A trip over to RMK’s place a couple days ago got the wheels turning. Long story short, two JTR Orbit Shifters, which combined is two 18” drivers and 8kw of power, gave my quad 18’s and 16kw of power a run for their money! To be more specific, I feel his setup had greater output above 30hz, and mine had greater output from the mid 20’s on down.
The efficiency of the horn design definitely impressed me, so I started to look around. It didn’t take me long to find the GJALLARGORN on Ricci’s data-bass.com. From his measurements, just one gjallarhorn will outperform all four of my sealed 5400s from 16-40hz-ish, and obviously with far less power.
The plan is two build two of these, and re-use two of the 5400s from one of my sealed cabinets. That means I’ll still have two other sealed 5400s powered by a LG clone, which can help cover the top 60-80hz portion where the gjallarhorn may need some help. The only investment for me is the cost of the wood.
Ricci already emailed me the detailed plans, so all I have to do is find 4x8 sheets of quality Baltic birch and I’ll get started
You can use 5x5 panels too. You may have to change some of the cut sheet layouts but that is sort of what I meant in my last email. If you have questions let me know. i have lots of pictures and cad files.
Awesome idea, tuned in. It is intriguing for sure.
On the face of it, more output is the allure, I get it. Josh's build is epic, period. However, fewer, higher output sources, vs. higher numbers of lesser output sources, doesn't always end up being advantageous when the acoustics of small rooms are involved.
But hell, I'd build it too! Especially having the benefit of the previous build, Josh's knowledge and hindsight.
Have fun and best of luck, this will be one to watch.
Yup, the GJALLARHORN really pulls ahead of the DIY offerings from 16Hz - 50Hz. The XXX ported is the only one to go lower (10-12.5Hz) with greater spl.
Yes, at 10hz, sorry, I was on my phone which seems to auto correct to the wrong text. Quad sealed LMS 5400's will get you 120 dBs at 20hz and the GH will get you 128 dBs. So we have the sealed system doing 120 hz and 107 dBs where the GH will be doing 128 and 96. I don't know but the sealed system will be much flatter lower and still have enough output for any movie. I can tell you I had dual DTS-10's which had 122 at 20hz and 96 at 10hz and now my system has 107 dBs at 10hz and 123 dBs at 20hz. The sealed system absolutely rocks my theater and I ran sine wave testing higher than ever before. Having increased 16-80hz does nothing when you already have 130 dBs capable with the sealed system. You should have run those OS on scenes with known ULF only and then compared the two as you would have had at least 9 dBs more capable output at 10hz. Systems do wow you when they have lots of 20hz and up but imagine having the whole bandwidth at the same levels.
Actually I already went over all of this with Luke. He has 4 sealed LMS already which technically should be enough for anything sane. He knows what he is doing and doesn't really care a whole lot about
Ricci, this thing is an animal. Truly impressive. Will the dual sealed keep up in the upper bass and would the two extra lms's be better as two single sealed co-located? I suppose measurement would better dictate that...
funny you are building a pair of these, i was just contemplating doing a lilwrecker pair or a pair of these. I'll have to drop in once they are done and see how they sound- might influence my decision a bit.
I agree the sealed system is much flatter to 10hz, and the last time I measured I think I could hit 110db at 10hz at the LP. However, even with 110db at 10hz, the tactile feel is virtually non-existent. My room takes a huge bite out of SPL right at 13hz for some reason. See the graph below:
From 15-20hz, the "feel" is best described at violent. Even though my theater is below ground level on a concrete slab, the couch feels like it has bass shakers in it. However, 10-13hz, no audible bass, and only a VERY slight feel. Considering what it took to get that 110db at 10hz, I'd have to double my system to notnyt's level to make 10hz worth anything. Honestly, I don't feel like spending 6k more to get there!
RMK did have the blu-ray test disc, so I was able to hear ULF I had heard dozens of times before on the OS.
Related Threads
AVS Forum
34M posts
1.5M members
Since 1999
