Scratched subwoofer dust cap - any audible issues to be worried about? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 12-14-2012, 08:03 AM - Thread Starter
John4721's Avatar
Hi all,
I just received a subwoofer driver and the first thing I noticed was that there a couple of mild scratches on the center dust cap. The subwoofer material is quoted as being "Fiber Composite, Poly Coated"; nothing aluminum or otherwise too exotic. No punctures, dents, or tears. I'd say the scratch depth isn't deep, but is more than just an faint surface scratch. Something mild to moderate I guess. The two scratches were less than 1/4" long each, with a scratch width less than a pencil tip's size.
I connected it and it's sounding good. In terms of audible, real-world use sound quality or durability, should I be concerned? I'm such a worrier sometimes. 8)
John4721 is offline
post #2 of 5 Old 12-14-2012, 08:44 AM
Assoc. Editor @ AVS Forum
imagic's Avatar
Quoted: 4943 Post(s)
Liked: 8366
Unless air leaks through it, it's irrelevant
Mark Henninger
imagic is online now
post #3 of 5 Old 12-14-2012, 11:35 AM - Thread Starter
John4721's Avatar
Sounds good. Thank you.
John4721 is offline
post #4 of 5 Old 12-15-2012, 09:03 AM
vivatech's Avatar
Does the same go for dents in dust caps?
vivatech is offline
post #5 of 5 Old 12-15-2012, 09:08 AM
Bill Fitzmaurice's Avatar
Liked: 4629
Dented dust caps can result in response zits in the midrange. That's not a concern with a sub.
Bill Fitzmaurice is online now
