Dual GJALLARHORNs! - Page 22 - AVS Forum | Home Theater Discussions And Reviews
 5Likes
post #631 of 796 Old 11-09-2013, 08:46 PM
stormwind13's Avatar
Quoted: 60 Post(s)
Liked: 96
Originally Posted by lukeamdman View Post
I don't know man. .. the clones clip lights were on solid, and the crest was 1.5db louder and shoes no signs of running out. I only stopped because the 5400 was now collapsing the foundation of my house...
The crest was probably outputting over 1kw more.
Fixed it for you.
stormwind13 is offline
post #632 of 796 Old 11-09-2013, 08:48 PM - Thread Starter
lukeamdman's Avatar
Quoted: 1080 Post(s)
Liked: 1200
lukeamdman is offline
post #633 of 796 Old 11-19-2013, 11:06 AM
kutlow's Avatar
Quoted: 113 Post(s)
Liked: 44
I just looked up the crest cc5500 and compared it to the pro 200 line the crest 9200. According to the website it looks like the pro 200 line amp the pro 9200 would outduel the cc5500? Is that right?
http://www.peaveycommercialaudio.com/products.cfm/Power+Amplifiers
kutlow is offline
post #634 of 796 Old 11-19-2013, 11:18 AM - Thread Starter
lukeamdman's Avatar
Liked: 1200
Yep, the 9200 has more power everywhere. But, even used it's double the cost of the 5500, but it's an awesome amp!
You can tell from the 5500 specs that running stereo both channel driven vs just one channel (not bridged) that its power supply is limiting it. The 9200 might be what the 5500 could do with a class d switching power supply.
If you can afford it over the 5500 and want the extra juice, I say go for it.
post #635 of 796 Old 11-19-2013, 07:54 PM
kutlow's Avatar
Quoted: 113 Post(s)
Liked: 44
I have 2 of the 9200 and 3 of the 8200 crest amps. I have 3 DTS 10'S with the LMSR UPGRADE. and in the latest James bond film on the subway scene I noticed my amps clipping and cutting the bass off for a few seconds. Does that mean the amp is overdriving the lmsr drivers? That is the only scene Ive seen that happen in. Mt 3 DTS 10'S are powered by the 9200 amps.
kutlow is offline
post #636 of 796 Old 11-19-2013, 08:47 PM
Pain Infliction's Avatar
Quoted: 978 Post(s)
Liked: 506
Sounds like the opposite to me. More like the amps can't keep up with the drivers. Somebody with more knowledge than me will can answer better.
How do you have them wired to the amp?
The Thompson Theater
RIP William Alexander
Pain Infliction is offline
post #637 of 796 Old 11-19-2013, 09:42 PM
SASSAFRAS KING's Avatar
will this sundown sub(X18 D2) work in this design? i just dont see myself spending 1k for an lms ultra
http://www.woofersetc.com/p-11695-x-18-d2-sundown-audio-18-dual-2-ohm-1250w-rms-subwoofer.aspx
SASSAFRAS KING is offline
post #638 of 796 Old 11-19-2013, 10:56 PM
gpmbc's Avatar
Quoted: 312 Post(s)
Liked: 197
If the sundown isn't a candidate, the Mach 5 audio uxl 18 is several hundred less than the LMS and proven to work in this horn.
gpmbc is online now
post #639 of 796 Old 11-20-2013, 03:54 PM
N8DOGG's Avatar
Quoted: 967 Post(s)
Liked: 1038
I've got the UXL's in my G-horns, they work great and pound like mad!
N8DOGG is offline
post #640 of 796 Old 11-20-2013, 04:08 PM
gpmbc's Avatar
Quoted: 312 Post(s)
Liked: 197
N8 do you have both in use or just the one?
gpmbc is online now
post #641 of 796 Old 11-21-2013, 03:21 PM
N8DOGG's Avatar
Quoted: 967 Post(s)
Liked: 1038
Just one in use right now, the other is in my workout room under a bunch of boxes lol
N8DOGG is offline
post #642 of 796 Old 11-21-2013, 03:26 PM
jpmst3's Avatar
Quoted: 97 Post(s)
Liked: 233
I was just about the grab a pair of LMSs for the GJALLARHORN re-fold, but can't wrap my head around the cost. So, I keep coming back to the UXL for not much more than half the cost!
Did you get a chance to compare the two?
Joe = LFE Addict
Joe's LOWARHORN build
jpmst3 is offline
post #643 of 796 Old 11-21-2013, 03:40 PM
Bass Enabler
Scott Simonian's Avatar
Quoted: 5285 Post(s)
Liked: 4172
I can't really comment on the two G-horns but ... from what I know of the differences of the drivers, I'd bet that the LMSU would have a slight advantage at the very very edge of the limits of the system.
Scott Simonian is offline
post #644 of 796 Old 11-21-2013, 03:42 PM
N8DOGG's Avatar
Quoted: 967 Post(s)
Liked: 1038
The UXL is about 95% of what the LMS can do, so you won't be missing much.
N8DOGG is offline
post #645 of 796 Old 11-21-2013, 03:42 PM
jpmst3's Avatar
Quoted: 97 Post(s)
Liked: 233
I am sure you are correct in that regard.
However, I was curious if there was an audible quality/tonal difference in the two when used in a horn config...during "normal" listening levels. (whatever that means in this forum!)
