passive radiator for re xxx 18 d2 sub build - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 01-07-2013, 06:06 AM - Thread Starter
poolgod's Avatar
hi guys..just wondering..has anyone built a HT sub using the re audio xxx 18 d2 sub with prs...and if so what brand was used and in what size enclosure
poolgod is offline
post #2 of 5 Old 01-07-2013, 10:25 AM
Point Source
beastaudio's Avatar
Quoted: 3496 Post(s)
Liked: 2826
Not a lot of PR's around that are going to keep up with the RE's, I haven't tried any before with my two.
beastaudio is offline
post #3 of 5 Old 01-07-2013, 12:34 PM
Bass Enabler
Scott Simonian's Avatar
Quoted: 5282 Post(s)
Liked: 4167
Just use a lot of high excursion 18/21 inch PR's... if you can find any.
Scott Simonian is online now
post #4 of 5 Old 01-08-2013, 10:36 PM
chrapladm's Avatar
Quoted: 823 Post(s)
Liked: 286
chrapladm is online now
post #5 of 5 Old 01-08-2013, 11:11 PM
robertcharles's Avatar
You could use the TC sounds passives. They are fully adjustable but expensive. Only issue is as you add more passives they need to be heavier still so their becomes a point where you run out of the ability to add trhe extra weight needed for the extra passives. I would model the driver using the TC's, but in the end, unless you are just searching for an exotic build, I would go with a ported system and let it rip.
Keep cranking,
Robert
robertcharles is offline
