please help to identify these speakers - AVS Forum | Home Theater Discussions And Reviews
post #1 of 9 Old 12-26-2012, 09:00 PM - Thread Starter
zheka's Avatar
Quoted: 29 Post(s)
Liked: 26
Looks like a Heresy clone. but it's ported and has lpads for the tweeter and the mid range
I can have this pair for $175. worth the gamble?
zheka is offline
post #2 of 9 Old 12-26-2012, 09:03 PM
Splicer010's Avatar
Liked: 39
Almost looks like Realistic to me. Where are the grills? I wouldn't spend that much on old, used speakers like this tho. I mean they have spring clip wire connections...
Splicer010 is offline
post #3 of 9 Old 12-26-2012, 09:36 PM
Bill Fitzmaurice's Avatar
Liked: 4631
Close, but no cigar. The tweeters have a T35 look, but I'm pretty sure they're not T35s, and the midrange horn isn't an 8HD. The port is no more than half the diameter it should be, making the entire design suspect.
Bill Fitzmaurice is online now
post #4 of 9 Old 12-26-2012, 09:49 PM - Thread Starter
zheka's Avatar
Quoted: 29 Post(s)
Liked: 26
And the spacing between drivers is much wider than on the originals. which probably means that none of the tested crossovers cold be used unmodified.
no cigar it is.
thank you,Bill.
zheka is offline
post #5 of 9 Old 12-26-2012, 10:11 PM
Colm's Avatar
Liked: 94
Depends on what $175 means to you. I wouldn't do it. $175 would be a good price for Heresys or equivalents. But they aren't Heresys or anything equivalent. Looks to me like they have $2 piezo tweeters, but it is hard to tell much from your photos. They definitely aren't T-35s. The squawer looks even more suspect. If you want Heresys, buy Heresys.
zheka likes this.
Colm is offline
post #6 of 9 Old 12-27-2012, 12:20 AM - Thread Starter
zheka's Avatar
Quoted: 29 Post(s)
Liked: 26
that's the lesson
zheka is offline
post #7 of 9 Old 12-27-2012, 04:51 AM
mobeer4don's Avatar
Quoted: 122 Post(s)
Liked: 115
Might consider making an offer on the cabs if you like them and then start over.
mobeer4don is offline
post #8 of 9 Old 12-27-2012, 07:31 AM
Liked: 4631
That's moot in any event. Driver spacing wasn't considered back in PK's day, and for that matter the 8HD and T35 were both diffraction horns that should have been vertically aligned.
post #9 of 9 Old 12-27-2012, 08:14 PM
Colm's Avatar
Liked: 94
Heresy didn't used 8HD, but another EV design PWK picked up out of a waste basket IIRC. He knew how diffraction horns are normally mounted. But I think in the Heresy's case he would have said "it doesn't make a dime's worth of difference."
Colm is offline