Joe = LFE Addict
jpmst3 is offline
post #646 of 796 Old 11-21-2013, 04:05 PM - Thread Starter
lukeamdman's Avatar
Liked: 1200
I'm skeptical...
Josh stresses the importance of the motor force of a driver for use in horns, and the LMS has over 20% more motor force than the UXL.
Does a 20%+ stronger motor really only equal 5% more in performance?
post #647 of 796 Old 11-21-2013, 04:10 PM
Bass Enabler
Liked: 4172
Heh.
Most likely nothing. Most of the difference will be 50hz and above and at the extreme end of the throw of the driver(s).
I'm skeptical...
Agreed. Both get the job done in a small cab. So close it could be said that the UXL is 95% of an LMS-U wink.gif that is until you start injecting high level <30hz content. smile.gif
That's where the $300 difference comes in and the LMS-Ultra takes the lead and keeps it.
post #648 of 796 Old 11-21-2013, 04:15 PM - Thread Starter
lukeamdman's Avatar
Liked: 1200
Heh.
When doing the math, 95% actually kinda sucks...lol
For example, one GH with a LMS can do 120db at 20hz. 95% of 120db is 114db...6db less...
6db is a doubling of both the subwoofer and amplifier. Meaning it would take two GH's loaded with UXL's and each fully powered to match a single GH with an LMS...
post #649 of 796 Old 11-21-2013, 04:22 PM
LTD02's Avatar
Quoted: 2341 Post(s)
Liked: 2577
YOLO
get one lms...build one enclosure...get hooked.
then the second won't be painful at all. :-)
Scott Simonian likes this.
Listen. It's All Good.
LTD02 is offline
post #650 of 796 Old 11-21-2013, 04:22 PM
jpmst3's Avatar
Quoted: 97 Post(s)
Liked: 233
Of course, you are assuming that you are running them all at the max limits. I would assume that most people are not pushing most subs that hard.
Joe = LFE Addict
jpmst3 is offline
post #651 of 796 Old 11-21-2013, 04:25 PM - Thread Starter
lukeamdman's Avatar
Liked: 1200
Yes, and I also have no idea what the UXL numbers would be and this is all just pure speculation.
However, I'm sure most don't push subs that hard, but I most certainly do!
post #652 of 796 Old 11-21-2013, 04:26 PM
Bass Enabler
Liked: 4172
Lol! Yeah really but... audio doesn't work that way. 5% less of 120dB (at what, where? wtf!??!) is not suddenly 6dB less. Wait ..... What are we talking about again? tongue.gif
YOLO
Mmmm, no, not necessarily. In the end it's your call.
How bad do you need to save $300? How long do you think you'll keep the G-horn? Over a year? Several years? Get the Ultra. cool.gif
post #653 of 796 Old 11-21-2013, 04:26 PM
jpmst3's Avatar
Quoted: 97 Post(s)
Liked: 233
Joe = LFE Addict
jpmst3 is offline
post #654 of 796 Old 11-21-2013, 04:28 PM
jpmst3's Avatar
Quoted: 97 Post(s)
Liked: 233
Good point, that's how I typically think as well. But, sometimes I need to force myself to think more rationally sometimes, YOLO, but I ain't printing money either!biggrin.gif
Joe = LFE Addict
jpmst3 is offline
post #655 of 796 Old 11-21-2013, 04:32 PM
Bass Enabler
Liked: 4172
You know... I'm just thinking in a way because I know you and you already have experience with the Ultra and loved it. Another would make sense. Also I never get the feeling you are on a severe budget so a $300 difference even over a years time is ... not all that much.
Now if you're coming in here saying, "hey I want to build four of these horns but I don't have all the money in the world" then I'd think that the UXL would be the perfect choice.
In this case....
post #656 of 796 Old 11-21-2013, 04:35 PM
jpmst3's Avatar
Quoted: 97 Post(s)
Liked: 233
Damn you all! I guess I have to order an LMSU....Ugh!
Joe = LFE Addict
jpmst3 is offline
post #657 of 796 Old 11-21-2013, 05:39 PM
N8DOGG's Avatar
Quoted: 967 Post(s)
Liked: 1038
That not how it works. It's not a fixed 95% number. If you look at their numbers, the LMS leads in a lot of ways but the UXL also put up a great fight and wins in some also.
I'd also like to point out, I don't think anyone has had direct LMS vs UXL experience in a G-horn, myself included. Both drivers can take all the power 1 channel of a clone 14K can give and I'm sure both are awesome!
N8DOGG is offline
post #658 of 796 Old 11-21-2013, 05:45 PM
Bass Enabler
Liked: 4172
Agreed in full.
post #659 of 796 Old 11-21-2013, 05:57 PM - Thread Starter
lukeamdman's Avatar
Liked: 1200
Yep, it doesn't work, hence my comments earlier about it being speculation since I have no idea would the UXL number would be.
But, it got your attention, and it just goes to show how "95%" is also pure speculation.
post #660 of 796 Old 11-21-2013, 06:12 PM
d_c
d_c's Avatar
Quoted: 824 Post(s)
Liked: 879
"I hear ya. Yes, the LMS is bad ass, no argument there.
Damn you all! I guess I have to order an LMSU....Ugh!"
+1 for the Ultra. Better make it 2 since making the two horns at the same time is really going to save you some time. Don't fight it Jpm - you obviously want face-melting LFE, get started with your G-horns already!
d_c is offline
