Behringer EP4000 Price Change - AVS Forum | Home Theater Discussions And Reviews
post #1 of 46 Old 12-02-2012, 02:16 PM - Thread Starter
gw742296's Avatar
The behringerEP4000 is back in stock at WALMART.COM
$275.00 + Local Tax
Free pickup at your local Walmart
Shipping $4.97
Warranty 3yrs $28.00
gw742296 is offline
post #2 of 46 Old 12-02-2012, 02:19 PM
Sibuna's Avatar
Quoted: 373 Post(s)
Liked: 429
nice.
I ordered it when it was up last week. made it from site to store in 2 days
Sibuna is online now
post #3 of 46 Old 12-02-2012, 02:20 PM
FOH
FOH's Avatar
Quoted: 38 Post(s)
Liked: 234
Sweet, quite the bargain.
Already have two of them, but that's a deal.
Active 16.8kw, 7.3 system
(2)Seaton SubM-HP, (4)18" IB
FOH is offline
post #4 of 46 Old 12-02-2012, 02:33 PM
bass addict's Avatar
Quoted: 360 Post(s)
Liked: 437
Yup. Jumped on one, should probably order another. You can never have too many amps laying around, lol.
Achievement Unlocked
Psychotic Episode Averted
bass addict is offline
post #5 of 46 Old 12-02-2012, 07:39 PM
kcnitro07's Avatar
Quoted: 12 Post(s)
Dang I just got my EPX4000 for $360
kcnitro07 is offline
post #6 of 46 Old 12-02-2012, 09:07 PM - Thread Starter
gw742296's Avatar
Too many of you snapped up the latest supply.
gw742296 is offline
post #7 of 46 Old 12-03-2012, 07:40 PM
brian6751's Avatar
Quoted: 879 Post(s)
Liked: 675
How often they come in stock?
That's not science! - Cyborg
Steam ID: The Barbeerian
Rivers Edge Theater
brian6751 is offline
post #8 of 46 Old 12-03-2012, 09:50 PM - Thread Starter
gw742296's Avatar
It usually is every other week.
gw742296 is offline
post #9 of 46 Old 12-05-2012, 07:09 PM
Sibuna's Avatar
Quoted: 373 Post(s)
Liked: 429
post #10 of 46 Old 12-06-2012, 07:48 AM
tashspop's Avatar
Quoted: 63 Post(s)
sweet, done.
so what is the cheapest best way to handle frequency control on this guy for sub duties?
samsung un55hu9000 sek3500 Marantz av7702 Audiocontrol Savoy 7x150 4x MA500U
swope center, tmww fronts, tm surrounds and rears
polk audio OWM3 x4 atmos
4 12" t3 audio subs ep4000 amp
tashspop is online now
post #11 of 46 Old 12-06-2012, 08:07 AM
robotbunny's Avatar
Originally Posted by tashspop View Post
sweet, done.
mini dsp 2x4 unbalanced: $125 or balanced $145
robotbunny is offline
post #12 of 46 Old 12-06-2012, 08:45 AM
kcnitro07's Avatar
Quoted: 12 Post(s)
get the balanced
post #13 of 46 Old 12-06-2012, 08:46 AM
Gorilla83's Avatar
Quoted: 370 Post(s)
Liked: 513
Originally Posted by kcnitro07 View Post
get the balanced
X2. The majority of pro amps are going to expect a >1 V output than the unbalanced provides to produce full rated power. The balanced version can output 2V RMS to supply the needs of most pro amplifiers.
Gorilla83 is online now
post #14 of 46 Old 12-06-2012, 09:28 AM
brian6751's Avatar
Quoted: 879 Post(s)
Liked: 675
Originally Posted by Gorilla83 View Post
X2. The majority of pro amps are going to expect a >1 V output that the unbalanced provides to produce full rated power. The balanced version can output 2V RMS to supply the needs of most pro amplifiers.
i think you meant "The majority of pro amps are going to expect a >1 V output than the unbalanced provides to produce full rated power." ?
Rivers Edge Theater
post #15 of 46 Old 12-06-2012, 09:37 AM
brian6751's Avatar
Quoted: 879 Post(s)
Liked: 675
thats why you want the BALANCED version if using a pro amp. it has a higher input signal, correct? i know you use pro amps and im looking at getting a minidsp and a pro amp so im just making sure
Rivers Edge Theater
post #16 of 46 Old 12-06-2012, 09:37 AM
Gorilla83's Avatar
Quoted: 370 Post(s)
Liked: 513
Yes, corrected. My apologies.
