HSU VTF15 what can I build that compares to it? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 19 Old 01-04-2013, 04:37 PM - Thread Starter
oakleyman's Avatar
Quoted: 17 Post(s)
I am going to sell my HSU VTF15. I have a offer on it and I am going to sell it. I am wanting to see what you guys recommend me building in the $800 price range that will be in my dedicated home theater room. The room is 15ft wide by 24ft long with 7 ft ceilings. double drywall and acoustic panels. Please point me in the right direction for a killer sub.
Thanks for your time and replies
oakleyman is offline
post #2 of 19 Old 01-04-2013, 04:51 PM
brian6751's Avatar
Quoted: 1142 Post(s)
Liked: 1121
Two f-20's or THT's
What size restrictions do you have?
That's not science! - Cyborg
FOR SALE: 120" 16:9 Silver Ticket AT Screen
Rivers Edge Theater
brian6751 is online now
post #3 of 19 Old 01-04-2013, 04:54 PM
J Real's Avatar
Write www.hsuresearch.com a check for a killer $800 sub
J Real is offline
post #4 of 19 Old 01-04-2013, 04:59 PM
cookieattk's Avatar
Quoted: 111 Post(s)
Liked: 91
O_o dumbest thing i have ever seen are u a bot ?
do u want like a sealed or ported do u plan to build boxs your self ?
cookieattk is offline
post #5 of 19 Old 01-04-2013, 04:59 PM - Thread Starter
oakleyman's Avatar
Quoted: 17 Post(s)
Originally Posted by brian6751 View Post
Two f-20's or THT's
I don't have the room for a gigantic box behind the screen. I have about 3.5 behind the screen.
post #6 of 19 Old 01-04-2013, 05:04 PM - Thread Starter
oakleyman's Avatar
Quoted: 17 Post(s)
I can build them myself. What would be best do go with ported or sealed?
post #7 of 19 Old 01-04-2013, 05:08 PM
brian6751's Avatar
Liked: 1121
3.5 inches or feet? I assume you meant inches.
Rivers Edge Theater
post #8 of 19 Old 01-04-2013, 05:08 PM
Mrkazador's Avatar
Quoted: 262 Post(s)
Liked: 390
Give us the largest dimension you can fit behind the screen. Another option is the Tuba HT LP, build two of them.
Mrkazador is offline
post #9 of 19 Old 01-04-2013, 05:13 PM
cookieattk's Avatar
Quoted: 111 Post(s)
Liked: 91
u could do 2 http://www.parts-express.com/pe/showdetl.cfm?partnumber=295-472 + a ep4k for $740 ported or sealed should go about 6-12 db louder.
post #10 of 19 Old 01-04-2013, 05:14 PM
ack_bk's Avatar
Quoted: 604 Post(s)
Liked: 687
I would recommend going with at least dual subs. I have an Hsu VTf-15H and am replacing it with four sealed 15" subs in 3.8 cu ft boxes. It is going to cost me right around $1k for all four. I purchased four 15" Dayton DVC 385-88 drivers when they were $99 each and an iNuke3000dsp to power them.
Here is my thread if you want to get some ideas on ported and sealed subs:
http://www.avsforum.com/t/1440277/acks-diy-subwoofer-build-idea-thread-newbie-alert
You need decide how big a box you can build if you go ported, and you may want to download Winisd Pro and model some subs.
ack_bk is offline
post #11 of 19 Old 01-05-2013, 05:30 AM
Martycool007's Avatar
Quoted: 280 Post(s)
Liked: 181
If I were in your shoes, I would order either 2 Dayton HO18's or 2 Stereo Integrity 18D's, build them in a ported enclosure powered by a single Behringer EP4000. Each Dayton HO18 is $250 so two would come to a total of $500, and in an EP4000 for a tad under $300 and there you will most likely have a hell of a performer! I would bet my life that two of those would most definitely best a single HSU VTF-15.
