Need more extension - AVS Forum | Home Theater Discussions And Reviews
Old 12-06-2012, 09:07 PM - Thread Starter
stgdz's Avatar
So a couple of years back I built this TH
http://www.avsforum.com/t/1240371/high-output-8-tapped-horn
it doesn't break any windows or belt out huge spl but it certainly delivers good performance for its size and cost. I want to go deeper though but I'm pretty size limited. The max dimensions are 48"x15x30.
Is there any good designs out there currently that would get me down to say 18hz at 105db or 100db? Can't go sealed.
stgdz is offline
Old 12-06-2012, 09:12 PM
brian6751's Avatar
Quoted: 890 Post(s)
Liked: 687
Side firing, ported Dayton HO18 ?
That's not science! - Cyborg
Steam ID: The Barbeerian
Rivers Edge Theater
brian6751 is offline
Old 12-06-2012, 09:47 PM
bass addict's Avatar
Quoted: 360 Post(s)
Liked: 437
How bout a sonosub? It would fit the footprint and provide exactly what you are looking for.
Achievement Unlocked
Psychotic Episode Averted
bass addict is offline
Old 12-07-2012, 06:48 PM - Thread Starter
stgdz's Avatar
I like this idea and never considered a side firing sub.
If I go with a slot port like the easy button, figure 2" tall and 13.5 wide the port length would be about 91.5" and the chamber is around 7-8cuft. Hitting it with a 500 watt bash amp where would I hit the X-max? I may be able to build this on two sheets.
I can never get my models to work for some darn reason in winisd.
stgdz is offline
Old 12-12-2012, 08:17 PM - Thread Starter
stgdz's Avatar
Been playing around with winisd, mdeling with a bash 500w amp and the dayton 18" and the SI 18"
Course then I remembered I have two unused 18" maelstroms in my basement and put that in the model with an ep2500 and 2kw
Am I missing something, the box has a driver depth dimension of about 13.5". I can build it in two sheets doubling up the baffle or possibly one sheet with one baffle.
stgdz is offline
Old 12-14-2012, 09:13 PM - Thread Starter
stgdz's Avatar
So no comments?
After looking at some numbers and seeing what I would have to buy I think I am going to go with the SI 18" and a 550 watt dayton plate amp, box is about 10cuft and a 27.25x12.5 port length. I'm going to need two sheets for this.
I think I may sell my two sealed mael-x's in their own cubes.
stgdz is offline
Old 12-14-2012, 09:16 PM
Thatsnasty's Avatar
Quoted: 51 Post(s)
Liked: 42
Originally Posted by stgdz View Post
So no comments?
Why cant you go sealed?
What about a giant LLT box.
2 maels in a sealed box would be pretty good on the low end, imo.
Thatsnasty is offline
Old 12-14-2012, 10:55 PM - Thread Starter
stgdz's Avatar
Can't go sealed
https://www.dropbox.com/s/2r2z77loxq7as6i/2012-11-29%2021.51.05.jpg
I have to deal with what I have and those dimensions are the largest I can go. I've pretty much tossed out the idea of sealed since I need output.
stgdz is offline
Old 12-14-2012, 11:15 PM
BassThatHz's Avatar
Quoted: 2035 Post(s)
Liked: 1567
Quad HO-18 dual-opposed would just fit into a 37x18.5x18.5, the bigger the better.
Model that, see what you get...
BassThatHz is offline
Old 12-15-2012, 10:54 AM - Thread Starter
stgdz's Avatar
stgdz is offline
Old 12-15-2012, 06:30 PM
BassThatHz's Avatar
Liked: 1567
Do you guys even read what I type?
Yes, but: Why are you restricted to those parameters to such a degree?
One of this: http://www.data-bass.com/data?page=system&id=3&mset=35
In one of this: 48x15x30
and one of this: http://www.crestaudio.com/products/browse.cfm/action/detail/item/116972/number/03513840/cat/342/CC%205500.cfm
105db @ 18hz or better, in 2-PI space no less.
Old 12-16-2012, 08:24 PM - Thread Starter
stgdz's Avatar
plus I have 4 maelstroms in the basement and I have to keep the boss happy, she's a bit unhappy with 85db at 60hz so I don't need to go full reference level in my critical viewing area.
stgdz is offline
