High output, multiple driver DIY main recommendations? - Page 10 - AVS Forum | Home Theater Discussions And Reviews
post #271 of 538 Old 01-25-2013, 06:13 AM - Thread Starter
Gorilla83's Avatar
Quoted: 370 Post(s)
Liked: 513
Originally Posted by ack_bk View Post
So close you can taste it....
Haha, nice! Should be lining the boxes and installing drivers tomorrow sometime. biggrin.gif
Originally Posted by Martycool007 View Post
illa- what screw sizes, or bolts, and attachment techniques are you using for attaching the waveguides and woofers?
Funny you should ask this now as I'm actually making a run at lunch to woodcraft to pick up the hardware. Here is what's on my shopping list - since I was one of the first to pick up this kit, Erich didn't quite have all the hardware ready:
B&C Speakers - #10 x 1.5" black oxide pan head wood screws (8 each required)
Waveguide - #8 x 1.25" black oxide wood screws (4 each required)
Compression driver to wave guide M6 x 16mm with lock washer (2 each required) - already have these and fit great
Oh, I also picked up some gasket tape from PE to use behind the woofs and waveguides. I'm using the 1/8" thick, 0.5" wide speaker gasket tape for both.
Gorilla83 is online now
post #272 of 538 Old 01-25-2013, 06:51 AM
Sibuna's Avatar
Quoted: 373 Post(s)
Liked: 429
do you have the screw count backwards? i would guess the 15in B&C takes 8 screws and the waveguide 4. mine only have 4 holes
Sibuna is offline
post #273 of 538 Old 01-25-2013, 07:01 AM - Thread Starter
Gorilla83's Avatar
Quoted: 370 Post(s)
Liked: 513
post #274 of 538 Old 01-25-2013, 11:07 AM - Thread Starter
Gorilla83's Avatar
Quoted: 370 Post(s)
Liked: 513
Just got back from Woodcraft. Man, I love that place. It's a good thing I had to get back to work or I would have spent a LOT more money. Next I think I've talked myself into doing one of the DIY dust deputy separators. Pretty cool IMO.
I picked up an assortment of black oxide wood screws from #6 to #10 to have 'in stock' for this build and future builds. They have some really nice hardware there, although it's a bit more expensive than your local HD or lowes stuff.
Now that these speakers are basically constructed, I'm going to build some proper stands for them. The stands will essentially be an extension of the actual cabinets. I have the cutlist ready but have to find some time to go pick up the wood. I will NOT be using MDF again though.
post #275 of 538 Old 01-25-2013, 11:59 AM
Erich H's Avatar
Quoted: 1406 Post(s)
Liked: 1771
The one thing I couldn't find was the #10 black pan head screws for the kits. The #8's that I had were likely too small. Well, they would work okay, but some might want beefier screws.
I'll head to Woodcraft this weekend and see what they have so I can include the bigger screws with the kits.
Gorilla, how much were those larger screws?
_______________________
The SEOS Waveguide Project
Erich H is offline
post #276 of 538 Old 01-25-2013, 12:08 PM - Thread Starter
Gorilla83's Avatar
Quoted: 370 Post(s)
Liked: 513
The larger size black wood screws they have are a 'round washer' type screw in square drive. I didn't see any traditional pan head screws anywhere, they seem to stock these type instead which was fine with me anyway since they accomplish the same thing. In the #10 x 1.5" black oxide they were quite pricey at 9.25 for a pack of 100. Then again a pack of 100 goes a long way 100/8 = 12 kits. biggrin.gif I can confirm fitment when I get home today.
Edit - the 10 x 1 1/4" are only 6.89 for 100:
http://www.woodcraft.com/product/2080396/28937/10-x-114-highpoint-round-washer-head-screws-black-oxide-100piece.aspx
post #277 of 538 Old 01-25-2013, 12:11 PM
mrfattbill's Avatar
Quoted: 91 Post(s)
Liked: 89
Up until this past weekend I have NEVER been in a Woodcraft store, I was a bit overwhelmed, lol. I would assume you have checked out Hillman for fasteners already?
