8" MCM horn sub builds for car trunk? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 11-27-2012, 05:37 PM - Thread Starter
CZ Eddie's Avatar
Quoted: 65 Post(s)
Liked: 33
Are there any suitable horn builds for the 8" MCM subwoofer (other than Bill's Auto Tuba)?
This is going into a friends 2006 Hyunda Sonata trunk and I figure the max dimensions can be about 18x24x38.
Or a similar $35'ish 8" or 10" sub will do. Something under $50 for the driver.
"The boom is dead, long live the bass"
CZ Eddie is offline
post #2 of 5 Old 11-27-2012, 05:44 PM
lilmike's Avatar
Quoted: 70 Post(s)
Liked: 178
The T-6 will fit in that space, and leave a little room.
As far as drivers? The MCM does not work well in it.
You can make it wider (and brace it), then load it with a 10 or a 12 though, that has been discussed over in the T-6 thread.
lilmike is offline
post #3 of 5 Old 11-27-2012, 06:02 PM - Thread Starter
CZ Eddie's Avatar
Quoted: 65 Post(s)
Liked: 33
Hey Mike. Thanks for responding. Hope you're doing well.
Weird, I was just looking at your 6 build thread and it was huge (6 cu.ft.). I'll look for the T-6 thread, maybe it was a different one.
CZ Eddie is offline
post #4 of 5 Old 11-27-2012, 06:05 PM - Thread Starter
CZ Eddie's Avatar
Quoted: 65 Post(s)
Liked: 33
Ahh, I think I looked at it wrong. Your T6's dimensions do fit. 6 cu.ft. just sounds a lot bigger than it actually is. hahah
http://www.avsforum.com/t/1358033/lilmikes-cinema-t-6
This may be exactly what I'm looking for.
CZ Eddie is offline
post #5 of 5 Old 11-27-2012, 07:23 PM
goku14139268520's Avatar
Hey CZ, nice to see you around.
goku14139268520 is offline
