
Cuzed2
CuznEddy Cinema
cuzed2 is offline
post #202 of 238 Old 03-25-2013, 02:21 PM
RTROSE's Avatar
Quoted: 195 Post(s)
Liked: 169
Sweet, I like the stands, but here again I'm not your wife! Glad the project turned out well for you, they are very nice looking speakers.
Here (or is it hear) is wishing you good listening, and many hours of enjoyment.
RTROSE
RTROSE is offline
post #203 of 238 Old 03-28-2013, 11:12 AM
drewmc's Avatar
Cuzed,
I have to say I do like the stands, but I think the base plates may look better with a faux travertine marble or similar finish. It would blend in better with the carpet than the black.
drewmc is offline
post #204 of 238 Old 03-28-2013, 11:43 AM - Thread Starter
cuzed2's Avatar
Quoted: 200 Post(s)
Liked: 255
Drewmc,
Good point, I think those bases are what my wife likes the least!
Hmm - may have to look into some kind of "stone-looking" finish
Cuzed2
CuznEddy Cinema
cuzed2 is offline
post #205 of 238 Old 03-29-2013, 02:04 PM
farkem's Avatar
Nice Job!
Have you tried running them full range, without the sub? Curious as to how the bottom end is on the sealed boxes.
farkem is offline
post #206 of 238 Old 03-29-2013, 03:44 PM
bass addict's Avatar
Quoted: 366 Post(s)
Liked: 442
Originally Posted by farkem View Post
Nice Job!
Achievement Unlocked
Psychotic Episode Averted
bass addict is online now
post #207 of 238 Old 03-29-2013, 07:16 PM - Thread Starter
cuzed2's Avatar
Quoted: 200 Post(s)
Liked: 255
I hope to make some REW measurements soon. However; I believe they will start rolling-off at 70hz
Cuzed2
CuznEddy Cinema
cuzed2 is offline
post #208 of 238 Old 03-29-2013, 07:22 PM
LTD02's Avatar
Quoted: 2462 Post(s)
Liked: 2783
mr. k., nice diagram for inductor placement. erich should include that somewhere on the seos kit building tips page. wait, is there such a page? :-)
Listen. It's All Good.
LTD02 is offline
post #209 of 238 Old 03-29-2013, 07:27 PM
Mrkazador's Avatar
Quoted: 262 Post(s)
Liked: 390
That would be a good idea, to have a building tips page. There is a FAQ page but its empty.
post #210 of 238 Old 04-03-2013, 11:05 AM - Thread Starter
cuzed2's Avatar
Quoted: 200 Post(s)
Liked: 255
As promised I finally got reacquainted with REW, after an 18mo hiatus. I say this; to ask for your REW forgiveness in advance smile.gif
Also; does anyone know of a slick way to post REW graphs; instead of my "screen-shot/cut/paste" technique? The following graphs were made indoors. Unfortunately; most of the nulls and peaks between 175 Hz and 1.7Khz are known room issues (the exact source and remedies is an on-going project). All measurements were made with my AVR bypassed, my sound card output was driving the test speaker directly thru my MM900 amplifier. In other words: no Audysey controls, no crossover, no sub-woofers, no processing. Measurements also made with the mic. about 30" directly in front and at the midpoint of the baffle face. Also used 1/6 smoothing.
The first comparison is Big Mal (in blue) under the screen against the front wall.
As compared to a Klipsch RC7 that is buried in mineral wool in an overhead soffit.
The 2nd comparison is a Deltalight 2512/SEOS12-360 (in red)
As compared to a Klipsch RF35.
Both of these were made with the speakers about 2' forward of the front corners of my theater.
Cuzed2
CuznEddy Cinema
cuzed2 is offline
