Dual opposed vs line array - Page 3 - AVS Forum | Home Theater Discussions And Reviews
post #61 of 67 Old 01-03-2013, 07:49 PM
zheka's Avatar
Quoted: 29 Post(s)
Liked: 26
Originally Posted by Bill Fitzmaurice View Post
No, because of the presence of boundaries. I think the term 'acoustic center' has you a bit confused. What's pertinent in this case is the radiating plane, one that's, say, thirteen inches wide versus thirteen feet wide. One will react quite differently with respect to the radiation pattern than the other, and that matters more than the response curve in this scenario.
this and something you said a few posts back about tall stacks of subwoofer boxes
Where adjacent drivers are within 1/4 wavelength of each other they'll couple to create a single source. Even six drivers would still couple to a single source. If taming room modes was that simple that's how we'd do it.
i guess the lesson is that how the drivers are aligned may also make a difference for in-room FR.
e.g. 8 drives on the same plane would likely sound different than 4 DO boxes stacked in 2 levels.
I would not be surprised if there is measurable difference in frequency response even between single dual opposed and single dual font firing boxes, depending on position.
zheka is offline
post #62 of 67 Old 01-03-2013, 08:51 PM
Bill Fitzmaurice's Avatar
Liked: 4682
Yes, the key being the distance from the respective radiating planes to the sidewalls are so different.
Very little, there not being that much of a difference in the overall form/size factor.
Bill Fitzmaurice is offline
post #63 of 67 Old 01-03-2013, 09:21 PM - Thread Starter
bass addict's Avatar
Quoted: 360 Post(s)
Liked: 437
I found this interesting.
http://www.data-bass.com/data?page=content&id=77
Achievement Unlocked
Psychotic Episode Averted
bass addict is offline
post #64 of 67 Old 01-04-2013, 05:47 AM
Martycool007's Avatar
Quoted: 280 Post(s)
Liked: 176
So basically what happens if you mount all of your subs on the same plane, within one quarter wave length of each other, they will couple to create a summed source? If that is the case, wouldn't you loose the advantages of having multiple subs to smooth out the response? If so, what would anyone do this?
Martycool007 is offline
post #65 of 67 Old 01-04-2013, 06:12 AM
TimVG's Avatar
Headroom
TimVG is offline
post #66 of 67 Old 01-04-2013, 07:11 AM
Liked: 4682
Ask MKtheater. It is a valid approach if you've got a very good room, and if you create a true wall of subs.
post #67 of 67 Old 01-04-2013, 07:33 AM
MKtheater's Avatar
Quoted: 1596 Post(s)
Liked: 1123
It works great! My subs go across 10 feet wide, almost 3 feet high and leaves me about 2.5 feet on each side away from the corners. When I add the T-48's to the bottoms of my DR-250's I will move the subs each in a corner so now triple stacked in each front corner. I will see which is better as response is concerned. I did not even have to EQ that much to be flat, I just added a low shelf for under 20hz.
Marantz 7702 Atmos
MKtheater is online now