Bill
mrfattbill is offline
post #278 of 538 Old 01-25-2013, 12:53 PM - Thread Starter
Gorilla83's Avatar
Quoted: 370 Post(s)
Liked: 513
Bill
It's funny almost everywhere I checked had some type of black #8 screw, but the #10's seem a bit harder to find. Up until now I've just been spraying my zinc #10s black, but they seem to chip rather easily while installing.
I agree there is a lot going on inside a woodcraft store. Fortunately, most of the sections are well labeled so you can find what you're looking for rather quickly. The downside is there is so much cool stuff it's easy to get distracted. biggrin.gif
post #279 of 538 Old 01-25-2013, 12:59 PM
Erich H's Avatar
Liked: 1771
Bill
I haven't checked out Hillman because I didn't know you could actually stop in and buy direct from them. Maybe I'll check that out.
Gorilla, I'm not so sure those screws will be good because of the square drive head. Some might not have that bit laying around.
Erich H is offline
post #280 of 538 Old 01-25-2013, 01:05 PM
mrfattbill's Avatar
Quoted: 91 Post(s)
Liked: 89
Wife was eyeballing a giant piece of hardwood for a mantel, I was eyeballing everything else wink.gif
Not sure if you actually can to be honest, their name just popped into my head.
Bill
post #281 of 538 Old 01-25-2013, 01:06 PM - Thread Starter
Gorilla83's Avatar
Quoted: 370 Post(s)
Liked: 513
I agree, the square head is probably not common enough for most guys to use, but apparently it is superior in terms of slip protection.
Other options:
http://www.mcfeelys.com/product/1014-WRK/10-x-1-12-Wood-Screws-Black-Oxide-Round-Washer-Head-Combo-Drive
post #282 of 538 Old 01-25-2013, 05:05 PM
Erich H's Avatar
Liked: 1771
Do you think the washer head on the #10 might be too big to fit most woofers?
Erich H is offline
post #283 of 538 Old 01-25-2013, 06:58 PM - Thread Starter
Gorilla83's Avatar
Quoted: 370 Post(s)
Liked: 513
Confirmed #10 with the washer head does NOT fit, haha.
Looks like #8 with washer it is!
2 coats of Duratex, done. Also busted out crossover #3 while the first coat was drying. Waiting to try and watching some TV with the wife now. cool.gif
post #284 of 538 Old 01-25-2013, 08:46 PM
ChopShop1's Avatar
Quoted: 293 Post(s)
Liked: 289
Dude, you're blowing my doors in on these!! Can't wait to hear what you think.
ChopShop1 is offline
post #285 of 538 Old 01-25-2013, 10:15 PM
mtg90's Avatar
Quoted: 413 Post(s)
Liked: 785
mtg90 is offline
post #286 of 538 Old 01-26-2013, 07:27 AM
ChopShop1's Avatar
Quoted: 293 Post(s)
Liked: 289
Originally Posted by mtg90 View Post
I keep getting this feeling, based on yours and Erich's response to the never ending questions from Andrew and I about upgrades, that once we power these up and get a good listen they will be amazing.
post #287 of 538 Old 01-26-2013, 09:51 AM
Sibuna's Avatar
Quoted: 373 Post(s)
Liked: 429
looking good dude. My flatpacks for the Fusion 10s should be here mon/tues. i was hoping they woudl be here today. Next week is gonna be crazy. I should be able to get all the cabs assembled during the week and then do some of the finishing on the weekend. im out of town the week of the 4th for work. which is gonna suck. because all i want to do is build speakers
Sibuna is offline
post #288 of 538 Old 01-26-2013, 10:56 AM - Thread Starter
Gorilla83's Avatar
Quoted: 370 Post(s)
Liked: 513
Thanks guys. I spent all morning 7-12 getting them finished up. I still had a bit more work than I thought. smile.gif But they are DONE! I only have about 10 minutes before we leave for the auto show but I did get to listen to a few tracks in 2 channel. No EQ/distance settings/Audyssey yet but they sound AWESOME!! Midbass is better than a lot of the 'smaller' subs that I had in my room. Clarity is top notch as well as imagine. Can't wait to give them a thorough listen and calibration later tonight. I took a LOT of pics which I will upload the rest later.
