Where to get 1" MDF - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 11-24-2012, 02:23 PM - Thread Starter
TenTonBass's Avatar
Quoted: 16 Post(s)
None of my local suppliers carry it, only 3/4".
Thinking of just doing 3/4" all around and gluing and screwing two pieces together for a 1 1/2" front baffle.
This will be housing a 33 lb 15" driver.
TenTonBass is offline
post #2 of 6 Old 11-24-2012, 02:55 PM
bass addict's Avatar
Quoted: 360 Post(s)
Liked: 437
That's what I've always done. 3/4" all the way around + doubled up 3/4" for the baffle.
Achievement Unlocked
Psychotic Episode Averted
bass addict is offline
post #3 of 6 Old 11-24-2012, 11:43 PM
N8DOGG's Avatar
Quoted: 973 Post(s)
Liked: 1045
I always like to use 1" plywood for my mounting surface then the flush mount top can be MDF. It makes a nice difference in torquing down the sub. Ply is much better than mdf in that way.
N8DOGG is offline
post #4 of 6 Old 11-25-2012, 08:29 AM
michael hurd's Avatar
Quoted: 43 Post(s)
Liked: 45
For the size of box you were planning on using, 3/4 inch all the way around is plenty, if you add in some bracing. I would use a thin piece of Baltic Birch plywood behind the MDF baffle to screw into. I have had issues with T-nuts before so I would not recommend them to anyone.
I like these.... http://www.parts-express.com/pe/showdetl.cfm?partnumber=293-685
"What the heck was that crashing noise?" Me: "oh, just tossed the shampoo bottles off the shelf on the opposite side of the house. "
michael hurd is offline
post #5 of 6 Old 11-25-2012, 09:12 AM
whiskey_face's Avatar
a local shop carries it but its cheaper to buy 2 sheets of 3/4 and glue it together. eek.gif
whiskey_face is offline
post #6 of 6 Old 11-25-2012, 09:33 AM
AI Limited's Avatar
Wish I had seen those before I bought my T-nuts... I haven't used them yet so I will just use drywall screws for now until I can get some on order! Thanks for posting this!!!
AI Limited
AI Limited is offline
