Help with Room Treatment (with DIY mentality) - Page 2 - AVS Forum | Home Theater Discussions And Reviews
post #31 of 40 Old 03-30-2013, 06:28 PM - Thread Starter
tuxedocivic's Avatar
Quoted: 1912 Post(s)
Liked: 1733
Yup
Ryan
tuxedocivic is offline
post #32 of 40 Old 03-30-2013, 07:40 PM
Bill Fitzmaurice's Avatar
Liked: 4706
That looks to be a lot higher Q than .65, but not knowing the driver or alignment I can't render an opinion.
Bill Fitzmaurice is online now
post #33 of 40 Old 03-30-2013, 07:47 PM - Thread Starter
Liked: 1733
CSS trio 12 sealed in 75L. Can't remember of it was 75L but pretty sure. Well stuffed to.
Doesn't really matter. Actually kind of nice knowing I can put more LT onto the low end than I was planning. Thanks for taking a look though. Maybe I modelled wrong...
Ryan
post #34 of 40 Old 03-30-2013, 08:26 PM
Liked: 4706
If the specs are accurate 60L net gives a Q of .7, with no hump. I suspect stuffing the cab over damped it. F3 looks right, response above 70Hz doesn't, and over damping can kill the midbass.
post #35 of 40 Old 03-30-2013, 08:40 PM - Thread Starter
Liked: 1733
You think I over stuffed it? I suppose that could be it.
How about the steep roll off though? Much steeper than 12db/oct.
Ryan
post #36 of 40 Old 03-30-2013, 08:59 PM - Thread Starter
Liked: 1733
Impedance matches the model ok. A little higher impedance actually smile.gif
Ryan
post #37 of 40 Old 03-31-2013, 06:29 AM
Liked: 4706
You only stuff when you want to lower Q. If Q is already low enough you just line the cab. The rolloff from 40 to 20 looks fine. Below that I'd question the accuracy of the testing hardware.
post #38 of 40 Old 03-31-2013, 08:38 AM - Thread Starter
Liked: 1733
Hmm, you're right about 40 to 20. The mic is an ECM8000 calibrated by cross spectrum to their highest standards. I suppose it could be the Dayton T amp I used. Convenient for outdoor work. I'll try a near field indoors with a higher end setup when I have a chance and see if that's a problem. Thanks!
Ryan
post #39 of 40 Old 03-31-2013, 08:41 AM - Thread Starter
Liked: 1733
There was visible excursion way down at least at 5hz. 2hz starting frequency though.
Ryan
post #40 of 40 Old 03-31-2013, 10:21 AM
Liked: 4706
I have my HolmImpulse calibrated with the power amp in the loop. It's a simple affair, you just have to be sure the power amp is set at unity gain so it doesn't toast the sound card input.
