Speaker post for subs- banana or speakon - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 01-06-2013, 06:02 PM - Thread Starter
NathanJ's Avatar
I need to order my speaker posts for my 2 dual opposed SI build and I would like to know what the majority prefers, banana or Speakon?
If speakon, does anyone ever use normal 12 awg speaker wire or just the cable in black jacket that is round?
Nathan
NathanJ is offline
post #2 of 7 Old 01-06-2013, 06:08 PM
brian6751's Avatar
Quoted: 1113 Post(s)
Liked: 1101
Depends on which cables your using. I just use regular speaker wire so I go with these
http://www.parts-express.com/pe/showdetl.cfm?partnumber=091-1245
That's not science! - Cyborg
Steam ID: The Barbeerian
Rivers Edge Theater
brian6751 is offline
post #3 of 7 Old 01-06-2013, 06:35 PM
fperra's Avatar
Quoted: 50 Post(s)
Liked: 71
I've come to love Speakon connectors and since all my amplifiers use them I design my speakers with them. You don't have to worry about them ever being accidently disconnected.
fperra is offline
post #4 of 7 Old 01-07-2013, 05:31 PM
BassThatHz's Avatar
Quoted: 2317 Post(s)
Liked: 2069
I hate banana, it's almost as bad as bare wire with spring terminals. Never again with I use banana (unless I have to).
Spade or Speakon is what I'd recommend.
Speakon is more expensive but is quicker to use and nearly impossible to short out and is much harder (but not impossible) to accidentally disconnect, especially after encasing the bindings in glue.
BassThatHz is offline
post #5 of 7 Old 01-07-2013, 05:41 PM
N8DOGG's Avatar
Quoted: 1105 Post(s)
Liked: 1203
I've used all of them, Speakon would be ther best but I use bananas on all my subs now. I don't need the security of speakons and have never had a banana fall out.
N8DOGG is online now
post #6 of 7 Old 01-07-2013, 07:18 PM
bass addict's Avatar
Quoted: 370 Post(s)
Liked: 446
What are you guys using your subs for that you are having issues with bananas coming loose? Those bad boys must be doing some crazy dancing. smile.gif
Yup and yup.
Achievement Unlocked
Psychotic Episode Averted
bass addict is offline
post #7 of 7 Old 01-07-2013, 07:37 PM
brian6751's Avatar
Liked: 1101
i was thinking the same thing. ill be using bare wire on my new ones.
Rivers Edge Theater
