2x EP4000 or iNuke6000DSP? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 16 Old 12-30-2012, 04:04 PM - Thread Starter
brian6751's Avatar
Quoted: 1168 Post(s)
Liked: 1139
i looked for more info on this but could not find it. anyone have advice on which would be better? ill be driving 4 SI 18's. dual 4ohm VC. basically 2 per cab making a 4ohm total load.
one bridged EP4K for each par or run both DO boxes off a single iNuke6000DSP?
Inuke saves me money but im concerned about performance/reliability.
That's not science! - Cyborg
FOR SALE: nothing at the moment
Rivers Edge Theater
brian6751 is online now
post #2 of 16 Old 12-30-2012, 05:09 PM
bass addict's Avatar
Quoted: 441 Post(s)
Liked: 507
Short version; 2 EP4000's running in 4ohm bridged config putting out 950 per driver. Done. smile.gif
Achievement Unlocked
Psychotic Episode Averted
bass addict is offline
post #3 of 16 Old 12-30-2012, 05:17 PM
zheka's Avatar
Quoted: 29 Post(s)
Liked: 26
I am a big fan of the DSP feature in inukes. AFAIK, 2000W @ 4 ohm is realistic number with NU6000 version. I have not heard of any reliability issues .
zheka is offline
post #4 of 16 Old 12-30-2012, 05:33 PM - Thread Starter
brian6751's Avatar
Liked: 1139
hey great. a tie!
the DSP in the iNuke is what interests me as well. i wouldnt need to buy a Minidsp which saves more money. tets of the 3000 seem to compare with the ep4k and the 6000 is just two 3's bridged sooooo. Like i said, im just worried about the quality and ULF performance of the iNuke compared to the EP4K
Rivers Edge Theater
post #5 of 16 Old 12-30-2012, 05:39 PM
zheka's Avatar
Quoted: 29 Post(s)
Liked: 26
Originally Posted by brian6751 View Post
hey great. a tie!
Have you seen this thread?
http://www.diyaudio.com/forums/class-d/213071-behringer-inuke-nu3000-measurements.html
zheka is offline
post #6 of 16 Old 12-30-2012, 05:45 PM - Thread Starter
brian6751's Avatar
Liked: 1139
i didnt see that one, so it looks like the 6000 is the better choice for my application?
Rivers Edge Theater
post #7 of 16 Old 12-30-2012, 05:53 PM
zheka's Avatar
Quoted: 29 Post(s)
Liked: 26
The way I understood it, the amp is fairly flat to 10hz. However continues output with low impendance load at 10Hz is not guaranteed.
zheka is offline
post #8 of 16 Old 12-30-2012, 05:55 PM
lilmike's Avatar
Quoted: 71 Post(s)
Liked: 180
I own (and have measured) a 3000DSP.
It delivers the power I need, but the DSP is not usable below 20 Hz.
Not a bad amp at all, but it would be more useful to me if the DSP software matched the 10 Hz capability of the MiniDSP.
For use as a home-theater sub amp with highpass above 20 Hz? Should work fine. I just need a lower limit on the DSP.
lilmike is offline
post #9 of 16 Old 12-30-2012, 05:58 PM - Thread Starter
brian6751's Avatar
Liked: 1139
hmmm. i dont need a HPF. im wondering if ill miss the <20Hz EQ filters..............
Rivers Edge Theater
post #10 of 16 Old 12-30-2012, 06:12 PM
zheka's Avatar
Quoted: 29 Post(s)
Liked: 26
You can combine HPF and PEQ around 20Hz to simulate sub-20Hz HPF.
I never had to EQ below 20hz. Normally you'd do a shelving filter or LT to shape the signal in the lower octaves, but the filter itself is set above 20Hz.
zheka is offline
post #11 of 16 Old 12-30-2012, 07:03 PM - Thread Starter
brian6751's Avatar
Liked: 1139
I might just go with two ep4k's and a minidsp. Ill have more options, flexibility, redundancy, and proven reliability.
Rivers Edge Theater
post #12 of 16 Old 12-30-2012, 07:08 PM
zheka's Avatar
Quoted: 29 Post(s)
Liked: 26
I remember reading recently about minidsp being limited in output voltage to work well for sub EQ.
zheka is offline
post #13 of 16 Old 12-30-2012, 07:15 PM - Thread Starter
brian6751's Avatar
Liked: 1139
I was reading that as well. Has me concerned. That's the other plus of using the inuke. If there is a input signal issue I can just buy a bump box. Problem solved. But then again, the inuke rolls off at 10Hz. The ep at 5Hz. Argh. So many choices.
Rivers Edge Theater
post #14 of 16 Old 12-30-2012, 07:27 PM
Quoted: 441 Post(s)
Liked: 507
Depends on room, placement, etc. No way to know without trying.
Most newer AVR's put out plenty of voltage to drive pro amps. The mini dsp can be purchased in two different versions which will fit most all installations.
Bottom line is the EP4000's can be had for a song and dance, put out a true 1900+ watts at 4 ohms, and don't roll off signal till well below where room gain occurs. I'd personally go that route.
post #15 of 16 Old 12-30-2012, 08:09 PM
maxcooper's Avatar
I don't have an opinion about which one would be better for your setup, but here's some additional info to consider...
The shallow, super-light NU6000DSP is much easier to lug around, and may also be easier to fit in a rack if you have rack space issues.
The iNuke is also easier to fan mod, and would likely be quieter overall, since you'd only need a single 12v (common) fan.
People are reporting additional discounts at amazon for the iNukes in my fan mod thread:
http://www.avsforum.com/t/1447896/nu3000-and-ep4000-fan-mod-notes
-Max
maxcooper is offline
post #16 of 16 Old 12-30-2012, 08:13 PM - Thread Starter
brian6751's Avatar
Liked: 1139
Thanks Max. The 6000 gets a $75 discount right now. That is another reason I was looking at it.
The weight and noise is not a problem for me. It will technically be on a shelf in another room. Backside of my built in av rack is only open to the adjacent utility room.
Rivers Edge Theater
