NU3000 and EP4000 fan mod notes - Page 2 - AVS Forum | Home Theater Discussions And Reviews
 2Likes
Old 03-11-2013, 12:34 PM
noah katz's Avatar
Quoted: 881 Post(s)
Liked: 304
for a couple bucks more why not get a fan designed to be quiet?
Noah
noah katz is offline
Old 03-11-2013, 01:03 PM
djkest's Avatar
Quoted: 26 Post(s)
Liked: 39
I like the Noctua fans but they are 2-3x more money than a lot of decent fans (like Scythe) and tend to move less air for the same fan speed as the more traditional fan blade designs.
djkest is offline
Old 03-11-2013, 08:39 PM
ratm's Avatar
Quoted: 39 Post(s)
Liked: 39
such as?
ratm is offline
Old 03-13-2013, 04:24 PM
noah katz's Avatar
Quoted: 881 Post(s)
Liked: 304
Originally Posted by ratm View Post
such as?
http://www.newegg.com/Product/Product.aspx?Item=N82E16835226033
Noah
Old 03-13-2013, 05:24 PM
ratm's Avatar
Quoted: 39 Post(s)
Liked: 39
Thank you very much! While quiet, it does spin slower and push less air than others I've looked at. I will rarely, if ever, push my amp to the point of reference (with the Cap) so will that be a big deal?
ratm is offline
Old 03-13-2013, 05:34 PM
ASU
ASU's Avatar
That is a 12 volt fan. The ep4000 has a 24 volt fan in it.
ASU is offline
Old 03-13-2013, 07:30 PM
ratm's Avatar
Quoted: 39 Post(s)
Liked: 39
well then crap. That sucks. Back to the drawing board....
ratm is offline
Old 03-13-2013, 07:49 PM
ASU
ASU's Avatar
Here try this one- http://www.digikey.com/product-detail/en/3110SB-05W-B20-E00/P14751-ND/2615564
ASU is offline
Old 03-13-2013, 08:09 PM
ratm's Avatar
Quoted: 39 Post(s)
Liked: 39
I saw that one, but its back ordered until mid May. This one is available in 2 weeks, should work right?
ratm is offline
Old 03-13-2013, 10:17 PM
ASU
ASU's Avatar
Link doesn't work
ASU is offline
Old 03-14-2013, 05:33 PM
dece870717's Avatar
Just finished my Noctua fan mod for my EPX 4000 and both fans start up no problem with the "ultra low noise" resistor connected, hope this air flow should be adequate , definitely better than nothing! (see http://www.avsforum.com/t/1462687/behringer-epx-4000-fan-replacement-mod-even-necessary)
dece870717 is offline
Old 03-14-2013, 06:47 PM
ratm's Avatar
Quoted: 39 Post(s)
Liked: 39
I hate that hyperlink doesnt work with digi-key
ratm is offline
Old 03-14-2013, 10:00 PM
noah katz's Avatar
Quoted: 881 Post(s)
Liked: 304
Right, not an issue for home use unless you run at club levels.
No biggie.
Put a resistor in series to bring the voltage down.
If you want to tune it, buy 10 with 10X the needed resistance (calculate effective resistance from fan voltage and current or power), and parallel them, adjusting the number you use.
Noah
Old 03-15-2013, 03:38 AM
curtisG's Avatar
Cool trick with the resistors in parallel!
So if I put two, the total resistance is 1/2 of the resistor value
If I put 3, the total is 1/3
Put 4, then it's 1/4
etc..
Pretty neat trick!
Plus doesn't that also help with heat dissipation since the current would be split between each resistors?
curtisG is offline
Old 03-15-2013, 03:45 AM
A9X-308's Avatar
Quoted: 1280 Post(s)
Liked: 951
Yes. P = I^2.R
PS: But you need to keep them separated if dissipating a significant percentage (>1/3) of their rating so they don't heat each other up. A resistor body diameter or more so air can move around them.
A9X-308 is offline
Old 11-27-2013, 10:33 AM
tobcar's Avatar
I think I will try to squeeze in 2 Noctua fans - one at each end of the heatsink of each of my EP4000:s - and connect them in series for 24v.
