New to home audio - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 01-06-2013, 04:49 PM - Thread Starter
SKDooley's Avatar
Hello everyone. I'm interested in expanding my audio knowledge and learning more about home audio. I've been big into car audio for over 10 years and know a great deal but am a complete novice when it comes to home audio. I'm interested in putting together a custom home theater set up, made up of seperate highs, mid range/bass and a single, large diameter subwoofer. I'm unsure of any brands to go with, how I would go about breaking these frequencies up nor how I would power each. Any help would be greatly appreciated smile.gif
SKDooley is offline
post #2 of 5 Old 01-06-2013, 05:36 PM
filtor1's Avatar
Quoted: 77 Post(s)
Liked: 78
Welcome SKDooley!
A couple of things you will need to define before any suggestions can be made. What is your budget? What are your goals? Do you have cabinet size restrictions? What size room? Are you starting with an existing AVR? The answers to those will jump start responses.
Chris
filtor1 is offline
post #3 of 5 Old 01-06-2013, 07:31 PM - Thread Starter
SKDooley's Avatar
I'm not sure what kind of budget I would really need to achieve the type of set up I have in mind. I assume it would be a couple thousand depending on what I go with. I understand the theory of how the install can influence output, so I'm shooting for speakers that will perform well, but planning on putting them within ideal, custom cabinets to optomize their performance. I'm assuming most of the money will go into the receiver and amplifiers. Not sure of the exact measurements of my room, but maybe 10 X 20. Average size.
SKDooley is offline
post #4 of 5 Old 01-06-2013, 07:32 PM - Thread Starter
SKDooley's Avatar
Currently I don't have anything so I would be starting from the ground up.
SKDooley is offline
post #5 of 5 Old 01-06-2013, 07:44 PM
Jay1's Avatar
Quoted: 236 Post(s)
Liked: 220
If you're wanting to design your own custom speakers, this is a completely different world from car audio. The crossover is 1000% more important when in a home environment. Some good reading here
http://techtalk.parts-express.com/showthread.php?219617-The-Speaker-Building-Bible
The subwoofer aspect is just as simple as car audio, the goals/type of performance are just different.
Jay1 is offline
