Dual GJALLARHORNs! - Page 25 - AVS Forum | Home Theater Discussions And Reviews
 5Likes
post #721 of 796 Old 12-13-2013, 06:35 AM
Pain Infliction's Avatar
Quoted: 978 Post(s)
Liked: 506
Originally Posted by chrapladm View Post
Well it definitely sparked my interest. And as long as it doesn't cost $1000 I might even be able to make something happen. wink.gif
It could cost that much or close. It is a 21" driver after all with nice specs. We shall see though.
The Thompson Theater
RIP William Alexander
Pain Infliction is offline
post #722 of 796 Old 12-13-2013, 07:43 AM - Thread Starter
lukeamdman's Avatar
Quoted: 1105 Post(s)
Liked: 1242
lukeamdman is offline
post #723 of 796 Old 12-13-2013, 09:04 AM
Quoted: 978 Post(s)
Liked: 506
That's crazy expensive!
post #724 of 796 Old 12-13-2013, 10:25 AM
Ricci's Avatar
Quoted: 185 Post(s)
Liked: 473
That one driver being talked about is REAL painful on the wallet. Like a tax audit or a divorce. Useful excursion limit is around 20-25mm one way. The driver, Zod Audio, the amplifier and the PaleHorn are all forged from solid unobtanium unfortunately with certain key components cast in unaffordium on top of that.
You guys remember the first rule of Fight Club? That pretty much applies to all of that stuff until I hear different...
Originally Posted by d_c View Post
I think I like v1 due to the ease of getting the driver in and out. Not that it has to be done often, but you would have to remove the magnet to get it in there without scuffing up the surround.
There are dual side hatches. The magnet does not have to be removed. In fact there is room for an even bigger deeper driver. The hatch is actually 15.5" wide. Shouldn't be that bad.
Originally Posted by lukeamdman View Post
My thoughts exactly.
After feeling the TC Sounds 18" VMP radiators, which I think use the same basket, cone, dual spiders, and surround as the 5400, you couldn't get the cone to move in a non-linear fashion no matter which way you pulled/pushed/twisted on the bolt for the washers. It was shocking how the only movement was perfectly linear. If that's the case, I don't see the way the driver is mounted in V2 ever being a problem, but I know some will say otherwise.
The VMP uses a heavier cone, heavier stiffer surround material, different stiffer spider, etc...Just saying.I don't know how big of an issue sag would be either, but while I'm attempting to improve things it can't hurt right?
Scott Simonian likes this.
Ricci is offline
post #725 of 796 Old 12-13-2013, 12:27 PM
Bass Enabler
Scott Simonian's Avatar
Quoted: 5340 Post(s)
Liked: 4228
Scott Simonian is offline
post #726 of 796 Old 12-13-2013, 12:54 PM
Decadent_Spectre's Avatar
Quoted: 328 Post(s)
Liked: 144
The Zod reminds me a lot of the B&C IPAL 21. The Zod does have a lot more motor though.
Decadent_Spectre is offline
post #727 of 796 Old 12-13-2013, 01:06 PM
LTD02's Avatar
Quoted: 2344 Post(s)
Liked: 2583
the ipal 21" driver comes in at bl^2/re of 521 from my notes.
it is available to oem companies only.
this is public information and unrelated to fight club rule #1.
b&c measures resistance after intensive sine wave testing...current spec for re is 1 ohm, i believe it was measured as 0.7 ohm in the preliminary document that may not have included the "warm up".
Listen. It's All Good.
LTD02 is offline
post #728 of 796 Old 12-13-2013, 05:25 PM
NEO Dan's Avatar
Hey Scott :-)
Dan
NEO Dan is offline
post #729 of 796 Old 12-14-2013, 09:27 AM
kutlow's Avatar
Quoted: 113 Post(s)
Liked: 44
yes and no. If you pay 2000 x 2 and 600 for wood then you have 100.00 for screws etc then you have 4700 for 2 bad ass subs. I had that in 2 jl audio fathom f113 and they wouldn't compare to this.
kutlow is offline
post #730 of 796 Old 12-14-2013, 01:46 PM
NEO Dan's Avatar
DANG! All I got is this...
Dan
NEO Dan is offline
post #731 of 796 Old 01-14-2014, 05:04 AM
kutlow's Avatar
Quoted: 113 Post(s)
Liked: 44
can this be built using a different driver? Im just saying if the named driver here is not available can you use a lms ultra?
kutlow is offline
post #732 of 796 Old 01-14-2014, 06:03 AM
cookieattk's Avatar
Quoted: 111 Post(s)
Liked: 89
you can use a uxl-18
cookieattk is offline
post #733 of 796 Old 01-14-2014, 07:35 AM
Swolephile's Avatar
Quoted: 896 Post(s)
Liked: 352
Swolephile is offline
post #734 of 796 Old 01-14-2014, 09:52 AM
jpmst3's Avatar
Quoted: 97 Post(s)
Liked: 233
See if you can score one of the UXLs from the group buy that someone may not need/want.