I think that ought to give me excellent airflow at extremely low noise levels.
Will it fit...
tobcar is offline
Old 03-31-2014, 04:50 AM
Thatsnasty's Avatar
Quoted: 51 Post(s)
Liked: 42
Ressing an old thread for you guys out there with Inukes and ep4000's
This fan quoted above just came back in stock, probably one of the better options for 24v fans for the Ep4000.
I'm ordering one now, and for those with Inukes that take 12volt fans, I found this.
http://www.computers-canada.ca/store/products/1027019339/AFACO-08000-GBA01/Arctic%20Cooling/
It's got one of the highest CFM / DBA i've seen on almost any 80mm fan, and it's only $2.50!
I'm sure you guys in the states can find them just as cheap.
Cheers!
Thatsnasty is offline
Old 04-05-2014, 07:53 PM
curtisG's Avatar
Cheers!
Thanks for the heads up about the fan being back in stock.
Ordered it a few days ago, and it came in today.
Did the swap (took about 15 minutes), and WOW! Night and day difference.
I can barely hear the amp fan now..
Best mod ever IMHO
curtisG is offline
Old 04-05-2014, 08:17 PM
Mrkazador's Avatar
Quoted: 252 Post(s)
Liked: 378
Here is the fan connector and pin for the EP4000 so you don't have to cut the original fan.
http://www.digikey.com/product-search/en?x=0&y=0&lang=en&site=us&KeyWords=455-2266-ND
http://www.digikey.com/product-detail/en/SXH-001T-P0.6/455-1135-1-ND/527370
Boxozaxu likes this.
Mrkazador is offline
Old 04-08-2014, 12:00 AM
Thatsnasty's Avatar
Quoted: 51 Post(s)
Liked: 42
Thanks for the link! a bit late for me though, haha.
I doubt ill be using the stock fan anyways, and if so I can always solder some more wire to it.
Old 11-17-2014, 08:21 PM
Augerhandle's Avatar
Quoted: 747 Post(s)
Liked: 649
According to the manual (http://www.behringer.com/assets/NU60...00DSP_M_EN.pdf), the fan is supposed to be variable speed. I've not heard this mentioned in the forums. Can anyone with a NU3000DSP verify this?
"The wise understand by themselves; fools follow the reports of others"-Tibetan Proverb
_____________________ http://www.scientificamerican.com/article/auger-handle/ ____________________________
Augerhandle is offline
Old 11-17-2014, 10:40 PM
notnyt's Avatar
Quoted: 2156 Post(s)
Liked: 1984
Pretty sure it uses pwm to control the speed, at least in the inukes. I'm running a noctua fan in mine, no issues
notnyt is offline
Old 03-02-2015, 08:20 PM
NODES's Avatar
Quoted: 652 Post(s)
Liked: 271
No need for a PWM fan, it will just run at a constant high speed (depending on your fans specs)
Who needs 4K?... just go see your optometrist.
NODES is offline
Old 04-21-2015, 01:15 PM
Liked: 0
Did the Noctua fan mod with the ultra low noise work in the longtime?
Simp_the_pimP is offline
Old 12-06-2016, 12:56 AM
JonasHansen's Avatar
Quoted: 95 Post(s)
Liked: 42
Originally Posted by maxcooper View Post
So, the Noctua NF-R8 with the "ultra low noise" resistor is another option for the EP4000 fan mod. I bet that it is quieter than the common alternatives, but it probably also flows less air.
-Max
Is this still running with no overheating?
Home Theater: JBL M2 & SUB18 powered by Crown and BSS.
JonasHansen is offline
Old 12-06-2016, 09:07 AM - Thread Starter
maxcooper's Avatar
Quoted: 13 Post(s)
It hasn't been hooked up for years, so I can't really verify. My system changed and I ended up not using it.
-Max
maxcooper is offline
Behringer Nu3000 Inuke Ultra Lightweight High Density 3000 Watt Power Amplifier , Behringer Europower Ep4000 Professional Amplifier
