DIY wiring question ? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 12-01-2012, 10:37 PM - Thread Starter
randyc1's Avatar
Quoted: 238 Post(s)
Liked: 40
I've made my own cables for my 2 subs that im building , is it a good idea to solder all of the ends of my cables ( instead of just leaving them on bare wire) , same for the end in the sub before they are conected to the voice coils.
....Simply put,.. Just leave wires bare or solder all ends ??
randyc1 is offline
post #2 of 6 Old 12-01-2012, 10:46 PM
LTD02's Avatar
Quoted: 2341 Post(s)
Liked: 2577
no need for solder if you have a good physical connection.
Listen. It's All Good.
LTD02 is offline
post #3 of 6 Old 12-02-2012, 12:35 PM - Thread Starter
randyc1's Avatar
Quoted: 238 Post(s)
Liked: 40
Thanks LTD , just thought they would oxidate without soldering ?
randyc1 is offline
post #4 of 6 Old 12-02-2012, 04:22 PM
Bill Fitzmaurice's Avatar
Liked: 4647
More likely with it.
Bill Fitzmaurice is online now
post #5 of 6 Old 12-03-2012, 07:35 AM - Thread Starter
randyc1's Avatar
Quoted: 238 Post(s)
Liked: 40
Originally Posted by Bill Fitzmaurice View Post
More likely with it.[/quote
OK thanks guys
randyc1 is offline
post #6 of 6 Old 12-03-2012, 07:34 PM
maxcooper's Avatar
Quoted: 13 Post(s)
How are they connected now?
(I think you are asking about 'tinning' the wires with solder, rather than making a soldered connection. I agree that you probably should not tin the wires.)
-Max
maxcooper is offline
