How hard is it to build your own speakers? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 15 Old 12-19-2012, 02:24 PM - Thread Starter
TenTonBass's Avatar
Quoted: 31 Post(s)
I'm going to be building my own sub next week and I'm pretty comfortable as it seems most are here in carrying out that task.
I was wondering what all goes into building your own full range speakers? I am considering going this route but really have no idea where to even start.
Some basic questions I have are where can I find quality tweeters and drivers to buy?
What is up with the crossovers in full range speakers? Are they mandatory? Do they come with the speakers?
Are there any good sites that lay out the basics?
Thanks for any help guys!
TenTonBass is offline
post #2 of 15 Old 12-19-2012, 03:22 PM
tuxedocivic's Avatar
Quoted: 2199 Post(s)
Liked: 2066
By full range, do you mean single driver, or full range multi way?
Building a speaker can be just about as easy as a sub, or as complex as a NASA science experiment. Diysoundgroup has various kits at various prices, but you'll still have to solder a cross over. That's usually the trickiest part for someone asking this type of question. Doable though if you can follow directions.
If you don't need a kit, you still need to find a design that suits your needs. And you'll be a little more on your own.
You can design your own, but be prepared for about 5 years of learning and experimenting before you try.
My youtube channel: Impulse Audio
tuxedocivic is online now
post #3 of 15 Old 12-19-2012, 03:25 PM
antisuck's Avatar
Quoted: 114 Post(s)
Liked: 160
antisuck is offline
post #4 of 15 Old 12-19-2012, 06:13 PM
Ivan Beaver's Avatar
Quoted: 16 Post(s)
Liked: 59
You are really talking about 2 completely different things here.
There are people who can design a good speaker-but lack the tools or skills to build a quality cabinet.
Then there are the people who can build a quality cabinet-but have no idea what goes into a design-there is A LOT.
Then there are people who have done a lot of experimenting over the years and combine that with gained knowledge and skills learned building other cabinets-and they end up with a quality product
Building a speaker and have it make sound is one thing. Having make a GOOD sound is a whole different story.
It is multiple skill sets.
Danley Sound Labs
Physics-not fads
Ivan Beaver is offline
post #5 of 15 Old 12-19-2012, 06:55 PM
Bill Fitzmaurice's Avatar
Liked: 5687
http://techtalk.parts-express.com/showthread.php?219617-The-Speaker-Building-Bible
Bill Fitzmaurice is offline
post #6 of 15 Old 12-24-2012, 08:10 AM
snaker's Avatar
Your Speaker building supply needs:
http://www.parts-express.com/
Cabinets building:
MDF
PL Premium for glue
Screws
Jig saw
hole cutter
clamps - lots of clamps
table saw
EXCEL Spreadsheet
SOFTWARE for cabinet displacement and crossover design.
Do your homework and build what you want. Thats what I did and have been blown away by the results.
Know what Ohm your going to run the speakers in - check your amp.
Learn about small vs large and how you want to setup your system. - learn speaker configuration and benefits/drawbacks.
Crossover's are a pain to learn.
Thats just a few things off the top of my head. FYI - I spent 2 years planning and learning. I reached out to many companies to understand small vs large and speaker configuration. Then I incorporated all this information and designed my own cabinets based off end-goal and sub performance.
snaker is offline
post #7 of 15 Old 12-24-2012, 01:47 PM
mantha3's Avatar
Google "Troels Gravsen"
His Classic 3 way with SEAS drivers is excellent.
Or... 4PI by Wayne Parham
mantha3 is offline
post #8 of 15 Old 12-24-2012, 03:18 PM
Mike Garrett's Avatar
Quoted: 7060 Post(s)
Liked: 4768
If you are building sub/subs, why do you want to build full range mains?
mjgarrett100@gmail.com
Mike Garrett is online now
post #9 of 15 Old 12-25-2012, 05:56 AM - Thread Starter
TenTonBass's Avatar
Quoted: 31 Post(s)
I guess they wouldnt have to be full range. Monitors for the mains would be fine. But I would like a huge center channel with at least 4 mid/bass drivers and tweeter.
post #10 of 15 Old 12-25-2012, 06:04 AM
Looneybomber's Avatar
A center something like this?
YID DIY
Looneybomber is offline
post #11 of 15 Old 12-25-2012, 07:21 AM
vitaminbass's Avatar
MDF can "technically" be a better material for cabinets but I do not suggest using this material unless you are working outdoors or have access to very good dust (and fume) collecting equipment. I hated it. Good quality plywood is much more enjoyable to work with and healthier.
Table saws are great but you can do a lot with a cheap circular saw and a clamp-on guide, or even just a straight board and clamps.
A router is great for cutting circles and I've even used mine (with a guide board) to trim or straighten cuts i've made with other tools. But you can get buy with a jigsaw, too.
safety: you will need earplugs, safety glasses, and a plan to minimize the amount of dust breathed. Warm weather and climates are great for woodwork because you can let the breeze carry away the worst of the dust.
read read read....about others' project builds, many times folks will discuss their successes as well as what they did wrong or mistakes made
Have you considered building a sonotube subwoofer (not sure what you had in mind) these are super easy if you can cut circles...since normally there is no bracing required.
vitaminbass is offline
post #12 of 15 Old 12-25-2012, 11:53 AM
Jay1's Avatar
Quoted: 236 Post(s)
Liked: 221
Sounds like an LCR consisting of the following SEOS designs would be a good place to start
http://www.diysoundgroup.com/forum/index.php?topic=11.0
http://www.diysoundgroup.com/forum/index.php?topic=10.0
They also come available in convenient flat pack kits
http://www.diysoundgroup.com/waveguide-speaker-kits/seos-dayton-ds4-kit.html
http://www.diysoundgroup.com/waveguide-speaker-kits/seos-designer12-kit.html
Jay1 is offline
post #13 of 15 Old 12-25-2012, 11:55 AM
Mrkazador's Avatar
Quoted: 264 Post(s)
Liked: 390
Why?
For home theater you really can't beat these kits
http://www.diysoundgroup.com/waveguide-speaker-kits.html
Mrkazador is offline
post #14 of 15 Old 12-25-2012, 11:57 AM
Perry R's Avatar
Liked: 26
I have built quite a few speakers in the last few years, but as kits sent out by reputable designers.
My way of thinking is that these guys have spent their lives on a passion....design.
Why not take advantage of their expertise and time spent, usually many years.
In my mind this is the best of both worlds...their time, my woodworking
and a product produced for....sometimes...many thousands less than retail.
For the price of a good pair of bookshelves you can build killer floorstanders.
Or a whole HT system that is amazing, for the cost of a average one.
Perry R is offline
post #15 of 15 Old 12-25-2012, 03:29 PM - Thread Starter
TenTonBass's Avatar
Quoted: 31 Post(s)
^^ I concur
