Appleply + Tempest-X New Sub Build - Page 2 - AVS Forum | Home Theater Discussions And Reviews
post #31 of 35 Old 01-20-2013, 11:06 AM - Thread Starter
fperra's Avatar
Quoted: 50 Post(s)
Liked: 71
Well, construction is finally complete. This is the first time I have used Duratex and I must say, it is a great paint. You can't go wrong with it and it is very forgiving and goes a long long way. I put 4 coats on my cabs and I still have about 1/3 of a gallon left.
Here are some pictures:
Ready for the trip to the house.
fperra is offline
post #32 of 35 Old 01-20-2013, 02:23 PM
LTD02's Avatar
Quoted: 2341 Post(s)
Liked: 2577
nice work, particularly the grill.
Listen. It's All Good.
LTD02 is offline
post #33 of 35 Old 01-20-2013, 02:37 PM
brian6751's Avatar
Quoted: 881 Post(s)
Liked: 676
very nice!!
That's not science! - Cyborg
Steam ID: The Barbeerian
Rivers Edge Theater
brian6751 is offline
post #34 of 35 Old 01-21-2013, 06:32 AM
fschris's Avatar
Quoted: 18 Post(s)
i'd love to know how you made your grills. how did you secure to cabinet ? magnets ?
ASROCK H67 GE / HT/Core i3
Emotiva XPA2 Gen2 x2
Carver AV-705 5Channel AMP
Zaph 2.5MM TT'S DIY
Emotiva UMC 200
2 x MFW 15 Clones DIY
fschris is offline
post #35 of 35 Old 01-21-2013, 08:57 AM - Thread Starter
fperra's Avatar
Quoted: 50 Post(s)
Liked: 71
The grills are held to the place with magnets. The case magnets are set into the front baffle and the grill magnets are surface mounted so the grill stands off about 1/8" to prevent any rattle. These are the magnets I used:
http://www.kjmagnetics.com/proddetail.asp?prod=RE22CS-P
They are probably stronger than I needed, but they work. Here is a picture of the back of the grill:
I put squares of Velcro over the magnets to add some cushion so the magnets don't slam together and shatter.
fperra is offline