MANY more comments coming as well as pictures - stay tuned.
post #289 of 538 Old 01-26-2013, 10:56 AM - Thread Starter
Gorilla83's Avatar
Quoted: 370 Post(s)
Liked: 513
post #290 of 538 Old 01-26-2013, 10:59 AM
SeaNile's Avatar
Quoted: 380 Post(s)
Liked: 136
Andrew, they look awesome!! Can't wait to hear them.
SeaNile is offline
post #291 of 538 Old 01-26-2013, 11:42 AM
Erich H's Avatar
Liked: 1771
Wow, you did a great job on those!
Later I'm going to set up a photo gallery so we can put all these finished pictures in one place. So take some nice photos!!
The gloss SEOS looks really nice with that woofer.
Erich H is offline
post #292 of 538 Old 01-26-2013, 01:12 PM
ack_bk's Avatar
Quoted: 548 Post(s)
Liked: 631
They really did turn out nice. The SHO-10 looks like a toy next to them....
ack_bk is offline
post #293 of 538 Old 01-26-2013, 01:17 PM
popalock's Avatar
Quoted: 1232 Post(s)
Liked: 1712
Phenomenal man!
Can't wait to get your impressions after you throw some power at these beasts.
popalock is offline
post #294 of 538 Old 01-26-2013, 01:40 PM
ChopShop1's Avatar
Quoted: 293 Post(s)
Liked: 289
Fantastic!! glad to hear the initial impression, can't wait to hear more. You really did a great job on them man!
post #295 of 538 Old 01-26-2013, 02:02 PM
louisdamani's Avatar
Nice looking speakers! I don't think I've seen many gloss SEOS.
louisdamani is offline
post #296 of 538 Old 01-26-2013, 03:46 PM
ehoeft's Avatar
Liked: 26
Anxiously awaiting.....
ehoeft is offline
post #297 of 538 Old 01-26-2013, 04:49 PM - Thread Starter
Gorilla83's Avatar
Quoted: 370 Post(s)
Liked: 513
Thanks John! Stop over tomorrow or sometime this week to give them a listen. biggrin.gif
Thanks Erich! I'm got to get a decent camera over here to take something respectable. Thanks for the reccomendation on the gloss waveguide, they look incredible.
Phenomenal man!
Thank you sir. I have the EP4000 on them now and they take EVERYTHNG the amp can throw at them. I had them up to +15 (not yet level matched) where the EP4000 taps out (clip lights) and they're screaming away, cleanly!
Thanks Jake! You're going to love these things. I'm hoping to run Audyssey and watch Avengers when we get back from dinner. cool.gif
I don't know if I've seen many on here yet either? Erich reccomended I try it and I think it blends well with the B&C woof and duratex finish.
I'm also anxiously waitin to calibrate them and give them a proper listen too!
Some more pics in the meantime before we head out to dinner -
post #298 of 538 Old 01-26-2013, 04:56 PM - Thread Starter
Gorilla83's Avatar
Quoted: 370 Post(s)
Liked: 513
post #299 of 538 Old 01-26-2013, 05:19 PM
mtg90's Avatar
Quoted: 413 Post(s)
Liked: 785
Yeah man they are awesome indeed!
One quick comment though, if you find the midrange boxy sounding try to throw some more dampening material in there. You could completely fill the top section where the waveguide and CD are mounted up with it, the bracing up there should hold it in place. Here is how the dampening in mine looks BTW:
mtg90 is offline
post #300 of 538 Old 01-26-2013, 05:19 PM
Erich H's Avatar
Liked: 1771
Glad you liked the gloss versus matte. Most people are ordering the matte finish, and they look okay with most of the woofers. But the gloss looks great, especially with that B&C. As PassingInterest said......'Gloss is Boss'.
Take it easy on that amp! biggrin.gif I'm not sure if amp clipping can cause speaker issues or not, but I think so. I can't recall what kind of power MTG-90 recommended for these.
You might also try toeing those in a bit more and see how they do.
Looking forward to any nice pictures you can get. I'll also be putting a link to each build on the speaker's page so others can follow the builds.
Erich H is offline
Amazon Com