Joe = LFE Addict
Joe's LOWARHORN build
jpmst3 is offline
post #735 of 796 Old 01-14-2014, 02:46 PM
dsl1's Avatar
Quoted: 91 Post(s)
Liked: 207
Think he is asking about the Palehorn and if you can use another driver. Guessing the answer is no.
________________________________________
For Sale: SKHorn Enclosure
SKHorn Build - Gjallarhorn Build SOLD - Othorn Build SOLD - SEOS 12 Build - Other Gear: Jim Holtz Statements - Emotiva Amps - Samsung KS8000 65" tv - BenQ W7000 projector
dsl1 is offline
post #736 of 796 Old 01-14-2014, 05:39 PM
LTD02's Avatar
Liked: 2583
"can this be built using a different driver? Im just saying if the named driver here is not available can you use a lms ultra?"
did you ever solve your mid-bass problem?
LTD02 is offline
post #737 of 796 Old 01-22-2014, 03:22 PM
wormraper's Avatar
Quoted: 314 Post(s)
Liked: 157
ok, I have a disease... I have 2 marty subs right now, and they are solid... my only problem is this... I haven't built something for too long and I want to go nuts.... am thinking of just adding 2 more marty subs, but also wondering what a Gjallahorn will do in my room... my main room is 22x12 and it opens up into a kitchen, another 8x22 room and the back hallway (it's a southwest ranch style home so everything is open floor plans with no doors for those areas... since the Gjallahorn does great for open spaces where room gain is minimal I was wondering if one of those would do the trick.... or maybe a second one biggrin.gif
since I haven't read EVERY post... can you power one off of an Inuke 6000 or IPR2 7500 channel? or would I need an LG clone...
wormraper is online now
post #738 of 796 Old 01-22-2014, 03:42 PM
blah450's Avatar
Quoted: 138 Post(s)
Liked: 169
worm...would the Gjallerhorn mix okay with the 2 Martys? I did not know if you were planning on running all at same time.
Also, would your mains do okay crossing at 60-70 to match with the FR of the Gjallerhorn?
Also...I believe you don't need a lot of power for a driver in the Gjallerhorn...you should be able to rock it with one channel of either.
blah450 is offline
post #739 of 796 Old 01-22-2014, 04:13 PM
wormraper's Avatar
Quoted: 314 Post(s)
Liked: 157
I would replace the martys... use them as coffee tables in my beddroom setup biggrin.gif
yeah, I have the Cheap thrills SEOS and those go down to 65 hz easy peasy
post #740 of 796 Old 01-22-2014, 08:03 PM
N8DOGG's Avatar
Quoted: 977 Post(s)
Liked: 1047
I run one of my G-horns off 1 channel of the 7500 and it does an awesome job!! With a minidsp, you could get the martys to play with the G-horns fairly easily. If I can do it with sealed and an IB, you can with ported and the G-horn.
N8DOGG is offline
post #741 of 796 Old 01-22-2014, 08:07 PM
stormwind13's Avatar
Quoted: 60 Post(s)
Liked: 96
It's only really a matter of setting your delays properly. And hoping they aren't out of phase too :-p
stormwind13 is offline
post #742 of 796 Old 01-22-2014, 08:12 PM - Thread Starter
lukeamdman's Avatar
Liked: 1242
post #743 of 796 Old 01-22-2014, 08:33 PM
MD28's Avatar
is the palehorn a new design in the making? im gaining more and more respect for Mr. Ricci. genius!!!
MD28 is offline
post #744 of 796 Old 01-22-2014, 08:35 PM - Thread Starter
lukeamdman's Avatar
Liked: 1242
That is a new design, likely with a 25hz tune and designed for high sensitivity 21" pro-style drivers.
post #745 of 796 Old 01-22-2014, 08:41 PM
MD28's Avatar
sounds like this one is more suited for PA's... live sound?
MD28 is offline
post #746 of 796 Old 01-22-2014, 08:59 PM - Thread Starter
lukeamdman's Avatar
Liked: 1242
Yes, but so was the Othorn, and I wouldn't trade those for anything for 25-150hz sub duty.
post #747 of 796 Old 01-22-2014, 09:06 PM
MD28's Avatar
i just wish the drivers for these Ricci designs weren't so expensive!  imagine death metal never sounded any better through an Othorn. and... the viking names is just icing on the cake. BRUTAL!
MD28 is offline
post #748 of 796 Old 01-22-2014, 09:08 PM - Thread Starter
lukeamdman's Avatar
Liked: 1242
Drums kicks are so powerful they're almost painful. Your eyes squint with each kick even though you know it's coming, and your vision distorts.
post #749 of 796 Old 01-22-2014, 09:12 PM
MD28's Avatar
wow. this i must build. i imagine an othorn wouldnt sound to good with some LS9 line-arrays. with delays and what not. ive always wanted a sub that could produce life-like kick-drum with great authority. is the palehorn designed to be louder or play a little lower?
MD28 is offline
post #750 of 796 Old 01-22-2014, 09:13 PM - Thread Starter
lukeamdman's Avatar
Liked: 1242
Both...but good luck getting your hands on that ZOD mystery driver!
