using CHT 18" drivers for LLT type subs. Bad idea? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 23 Old 12-13-2012, 09:36 PM - Thread Starter
zheka's Avatar
Quoted: 29 Post(s)
Liked: 26
I'd like to convert my CHT CS18.2 (dual 18") to two vented subs.
This would be the first time I model/build a subwoofer. I'd like to hear your opinion about the the idea in general and, most importantly, if this kind of project should even be considered by a noob like me.
The drivers are Eminence OEM used in all current Chase Home Theater subs, both sealed and vented.
Their vented one, VS18.1, did well in recent data-bass benchmarks, so it is known that the driver can deliver in a 7-8cu.ft box tuned to 19Hz or so.
I have room for bigger subs behind the screen. they can realistically be up-to 17 cu.ft volume (30x20x50). I am curious if going LLT maybe a better option in my case.
UPDATE: the models below are based on overstated Sd numbers. For models based on more realistic assumptions see http://www.avsforum.com/t/1445228/using-cht-18-drivers-for-llt-type-subs-bad-idea#post_22702909
Here is how 7 cu.ft. @ 19Hz vs 17cu.ft. @ 14Hz tune boxes model with 300W signal. both have HPF just below tuning frequency.
the same boxes and power, no HPF on the LLT version
The specs for the drivers are not listed but they were measured by user LilGator.
Re: 6.963 Ohms
Fs: 21.53 Hz
Qts: 0.324
Qes: 0.355
Qms: 3.707
Le: 3.461 mH
Mms: 369.4 g
Vas: 19.78 Cu Ft
SPL: 93.86 1W/1m
BL: 31.31 N/A
Cms: 0.15 mm/N
Sd: 0.1642 m^2 more likely 0.1140 m^2
from the CHT site:
Xmax: 0.75in (edited. originally had it at 1.5 for peak to peak,did not realize i had to divide it by two)
Pe:800W
what do you guys think?
zheka is offline
post #2 of 23 Old 12-13-2012, 10:18 PM
Brad Horstkotte's Avatar
Liked: 68
I'd think you might get more for your money by selling the CHT sub, and buying drivers, since the complete sub would be worth more than just the drivers (speculating, not sure what the going price might be with CHT's future still up in the air - but regardless, the subs work well).
Brad Horstkotte is offline
post #3 of 23 Old 12-13-2012, 10:37 PM - Thread Starter
zheka's Avatar
Quoted: 29 Post(s)
Liked: 26
you are right. i should be able to buy a pair of well known drivers and somebody would get a great deal on a very solid sub. great advise, thank you.
still, is large vented enclosure a good candidate for first DIY project? or should i stick to sealed?
zheka is offline
post #4 of 23 Old 12-13-2012, 10:47 PM
Bass Enabler
Scott Simonian's Avatar
Quoted: 5283 Post(s)
Liked: 4167
The upcoming Stereo Integrity HT18's coming out work as drop-in replacements if you dare to build my LLT's. (check sig)
Scott Simonian is offline
post #5 of 23 Old 12-13-2012, 11:22 PM - Thread Starter
zheka's Avatar
Quoted: 29 Post(s)
Liked: 26
wow
zheka is offline
post #6 of 23 Old 12-13-2012, 11:28 PM - Thread Starter
zheka's Avatar
Quoted: 29 Post(s)
Liked: 26
the highest i can go is 19cu.ft each (40x50x20)
zheka is offline
post #7 of 23 Old 12-14-2012, 04:19 AM
LTD02's Avatar
Quoted: 2340 Post(s)
Liked: 2575
zheka,
the chase subs works fine in ported. the only thing is to keep an eye on excursion because with the larger and lower tuned subs, you get more excursion above the tuning frequency for a given power level.
the lilgator specs seem about right except for the driver diameter which seems way off. while the chase driver may be different, almost all nominal 18" subs have a much lower effective diameter and in turn much lower sd than lilgator specs.
the dd spec is typically taken to be from approximately the inner 1/3 of the surround side to side, not from the edge of the frame side to side. typical values for an 18" are in the neighborhood of 15"-15.5" providing approximately 1200 cm^2 of radiating area for sd. lilgator has measured about 1600cm^2, which is more like a 21" driver.
edit: also the xmax spec is too high. that is probably a peak to peak number vs. a one way number, so divide that by two.
you will be fine in up to 17 cubic feet tuned to 14hz with up to 1000 watts (maybe even a little more).
Listen. It's All Good.
LTD02 is offline
post #8 of 23 Old 12-14-2012, 08:37 AM - Thread Starter
zheka's Avatar
Quoted: 29 Post(s)
Liked: 26
zheka,
Thank you very much.
I measured the driver per your instructions, Dd is slightly short of 15". This changes Sd to 1140 cu.cm and sensitivity to around 90dB.
it looks like with this specs there is little benefit from going extra large.
to compare, 17 cu.ft vs 8 cu.ft, both tuned to 14Hz with HPF at 12Hz (600W signal)
17 vs 8
excursion at 1000W
excursion at 1000W
in my room (basement, concrete floor and 3 walls, moderate to strong cabin gain), 8cu.ft may be a better choice.
zheka is offline
post #9 of 23 Old 12-14-2012, 02:20 PM
zora's Avatar
Quoted: 48 Post(s)
Liked: 51
Originally Posted by zheka View Post
from the CHT site:
Pe:800W
.75" xmax is 1.5" peak to peak. I've got these drivers and when I had them out of the boxes I ran a few sweep tests and can say that they are definitely not limited to .75" two-way xmax.
