Porting speakers to the front or the rear? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 12-30-2012, 05:01 PM - Thread Starter
Point Source
beastaudio's Avatar
Quoted: 3592 Post(s)
Liked: 2896
Just wondering what type of difference this might make? It obviously assumes where in the room you plan to place the speakers, but assuming away from the rear wall about a foot, does it make much of a difference either way?
beastaudio is offline
post #2 of 4 Old 12-30-2012, 05:08 PM
Bill Fitzmaurice's Avatar
Liked: 4896
None. Rear placement is usually employed when it's desirable to keep the cabinet front dimensions as small as possible.
Bill Fitzmaurice is online now
post #3 of 4 Old 12-30-2012, 05:10 PM
antisuck's Avatar
Quoted: 100 Post(s)
Liked: 141
Apparently more than you'd think.
I had the same question in my mind a couple days ago and found this:
http://techtalk.parts-express.com/showthread.php?228020-front-or-rear-port
edit with respect to BFM who apparently clicked the submit button just before I did: The link above has to do with leakage of higher frequencies out the port. I'm sure actual performance of the port does not change.
antisuck is online now
post #4 of 4 Old 12-30-2012, 05:17 PM
Gorilla83's Avatar
Quoted: 375 Post(s)
Liked: 519
Funny enough I've been contemplating the same. I'm very interested in a 15" SEOs build, but the vented baffle is just a couple inches too high to fit under my screen as the center. For this reason I've been thinking of either doing rear port or front slot port.
Gorilla83 is online now
