I am completely confused on what sub amp to buy. - AVS Forum | Home Theater Discussions And Reviews
post #1 of 25 Old 12-15-2012, 12:39 PM - Thread Starter
TenTonBass's Avatar
Quoted: 16 Post(s)
Is there anything on the consumer line that even comes close to the 1500+ watts I need to power my sub that wont require a small personal loan to be taken out?
Do I have to go pro?
TenTonBass is offline
post #2 of 25 Old 12-15-2012, 01:41 PM
Mrkazador's Avatar
Quoted: 252 Post(s)
Liked: 378
The EP4000 is $275 at Walmart.com. You're not going to find ANYTHING close to that when it comes to power and price.
Mrkazador is offline
post #3 of 25 Old 12-15-2012, 01:42 PM
bass addict's Avatar
Quoted: 360 Post(s)
Liked: 437
Achievement Unlocked
Psychotic Episode Averted
bass addict is offline
post #4 of 25 Old 12-15-2012, 01:50 PM
LTD02's Avatar
Quoted: 2340 Post(s)
Liked: 2574
there are several stores that have that pricing if walmart goes out of stock.
Listen. It's All Good.
LTD02 is offline
post #5 of 25 Old 12-15-2012, 04:43 PM
gw742296's Avatar
Amazon also has the EP4000 for $275 but that includes free shipping and no sales tax.
gw742296 is offline
post #6 of 25 Old 12-15-2012, 05:11 PM
LTD02's Avatar
Liked: 2574
the closest thing that i can think of that is a non pro amp is the dayton:
http://www.parts-express.com/pe/showdetl.cfm?partnumber=300-811
LTD02 is offline
post #7 of 25 Old 12-15-2012, 09:35 PM
BassThatHz's Avatar
Quoted: 2032 Post(s)
Liked: 1548
What do you consider a small personal loan is worth?
If you want to go a step higher than an EP, the MA-5050 is a sure bet.
http://www.amazon.com/Marathon-MA-5050-PRO-Series-Amplifier/dp/B000V0HVE2
BassThatHz is online now
post #8 of 25 Old 12-15-2012, 11:28 PM - Thread Starter
TenTonBass's Avatar
Quoted: 16 Post(s)
I think I'm going with the Crown XTi 2002.
post #9 of 25 Old 12-15-2012, 11:42 PM
FOH
FOH's Avatar
Quoted: 38 Post(s)
Liked: 234
Emotiva, would be a "hifi" style amp that is afordable, and adept at sub duty.
Active 16.8kw, 7.3 system
(2)Seaton SubM-HP, (4)18" IB
FOH is offline
post #10 of 25 Old 12-16-2012, 08:04 AM
JackNC's Avatar
Quoted: 135 Post(s)
Liked: 37
I have an XTI2000 and it works fine for me first as a sub-amp and now driving my midwoofers. I'm sure you will love the DSP and lack of fan noise until driven hard. However, at the price they are asking for the XTI2002, you can do better with Behringer or Peavey IPR3000 + MiniDSP.
JackNC is offline
post #11 of 25 Old 12-16-2012, 08:34 AM - Thread Starter
TenTonBass's Avatar
Quoted: 16 Post(s)
I've heard Behringer amps run loud and require fan mods. Yes?
post #12 of 25 Old 12-16-2012, 08:58 AM
FOH
FOH's Avatar
Quoted: 38 Post(s)
Liked: 234
Yamaha amps are outstanding, and have next to no fan noise issues.
I'd not reccomend fan modding, ...relocation of the amp, or building a hush box, ... yes.
FOH is offline
post #13 of 25 Old 12-16-2012, 09:09 AM
Assoc. Editor @ AVS Forum
imagic's Avatar
Quoted: 4943 Post(s)
Liked: 8366
The XTi-2002 is my sub amp and it's a champion at that power level. The fan only goes on when needed and shuts off promptly when it isn't. If you're in a bass passage loud enough that it triggers the fan, there's no way you'll ever hear it - so on the whole the XTi-2002 operates silently with the occasional, brief intrusion of a fan that's not too loud.
As for the Behringer fans - they are 12 volt, 80mm fans which means swapping them is as easy as it gets - it takes two minutes and yields a perfect result. It's not merely recommended... it's mandatory if you get an iNuke... and as a bonus you can actually get a fan that has MORE airflow and is quieter at the same time.