JP
zora is offline
post #10 of 23 Old 12-14-2012, 02:28 PM
Assoc. Editor @ AVS Forum
imagic's Avatar
Quoted: 4943 Post(s)
Liked: 8367
You maximum excursion (xmech) could be as much as double the xmax. .75" one-way xmax is nothing to scoff at, 1.5" one-way xmax would be rather exceptional.
JP
Mark Henninger
imagic is offline
post #11 of 23 Old 12-14-2012, 02:46 PM
zora's Avatar
Quoted: 48 Post(s)
Liked: 51
I didn't say that it was 1.5" one-way xmax. If the driver's one-way xmax is .75" then the two-way (peak to peak in different terminology) would have to be 1.5" (2 x .75"). I was simply clarifying the comments that suggested these drivers can't have a 1.5" two-way xmax.
JP
zora is offline
post #12 of 23 Old 12-14-2012, 03:54 PM
Bill Fitzmaurice's Avatar
Liked: 4630
JP
If it's Eminence I doubt it has more than 15mm xmax, and a lot less than that if it's a pro model. It should be obvious which Eminence motor it's using by looking at it.
Bill Fitzmaurice is offline
post #13 of 23 Old 12-14-2012, 05:34 PM - Thread Starter
zheka's Avatar
Quoted: 29 Post(s)
Liked: 26
Here is what Josh Ricci had to say about excursion capabilities of the driver
The xmax of the driver is listed as about 19mm one way with a recommended power rating of about 800 watts. In use the driver would produce this much stroke but the xmech seems to be at almost the same point as the useful excursion and the surround and/or suspension seemed to be the most limiting factor
http://www.data-bass.com/data?page=system&id=83
zheka is offline
post #14 of 23 Old 12-14-2012, 05:59 PM - Thread Starter
zheka's Avatar
Quoted: 29 Post(s)
Liked: 26
here is what Mike P of HTS came up with
Green is 800 watts and a 15 hz HPF. Yellow is 700 watts and a 13 hz HPF.
zheka is offline
post #15 of 23 Old 12-14-2012, 11:13 PM
zora's Avatar
Quoted: 48 Post(s)
Liked: 51
It isn't a pro model. I don't believe that anyone is stating that it is a "super" driver but it is one of the best I've seen from Eminence. It is simply a solid, high value driver.
JP
zora is offline
post #16 of 23 Old 12-14-2012, 11:20 PM
Erich H's Avatar
Quoted: 1406 Post(s)
Liked: 1769
I think what Bill means is that Eminence can not build a woofer with over 15mm X-max. And I believe that was only until recently they could go that high. The woofer may go over that, but it wasn't designed to.
_______________________
The SEOS Waveguide Project
Erich H is offline
post #17 of 23 Old 12-14-2012, 11:54 PM - Thread Starter
zheka's Avatar
Quoted: 29 Post(s)
Liked: 26
excursion chart to go with the SPL one from http://www.avsforum.com/t/1445228/using-cht-18-drivers-for-llt-type-subs-bad-idea#post_22705143
well within the xmax limits.
zheka is offline
post #18 of 23 Old 12-15-2012, 07:00 AM
Liked: 4630
.[/quote]
Not that they can't, just that by and large they don't. I'm not personally aware of any. The LAB 15 is one beefy driver, and it's only 11.8mm.
Green is 800 watts and a 15 hz HPF. Yellow is 700 watts and a 13 hz HPF...well within the xmax limits.
If they're accurate. I didn't see on Data Bass testing above 35 volts; it would take at least 50 volts to reveal non-linearity and THD that might indicate xmax had been reached.
post #19 of 23 Old 12-15-2012, 08:05 AM
LTD02's Avatar
Liked: 2575
the craig sub is ported and tuned to around 19hz.
ricci tested it cea max burst 116db at 2m at 31.5hz.
31.5hz is roughly where the cone motion will be peaking in such a setup.
backing out the cone motion gives roughly 25-26mm required for that spl.
LTD02 is offline
post #20 of 23 Old 12-15-2012, 08:19 AM
Ricci's Avatar
Quoted: 184 Post(s)
Liked: 472
I would just build something equivalent to the vs18.1. And give it 500 w or so. The driver hits xmech near 20mm. The suspension is simply done around that point. It does not take a lot of power to get there and tuning lower in a bigger cab will reduce power handling more at the upper excursion maximum.
Also Lilgators sd spec above is not right it should be about 1200 cm give or take. It is an 8 ohm driver too despite some people saying it is 4 ohm nominal.
Ricci is offline
post #21 of 23 Old 12-15-2012, 08:50 AM - Thread Starter
zheka's Avatar
Quoted: 29 Post(s)
Liked: 26
The models by Mike P. are based on Sd of 1140sq.cm (Dd 15). the wdr file is attached.
I decided against using the CHT drivers. Brad is right, it makes no sense to break perfectly working subwoofer for the drivers that objectively cannot compete with the current budget 18" favorites.
So for me it is Dayton vs SI now.
CHT with reasonable DD.txt 1k .txt file
File Type: txt CHT with reasonable DD.txt (862 Bytes, 20 views)
zheka is offline
post #22 of 23 Old 12-15-2012, 10:50 AM - Thread Starter
zheka's Avatar
Quoted: 29 Post(s)
Liked: 26
I understand Xmax value of the Dayton HO 18" is understated.
What number should I use for modeling? Is 20mm reasonable?
zheka is offline
post #23 of 23 Old 12-15-2012, 11:28 AM
LTD02's Avatar
Liked: 2575
yeah...that's reasonable.
LTD02 is offline