Martycool007 is offline
post #12 of 19 Old 01-05-2013, 05:47 AM
ack_bk's Avatar
Quoted: 604 Post(s)
Liked: 687
Don't you need some sort of HPF? But yeah, I agree this would be a lot of bang for the buck. That said, by the time you buy wood, and everything else you need you are probably close to $900-1000.
ack_bk is offline
post #13 of 19 Old 01-05-2013, 07:32 AM
brian6751's Avatar
Liked: 1121
Another option within budget. Two Dayton 15's in ported boxes. Behringer iNuke3000dsp amp. That amp has a 20hz. High pass filter.
This 15
http://www.parts-express.com/pe/showdetl.cfm?partnumber=295-469
Or these with less power
http://www.parts-express.com/pe/showdetl.cfm?partnumber=295-190
Rivers Edge Theater
post #14 of 19 Old 01-05-2013, 01:05 PM
randyc1's Avatar
Quoted: 241 Post(s)
Liked: 40
I cant compare to the HSU but i've just built these: (2) 3,6 cu ft Ported with RSS315 HO 44, powered by a SA1000 Amp,.. and they sound awesome in my 22x23 x8 room, Amp is not even at 3/10
randyc1 is offline
post #15 of 19 Old 01-06-2013, 05:20 PM - Thread Starter
oakleyman's Avatar
Quoted: 17 Post(s)
all you guys have great ideas. I want to keep the size of my sub box around the size of the HSU. I don't want to go any bigger. Also I will be building my own 3 front speakers (LCR) behind the screen.
post #16 of 19 Old 01-06-2013, 06:25 PM
jonathanc's Avatar
Liked: 48
LoL seems like this answer is becoming the best answer.
If you have the HSU 15, want something that compares to the HSU 15, and is similar dimensions to the HSU 15, why not just use the HSU 15 ? The reason for DIY subs is either you can build them CHEAP, or you can build a enclosure design that allows for a very efficient sub that a normal vendor wouldn't be able to offer due to shipping size or complexity.
HSU knows how to build a good sub within their design dimensions. You probably won't be able to build something the same size and have it be worlds better. What you could do is build something similar for much cheaper, and build 2 or 4 of them.
jonathanc is offline
post #17 of 19 Old 01-06-2013, 06:40 PM - Thread Starter
oakleyman's Avatar
Quoted: 17 Post(s)
Reason being is that my buddy wants to buy it for $950. I would be very happy with building 2 subs myself.
post #18 of 19 Old 01-06-2013, 06:41 PM
brian6751's Avatar
Liked: 1121
2 Dayton 15's = $240
Inuke 3000dsp = $300 at amazon
That leaves $260 for cabinets etc.
How is that not better than a HSU 15?
Rivers Edge Theater
post #19 of 19 Old 01-06-2013, 08:53 PM
Jay1's Avatar
Quoted: 236 Post(s)
Liked: 221
The HSU is 25 x 18 x 26. Likely a little under 5 ft3 internal. Would a 26 x 21 x 26 box be close enough to the HSU? With a pair of 4" x 25" ports and after the likely bracing you would be right about 6 ft3 with a 20 hz tune (the HSU is 22hz with both ports). A multitude of 15" woofers would work very well in this enclosure.
The NU3000dsp would be your best value, but if you want to keep things super simple you can pick up a pair of 500 watt plate amps for $400
http://www.parts-express.com/pe/showdetl.cfm?partnumber=300-752
The DVC 15" Dayton's are a great value, but you could also go with the RS390HO, or any number of other 15"s
In order to get the long ports to fit inside the cabinet, you would use 4" pvc pipes for the ports, and these elbow fittings
http://www.lowes.com/ProductDisplay?partNumber=23362-1814-PVC+00304++1200&langId=-1&storeId=10151&productId=3132793&catalogId=10051&cmRelshp=req&rel=nofollow&cId=PDIO1
Jay1 is offline
Hsu Vtf 15h Subwoofer
