would not work with reciever - AVS Forum | Home Theater Discussions And Reviews
post #1 of 19 Old 11-29-2012, 12:36 PM - Thread Starter
conner22's Avatar
ok i just bought the klipsche icon kf-26 and they would not work with my pioneer reciever wich is old like circa 1993. whats the problem here do i need a new reciever?
conner22 is offline
post #2 of 19 Old 11-29-2012, 01:19 PM
Bill Fitzmaurice's Avatar
Liked: 5684
Why not? BTW, you're in the wrong section, this is DIY, you should be in Speakers.
conner22 likes this.
Bill Fitzmaurice is offline
post #3 of 19 Old 11-29-2012, 10:09 PM - Thread Starter
conner22's Avatar
Can you hook a old reciever up to a HDTV tv?
conner22 is offline
post #4 of 19 Old 11-29-2012, 10:26 PM
bass addict's Avatar
Quoted: 372 Post(s)
Liked: 448
Yes
/ thread. smile.gif
Achievement Unlocked
Psychotic Episode Averted
bass addict is offline
post #5 of 19 Old 11-30-2012, 03:48 AM
ovrrdrive's Avatar
Not if you want it to switch video as well as sound. If it doesn't have hdmi ports on it you can still use it but you'll have to switch the video on the TV and then the audio separately on the receiver.
ovrrdrive is offline
post #6 of 19 Old 11-30-2012, 06:12 AM
Liked: 5684
Yes, just send the audio out of the TV to the receiver.
I don't use the routing capability of my receiver, I send all the sources to the TV, and pull the audio out of the TV to the receiver, so when I change sources the audio source is switched along with the video. This allows me to run the audio through my DSP, which otherwise I couldn't do.
post #7 of 19 Old 11-30-2012, 01:33 PM
ovrrdrive's Avatar
I used to do the same thing back when I first got my TV but I read somewhere that at least the TV I got (Samsung 50" plasma FP T5084) modified the surround sound so I finally just bought a receiver that switched hdmi. I don't recall exactly what it was doing but something wouldn't work the way I wanted it to. It might have had something to do with blueray or something. Sorry for being so vague but I don't remember exactly what the problem was. I do know that I was still running all of the audio from each device straight to the htr because of it. I've had the TV since 2008 though so it probably isn't an issue anymore. My favorite part of the movies is the soundtrack though so I wanted it to be as clean as possible. YMMV...
post #8 of 19 Old 11-30-2012, 01:47 PM
Liked: 5684
AFAIK all TVs output the same stereo signal that DVD players do, with surround processing taking place in the receiver. Some do internal processing but AFAIK it only affects the sound from the internal speakers.
post #9 of 19 Old 12-01-2012, 09:21 AM - Thread Starter
conner22's Avatar
How do you send the audio out of the tv?
conner22 is offline
post #10 of 19 Old 12-01-2012, 09:28 AM
Liked: 5684
Me? Via the audio output jacks.
post #11 of 19 Old 12-01-2012, 09:40 AM - Thread Starter
conner22's Avatar
I tried that
conner22 is offline
post #12 of 19 Old 12-01-2012, 09:40 AM - Thread Starter
conner22's Avatar
Didnt work
conner22 is offline
post #13 of 19 Old 12-01-2012, 09:56 AM
Quoted: 372 Post(s)
Liked: 448
Didnt work
Originally Posted by bass addict View Post
Yes
/ thread. smile.gif
post #14 of 19 Old 12-01-2012, 10:50 AM
ovrrdrive's Avatar
I was using the optical out on my TV when I tried it. LCR worked fine but I couldn't get any surrounds at all. After thinking about it, that was the problem at least with my TV. During the conversion to optical it wouldn't pass the surrounds.
post #15 of 19 Old 12-01-2012, 01:30 PM
Liked: 5684
The optical out doesn't send surround information, it sends a stereo signal. The receiver decodes the stereo to x.1.
post #16 of 19 Old 12-01-2012, 02:00 PM
J_Palmer_Cass's Avatar
Quoted: 394 Post(s)
Liked: 118
Why do you use the analog output jack? Note that most TV sets will not send out multi-channel audio except when you use the optical output along with the built in digital TV tuner. Muti-channel outputs from say a DVD player will not pass through on most TVs.
The analog audio output jacks will at best give you a stereo output. That type of output should work fine to use with for an older AVR from 1993 that the OP is using.
J_Palmer_Cass is offline
post #17 of 19 Old 12-01-2012, 02:05 PM
Quoted: 394 Post(s)
Liked: 118
I tried that
Didnt work
You have to go into the TV menu and select the analog output jacks. I have to choose between internal and external speakers. I also have to choose between headphone level and speaker level analog outputs.
post #18 of 19 Old 12-02-2012, 10:51 AM - Thread Starter
conner22's Avatar
conner22 is offline
post #19 of 19 Old 12-02-2012, 10:55 AM - Thread Starter
conner22's Avatar
This is the only option it gives me changed it up still nothing
conner22 is offline