Most pro amps will need 1.7ish volts to product full output. The unbalanced version will not do that without a booster / cleanbox, etc.
post #17 of 46 Old 12-06-2012, 09:46 AM
brian6751's Avatar
Quoted: 879 Post(s)
Liked: 675
so, in an attempt to stay on topic here, does the balanced dsp's higher output signal make up for the commercial avr sub output's lower signal making for a good match with the ep4000?
Rivers Edge Theater
post #18 of 46 Old 12-06-2012, 09:55 AM
Stereodude's Avatar
Quoted: 3086 Post(s)
Liked: 2237
Yes it can give you some additional gain, but it's far from an established fact that all commercial AVRs have low output signals.
For example, my Pioneer Elite SC-05 at reference (0dB) with the SW channel trim at 0dB can clip the input on a balanced MiniDSP (using the 2V input jumper setting).
Stereodude is online now
post #19 of 46 Old 12-06-2012, 10:13 AM
brian6751's Avatar
Quoted: 879 Post(s)
Liked: 675
ok, so its kind of a non issue in this case then?
Rivers Edge Theater
post #20 of 46 Old 12-06-2012, 10:33 AM
Gorilla83's Avatar
Quoted: 370 Post(s)
Liked: 513
The issue becomes when you combine a normally capable output receiver with a balanced minidsp that will output 0.9V at maximum output.
http://www.minidsp.com/images/documents/Product%20Brief-MiniDSP.pdf
post #21 of 46 Old 12-06-2012, 10:52 AM
Quoted: 360 Post(s)
Liked: 437
They are back in stock at Wally World right now. Just snagged another one. smile.gif
post #22 of 46 Old 12-06-2012, 11:19 AM
Stereodude's Avatar
Liked: 2237
confused.gif The balanced model outputs 2V, not .9V. I assume you meant the unbalanced model which is limited to .9Vrms output?
post #23 of 46 Old 12-06-2012, 12:22 PM
Gorilla83's Avatar
Quoted: 370 Post(s)
Liked: 513
I suck at typing today. mad.gif Yes, the unbalanced is limited to 0.9V.
post #24 of 46 Old 12-06-2012, 01:14 PM
javygonx's Avatar
Quoted: 98 Post(s)
Liked: 27
Hmm.. I have iNuke3000DSP; and I was thinking seriously in selling it for $350. Brand New. Would you think is worthy replacing the iNuke 3000 DSP with the EP4000? I was looking for oAudio 500W; but are not on stock anymore....
I had an iNuke 3000 DSP and I have no idea why on my DIY 15" Sealed sounds much better with a 250W Bash Amp than with the iNuke 3000DSP!!!!!... So; I will buy an Yung 300W no boost version and use it instead of the iNuke3000DSP. I have another DIY 15" in which I can use the 250W BASH.....
javygonx is offline
post #25 of 46 Old 12-06-2012, 01:54 PM
Quoted: 360 Post(s)
Liked: 437
Did you calibrate everything after the switch? Input/output voltage might have changed, changing output between the 2.
post #26 of 46 Old 12-06-2012, 03:03 PM
Gonzalez Javier's Avatar
I used the Behringer Software to EQ the sub; I put the HPF; setup it to 4ohms, cabling and wiring as stated on manuals; etc... I performed various config files and no matter what; with the plates sounds better. How do I verify the Input/Output voltage?
Gonzalez Javier is offline
post #27 of 46 Old 12-06-2012, 04:15 PM
Quoted: 360 Post(s)
Liked: 437
You can test the output voltage coming out of your receivers LFE jack. Some pro amps require more voltage to reach full potential. It's possible to have two different amps running at a lot different efficiency based on the output voltage.
post #28 of 46 Old 12-06-2012, 08:49 PM
autox320's Avatar
Quoted: 42 Post(s)
Liked: 69
Whoever is listing these should eventually catch on they have to be listing them wrong rolleyes.gif
But until then and in shoppers frenzy of holiday sales it may take them awhile to correct. I don't even need any, but bought a few myself just in case. Back in the day the ep4000 was 300 bucks at PE.
edited:
btw my current rig uses 2 of these amps both running bridge mode into two DTS-10s. Proven performers.
"I should really see what dB levels I'm pushing. Long as it can't foam my beer during a movie we are ok "
autox320 is offline
post #29 of 46 Old 12-06-2012, 08:49 PM
d_c
d_c's Avatar
Quoted: 822 Post(s)
Liked: 873
d_c is online now
post #30 of 46 Old 12-06-2012, 09:14 PM
Quoted: 360 Post(s)
Liked: 437
Originally Posted by d_c View Post
Can't beat $5 shipping for a 47 pound amp.
Exactly. I paid more shipping on the fan upgrade I just ordered for it. cool.gif
