DIY Rti12's - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 11-23-2012, 07:52 AM - Thread Starter
zwc0442's Avatar
Has anyone done this kit before?
http://www.mavin.com/store.php/products/3-way-kit-mavin-emi12-kit-using-rti12-major-components
Seems like a really good price since it looks like it uses actual polk drivers. The price of a pair of Rti12's from polk's ebay store is $750 so it would be a lot cheaper to go this route.
zwc0442 is offline
post #2 of 7 Old 11-23-2012, 09:19 AM
Face2's Avatar
Quoted: 346 Post(s)
Liked: 208
It uses a generic crossover, stay away.
Face2 is offline
post #3 of 7 Old 11-23-2012, 09:43 AM
Mark Henninger
imagic's Avatar
Quoted: 6478 Post(s)
Liked: 11223
"Actual Polk Drivers' = junk. OK that's harsh, but 'Polk' as a brand is no guarantor of quality, on the contrary much of their product line is aimed squarely at the entry-level. I also know - from personal experience - they are not above exaggerating their specs and describing bottom-of-the-line engineering as 'state-of-the-art'. Not the only company guilty of that, of course.
Mark Henninger, Senior Editor at AVS Forum
imagic is offline
post #4 of 7 Old 11-23-2012, 09:51 AM - Thread Starter
zwc0442's Avatar
Is the Rti line that bad? I've owned the monitor series and they were great for what I use. Just movies and gaming not too much music.
zwc0442 is offline
post #5 of 7 Old 11-23-2012, 10:02 AM
LTD02's Avatar
Quoted: 2525 Post(s)
Liked: 2867
face2 caught the problem.
"This is my finest kit to date..."
"Cerwin Vega Bi-Ampable three way crossover, 12 db design, with heavy duty gold plated binding posts."
there are no measurements. who knows what kind of wild west frequency response you are likely to get with this combination. the guy selling the kits seems like a joker.
Listen. It's All Good.
LTD02 is online now
post #6 of 7 Old 11-23-2012, 10:26 AM - Thread Starter
zwc0442's Avatar
So if i just bought the drivers from them and got a set of crossovers from polk would be the best route to take if were to build a set of these.
zwc0442 is offline
post #7 of 7 Old 11-23-2012, 11:43 AM
LTD02's Avatar
Liked: 2867
if that is what you want and use the same drivers with the same crossover for the exact model of speaker that you are building and build a similar cabinet, then you will get similar results.
otherwise, who knows what you will get.
LTD02 is online now
Polk Audio Speakers Rti 12