That said, I returned my iNuke 6000DSP and traded it for the XTi-2002. Sure I lost 3db of potential power, but I gained a much more bullet-proof amplifier. In brief, informal A/B testing XTi-2002 matched but didn't beat a Behringer EP-4000's maximum output... the EP4000 is a much better bargain on a per-watt basis... but the XTi weighs much less and has DSP.
Mark Henninger
imagic is online now
post #14 of 25 Old 12-16-2012, 09:37 AM
Quoted: 911 Post(s)
Liked: 489
FWIW, I recently wrote a little survey on sub amps.
It might help you, might not. My context is a multisub system, not a single sub.,
But what makes you think you "need" 1.5kW?
"In many cases there aren’t two sides unless one side is 'reality' and the other is 'nonsense.'" - Phil Plait
Serious Audio Blog
DS-21 is offline
post #15 of 25 Old 12-16-2012, 10:05 AM
braveheart123's Avatar
Quoted: 311 Post(s)
Liked: 273
True. just added iNuke 6000DSP last night. The first and the only thing you hear when u start the amp is the fan noise, which is ridiculously loud. But no complaints here coz it is not for home use. I swapped both the fans with Noctua 80mm fans. No more fan noise here. Performance wise, it proved ballsy for me at least.
History is written by those who have hanged heroes ...
Main System: PSB X2T, PSB XC, PSB XB, Cambridge Audio Azur 751R, Rythmik FV15HP, PSB S500
braveheart123 is offline
post #16 of 25 Old 12-16-2012, 10:28 AM
vitaminbass's Avatar
Do the Inuke DSPs provide enough filters to do justice to a folded horn? Would be great to simplify and not need a mini DSP or BFD...
vitaminbass is offline
post #17 of 25 Old 12-16-2012, 12:38 PM
lilmike's Avatar
Quoted: 64 Post(s)
Liked: 160
The current iNuke DSP implementation is great (plenty of filters), but there is nothing available below 20 Hz.
lilmike is offline
post #18 of 25 Old 12-16-2012, 01:22 PM
Mrkazador's Avatar
Quoted: 252 Post(s)
Liked: 378
I placed my EP4000 under a couch, It cuts down on the fan noise a lot. I can BARELY hear the fan at the main listening position.
post #19 of 25 Old 12-16-2012, 02:25 PM
brian6751's Avatar
Quoted: 879 Post(s)
Liked: 674
kinda dusty and hot under there though isnt it?
That's not science! - Cyborg
Steam ID: The Barbeerian
Rivers Edge Theater
brian6751 is offline
post #20 of 25 Old 12-16-2012, 03:10 PM
imagic's Avatar
Liked: 8366
Fan mod = one of the easiest things to do on a Behringer. 100% effective, plenty of tutorials out there, takes 5 minutes. No excuse not to, this is DIY! biggrin.gif
Mark Henninger
post #21 of 25 Old 12-16-2012, 03:11 PM - Thread Starter
TenTonBass's Avatar
Quoted: 16 Post(s)
So using a pro amp for a sub is it suggested I buy some sort of device that increases the output volts from my receiver sub out?
I use a Pioneer Elite SC-25 and I think the output sensitivity is like .35V or something like that? Dont know much about it.
post #22 of 25 Old 12-16-2012, 03:37 PM - Thread Starter
TenTonBass's Avatar
Quoted: 16 Post(s)
post #23 of 25 Old 12-16-2012, 04:03 PM
wth718's Avatar
Quoted: 194 Post(s)
Liked: 311
I have one of those alongside my EP2500 (EP4000s are basically rebadged 2500s). In a pinch, the BK can work, but I use mine just for my Buttkickers. Bad SN ratio, response falls off well before the EPs. It's great for it's intended use and runs cool and silent. But the EP is a much better option for sub use.
wth718 is offline
post #24 of 25 Old 12-16-2012, 04:39 PM - Thread Starter
TenTonBass's Avatar
Quoted: 16 Post(s)
Yeah I'm gonna go with an EP4000. What fan did you guys end up using for the swap?
post #25 of 25 Old 12-16-2012, 06:05 PM
Mrkazador's Avatar
Quoted: 252 Post(s)
Liked: 378
The couches have tall feet and the outtake of the amp is on the edge so the hot air doesn't stay under. I have not seen much dust on the amp since I've been using it, I guess YMMV!
