DIY Surrounds - Should I add polyfill - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 11-28-2012, 09:44 PM - Thread Starter
snaker's Avatar
In general, when building full range speakers cabinets, should you add polyfill to the cabinets or even a little bit of spongy foam? FYI, I'm cutting them at 80 hz.
snaker is offline
post #2 of 3 Old 11-29-2012, 06:14 AM
Bill Fitzmaurice's Avatar
Liked: 5687
Nearly all speakers should be either lined or filled with damping, depending on the design. You probably should spend some time here before embarking on a build:
http://techtalk.parts-express.com/showthread.php?219617-The-Speaker-Building-Bible
Bill Fitzmaurice is offline
post #3 of 3 Old 11-29-2012, 03:03 PM - Thread Starter
snaker's Avatar
Thank you for your response.
snaker is offline
