new Lab12C - AVS Forum | Home Theater Discussions And Reviews
post #1 of 11 Old 11-27-2012, 08:04 AM - Thread Starter
autox320's Avatar
Quoted: 42 Post(s)
Liked: 69
http://www.parts-express.com/pe/pshowdetl.cfm?&Partnumber=290-668&scqty=1
Same great driver now available in 4 ohm load.
Not even compared parameters yet.
"I should really see what dB levels I'm pushing. Long as it can't foam my beer during a movie we are ok "
autox320 is offline
post #2 of 11 Old 11-27-2012, 09:06 AM
Bill Fitzmaurice's Avatar
Liked: 4639
An odd duck, actually, as the standard LAB 12 is six ohms. I'm surprised they brought this out.
Bill Fitzmaurice is online now
post #3 of 11 Old 11-27-2012, 09:41 AM
Bass Enabler
Scott Simonian's Avatar
Quoted: 5285 Post(s)
Liked: 4172
Squeeze out some extra sensitivity to compete with newer bass designs maybe?
Scott Simonian is online now
post #4 of 11 Old 11-27-2012, 10:03 AM
Liked: 4639
It's only a 2dB difference, and that's only of value if your amp is too small to drive the 6 ohm to full output.
post #5 of 11 Old 11-28-2012, 01:14 AM - Thread Starter
autox320's Avatar
Quoted: 42 Post(s)
Liked: 69
I have a standard 6Ohm lab in a small sealed box for the garage. 1.2cu ft sealed powered by a bash300.
I'm not very good with winISD but this C driver models less?
autox320 is offline
post #6 of 11 Old 11-28-2012, 06:30 AM
Liked: 4639
If you let WinISD calculate the default cab size the 4 ohm gives a smaller box size than the 6 ohm, but with a higher F3, so you're not really gaining anything.
post #7 of 11 Old 11-28-2012, 10:33 AM - Thread Starter
autox320's Avatar
Quoted: 42 Post(s)
Liked: 69
Thanks Bill that's kinda what I was seeing, and no real gain. Strange indeed this driver is biggrin.gif
autox320 is offline
post #8 of 11 Old 10-17-2013, 10:49 AM
Gaugster's Avatar
Quoted: 63 Post(s)
Liked: 56
Was checking into replecments for an older set of JL Audio subs that I use in Isobaric setup. This LAB12c looks like a really good match. I think because of the Vas.
So i guess that does make it odd compared to more modern woofers
Gaugster
Gaugster is offline
post #9 of 11 Old 10-17-2013, 12:24 PM
Martycool007's Avatar
Quoted: 280 Post(s)
Liked: 176
Is this more of a woofer or subwoofer? How would it work in a mid-bass setup, or as a woofer in a 2-way of 3-way?
Martycool007 is offline
post #10 of 11 Old 10-17-2013, 01:00 PM
Gaugster's Avatar
Quoted: 63 Post(s)
Liked: 56
My interest in the 12c would be to replace old automotive subwoofers that found new life in my home theater set up. Xmax is 13mm IIRC. That would be fine for me as a subwoofer but a lot of sub now have ~18mm xmax that is preferred by others.
Gaugster
Gaugster is offline
post #11 of 11 Old 10-17-2013, 03:38 PM
LTD02's Avatar
Quoted: 2341 Post(s)
Liked: 2577
danley spec'd the original lab12 for the lab horn project. it also found use as a ported sub in imax installs. xmax on it is conservative in the sense that there is much more 'usable max' or whatever you want to call it than it may appear.
Listen. It's All Good.
LTD02 is offline
