Should bracing be screwed down in a sub enclosure? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 12-22-2012, 07:57 AM - Thread Starter
TenTonBass's Avatar
Quoted: 16 Post(s)
When installing bracing into a subwoofer box do you want to screw and glue the bracing or just glue it?
TenTonBass is offline
post #2 of 3 Old 12-22-2012, 08:01 AM
brian6751's Avatar
Quoted: 879 Post(s)
Liked: 673
Just glue is fine. Screws are usually just to hold stuff in place till the glue dries. If you can clamp it you don't need screws
That's not science! - Cyborg
Steam ID: The Barbeerian
Rivers Edge Theater
brian6751 is offline
post #3 of 3 Old 12-22-2012, 05:19 PM
vitaminbass's Avatar
if you have an air/brad nailer that can come in handy, nailer in one hand and brace (with gule applied) in the other. Much easier to get things held in place and then from there you can clamp and/or screw.
vitaminbass is offline
