upgrading Polk woofer to Def tech woofer? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 12-07-2012, 06:43 AM - Thread Starter
stevethebrain's Avatar
Quoted: 108 Post(s)
Liked: 25
I have the CS1 center channel how easy or hard would it be to swap woofers like aren't 5.25" speaker mounting holes all standard like both Polk and Def Tech holes would line up on the CS1 cabinet correct?
was planning on leaving the tweeter and crossover as Polk.
http://www.ebay.com/itm/Definitive-Technology-BP8-BP2X-5-25-Driver-4AAG-/180654472920?_trksid=p5197.m1992&_trkparms=aid%3D111000%26algo%3DREC.CURRENT%26ao%3D1%26asc%3D14%26meid%3D3989137287042101456%26pid%3D100015%26prg%3D1006%26rk%3D1%26sd%3D180654472920%26
the polk cabinet has a tube port vent. the DT cabinet is designed w/ a passive radiating type inclosed type port curious if this has an effect on the woofer?
is this a good plan to add a little umff to the speaker?
Thanks STB
Samsung PN58C500/Amp: Yamaha RX-V465/Polk DSW1KProSub/DefTECH SM450/C1CC/Pro80/Sony BPX37 BD/Magnavox515/ HTPC-CPU: I3 550, 3.2 GHz/Mobo: Intel H57/RAM: 6GB DDR3 1333/HDD: 1TB/2TBX2 Internal, 1TB external/Tuner: 1800-950 Haupague/W7 64 OS Remote: Harmony 700
stevethebrain is offline
post #2 of 3 Old 12-08-2012, 06:34 AM
Martycool007's Avatar
Quoted: 280 Post(s)
Liked: 181
No, you can not do that. No offense but this question that you asked shows you severe lack of understanding about how this stuff works. You can't just unscrew your Polk woofer and put a new woofer on and expect to improve the sound quality. Every speaker has a crossover that is designed for that particular enclosure and combination of drivers. If you change out one of the drivers then you also have to change the crossover, which is very very complicated. If you want better sound quality, then sell your current setup and buy a different one. (note- I am absolutely hate Polk speakers as I feel like they are overpriced junk).
Martycool007 is offline
post #3 of 3 Old 12-08-2012, 09:15 AM
Bill Fitzmaurice's Avatar
Liked: 5684
Originally Posted by Martycool007 View Post
If you change out one of the drivers then you also have to change the crossover.
That's the least of the potential issues. Foremost is that the replacement driver must have T/S specs compatible with the cabinet design, then it must have sensitivity and frequency response that will work with the tweeter.
Bill Fitzmaurice is offline
