New to DIY? FAQ's in here - Page 5 - AVS Forum | Home Theater Discussions And Reviews
 31Likes
post #121 of 137 Old 12-14-2014, 08:43 PM
Liked: 4
This is one of the better FAQs I have seen, anywhere! Thank you for this excellent intro, I can't wait to get started.
geolchris is offline
post #122 of 137 Old 12-17-2014, 07:51 PM
Liked: 0
Good read!
RMunson is offline
post #123 of 137 Old 01-27-2016, 06:46 PM
I have a newbie question that I almost created a thread for, but it's probably so basic that it doesn't warrant one. I have a pair of Zaph ZD5s built years ago, and after a recent move the drivers have come loose from their mountings. The acoustical particleboard for half of the driver mount screws are stripped. I know there's probably an easy way to fix this, but the last thing I want to do is stick the wrong kind of epoxy or whatever in there, try and re-attach the drivers, and have the wood split... What's the best way to fix this problem?
EcceCapsa is offline
post #124 of 137 Old 01-29-2016, 12:48 PM
Medi0gre's Avatar
Quoted: 35 Post(s)
Liked: 40
Rotate the speaker and install the screws offset into clean wood
Medi0gre is offline
post #125 of 137 Old 01-31-2016, 06:21 AM
rhodesj's Avatar
Quoted: 942 Post(s)
Liked: 533
Another option is toothpicks and wood glue. Coat several toothpicks in glue, wedge them into the hole, cut them flush. Then reinstall the speaker, being careful to not over tighten the screws. Wood glue won't hold on the screw so it can still be easily removed, but it will hold and repair the hole.
rhodesj is offline
post #126 of 137 Old 03-13-2016, 06:07 AM
hatlesschimp's Avatar
Quoted: 482 Post(s)
Liked: 507
I bought two 18" Dayton Ultimax drivers and was wondering if should power them via iNuke 6000dsp or iNuke 6000 + minidsp or buy the Dayton Audio 1200w DSP plate amp. I like the idea of having the sub all in one with only RCA coming out of my reciever but will the RCA signal deteriorate at roughly 13m/15m in length?
hatlesschimp is offline
post #127 of 137 Old 05-22-2016, 09:14 PM
derrickdj1's Avatar
Quoted: 992 Post(s)
Liked: 731
If you don't have the Mini DSP, the I Nuke 6000 DSP is a good choice from a cost perspective.
derrickdj1 is offline
post #128 of 137 Old 07-30-2016, 10:28 PM
jeffrobinson's Avatar
Liked: 1
Howdy Gents! Noob here, wondering if there is a section for introductions etc. Migrating from Home Theater Shack.
jeffrobinson is offline
post #129 of 137 Old 08-08-2016, 09:53 AM
Quoted: 18 Post(s)
Liked: 7
Great post with lots of info.. Will be visiting here more often...!!
siddforuall is offline
post #130 of 137 Old 09-28-2016, 12:58 PM
thillrh's Avatar
For sure! Learning with every visit.
thillrh is offline
post #131 of 137 Old 11-11-2016, 03:09 PM
Liked: 4
Hey Guys,
I was also wondering if there is somewhere for introductions. I am new to diy home audio, but have built several car audio systems. I am very interested in home audio and am thinking about starting with some overnight sensation kits.
imagic likes this.
zaclaw is offline
post #132 of 137 Old 11-12-2016, 05:23 PM
asarose247's Avatar
Quoted: 832 Post(s)
Liked: 642
WELCOME!
leave while you can,
OTOH read around, try some different searches, read stuff over at the DIY sound group home threads/ builds
ASK Questions on some of the forums threads
even Parts Express has a ton of info that may seem overwhelming,
but read with the intent of developing a better focus about the possibilities you and your budget and all that other stuff allows you to think of short term and longer term goals for evolving HT growth . . .
if you go with proven designs , success guaranteed,
some ask about how to put together a seemingly well thought out and maybe even actually synergistic-ally, superlative planned collection of parts, but lack the E.E. degree to put it together, wrt the crossovers, the box, etc.
many here have a tendancy to shy away from the "frankersprecher" appeals
unless you're one really charming mofo . (thanks to Pulp Fiction-you know the line)
now get to work
zaclaw likes this.
DIY FAN Denon X5200 , ATI A 2000 for 7.4.6 SCATMOS/DSU Sammy 82" 4K/HDR
L/R: Fusion 15 V2 , C: 88 Special , SL/SR: 88 Special(V2) , RL/RR: F-3, TF/TR: Volt 6's TM: SLX, FH: F4Q4
SUBMAXIMUS, ,Submaximus V3,LOWARHORNCustom Dual Driver VBSS,2 x 6000DSP
www.avsforum.com/forum/155-diy-speakers-subs/1485120-submaximus-large-front-loaded-horn
http://www.avsforum.com/forum/155-di...orn-build.html
asarose247 is online now
post #133 of 137 Old 12-05-2016, 10:16 AM
andrewlef's Avatar
Quoted: 130 Post(s)
Liked: 45
This post was extremely helpful for mounting hardware. Using slab nuts with MDF cabinets is extremely easy and works WAY better than threaded inserts (even EZ-Lok Finserts, which are made for MDF).
Slab Nuts from Stafast
Socket Cap 1/4"-20 Black Oxide 2-1/4" length machine bolts
High Collar Lock washers 1/4" diameter
Wood screws #5 x 5/8" length
In addition, you'd need two drill bits: 5/16" and 5/64"
gworrel, ORIF and Oklahomie like this.
andrewlef is offline
post #134 of 137 Old 01-22-2017, 05:39 PM
mraub's Avatar
Quoted: 47 Post(s)
The infinite baffle information site URL earlier in this thread is dead. The correct URL is: http://ibsubwoofers.proboards.com
MIKE
For every complex problem, there is a solution that is simple, neat, and wrong.
--H. L. Mencken
mraub is offline
post #135 of 137 Old 04-14-2017, 08:00 AM
Liked: 3
Very good introduction, thanks all for the help getting into this hobby. Now time to upgrade the HT.
Budget HT v1.0; DIY NHT-1259 powered by Dayton plate amp, TriTrix MTM TL, Yamaha 675, BenQ W1070, DIY painted screen
pnhayden is offline
post #136 of 137 Old 04-23-2017, 07:35 PM
Liked: 0
Is it better to line my three way speaker cabinet (ported) with something on the inside walls or stuff it with poly wool?
WINSLOW LEACH is offline
post #137 of 137 Old 04-30-2017, 05:59 PM
joker927's Avatar
Where are folks getting cheap r13 demin insulation? I can only find huge bags.
joker927 is offline
