MDF thickness - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 12-28-2012, 12:16 PM - Thread Starter
hardwired's Avatar
Quoted: 12 Post(s)
I am planning to build a scanspeak 2-way design and the cabinet plans called for 1"MDF. The local Lowes and Home Depot only carry 3/4" max. The lumber outlets also only stock 3/4" MDF or Baltic Birch. One lumber yard had 3/4" Baltic Birch ply in stock for $60 for the standard 5'x5' sheet.
I can order 1" MDF but will take at least a week.
Can I get away with 3/4" MDF? This is for a tower roughly 42"Hx8.5"Wx12"D with bracing.
I have some 1/2" MDF I suppose I could cut and glue to the sides of the 3/4" MDF and make the cabinet slightly taller if its worthwhile.
What do you guys think?
Cost is $33 for 3/4" MDF 4x8 sheet, $50 for 1" MDF 4x8 sheet special order, $60 for 3/4" Baltic Birch 5'x5' sheet.
TI Purepath Digital:
An audio revolution from the source to the ear...found in $99 DVD receivers to audiophile-grade $10,000 audio systems.
hardwired is offline
post #2 of 3 Old 12-28-2012, 12:42 PM
ack_bk's Avatar
Quoted: 548 Post(s)
Liked: 631
You should have no problem with 3/4" MDF. I would just make sure you have a good brace or two and you should be good to go. Lots of subs built with 1/2" plywood and bracing and there are no issues.
ack_bk is offline
post #3 of 3 Old 12-28-2012, 06:30 PM
brian6751's Avatar
Quoted: 878 Post(s)
Liked: 673
If the plans call for 1" I would order the 1". I would also rather wait than double up the 1/2. Just work time wasted IMO.
One more week is nothing. Do it right the first time. You'll be glad you did.
That's not science! - Cyborg
Steam ID: The Barbeerian
Rivers Edge Theater
brian6751 is offline
