Cabinet grade pine for cab material? - Page 3 - AVS Forum | Home Theater Discussions And Reviews
post #61 of 83 Old 01-16-2013, 12:41 PM - Thread Starter
bass addict's Avatar
Quoted: 360 Post(s)
Liked: 437
Originally Posted by goonstopher View Post
This may sound nuts but I was rhinking of using 1 3/4 inch butcher block counter top or 2.5 inch solid cherry or walnut slabs ha
Why? I'm all for overkill but that is just a waste.
Originally Posted by beastaudio View Post
I got the 3/4" pine for my last build, had a nice solid void running right through it from side to side. Didn't notice until I had the drivers installed and they were in the theater, then had to damage control repair the holes by using REAL silicone to seal it back up. Now THAT stuff is nasty. wood looked lovely, but was basically crap. Inspect each sheet you get VERY carefully
That is the problem I kept running into, hence just deciding on going with MDF. It will take 2 or 3 of us to move the finished cab into place, but I know it's solid. smile.gif
Achievement Unlocked
Psychotic Episode Averted
bass addict is offline
post #62 of 83 Old 01-16-2013, 12:44 PM
brian6751's Avatar
Quoted: 881 Post(s)
Liked: 676
thats why i like REAL 13 ply Baltic Birch. if there is a void, its the size of a couple pieces of rice and those are rare.
That's not science! - Cyborg
Steam ID: The Barbeerian
Rivers Edge Theater
brian6751 is offline
post #63 of 83 Old 01-16-2013, 12:46 PM - Thread Starter
Quoted: 360 Post(s)
Liked: 437
Agreed. If I had my druthers that is the way I would have leaned, just for the weight savings alone.
post #64 of 83 Old 01-16-2013, 01:38 PM
goonstopher's Avatar
Quoted: 288 Post(s)
Liked: 55
Originally Posted by fperra View Post
Solid hardwood expands and contracts with humidity. You'll probablt end up with a cracked cab.
Really? I've never seen anyone with wood slab tables or butcher block counter have cracks.
I am considering making an entertainment stand with natural casing slabs or butcher block and was going to make them match
goonstopher is offline
post #65 of 83 Old 01-16-2013, 01:40 PM
Quoted: 288 Post(s)
Liked: 55
Here is a great price list on wood:
BB/B - Baltic Birch
Furniture Grade / Interior Grade
(2440mm X 1220mm X 18mm)
8' X 4' X 3/4" (13 Ply)
$76.00 Per Sheet
http://www.eastcoastplywood.com/wholesale-plywood-pricelist.htm
Looks like they might only do wholesale though
post #66 of 83 Old 01-16-2013, 01:55 PM
brian6751's Avatar
Quoted: 881 Post(s)
Liked: 676
My local Lowes special ordered mine for me. Cheapest price I found.
Rivers Edge Theater
post #67 of 83 Old 01-16-2013, 02:04 PM
fperra's Avatar
Quoted: 50 Post(s)
Liked: 71
That's because butcher block counter tops have a free edge and they can expand and contract without restrictions.
fperra is offline
post #68 of 83 Old 01-16-2013, 09:43 PM
Quoted: 288 Post(s)
Liked: 55
That kills my plans... maybe will make a box within a box and attack the outer box to the inner but not to itself
post #69 of 83 Old 01-17-2013, 04:55 AM
brian6751's Avatar
Quoted: 881 Post(s)
Liked: 676
What are you trying to accomplish with the butcher blocks? Is it just a certain look?
I don't think the box within a box will work either.
Rivers Edge Theater
post #70 of 83 Old 01-17-2013, 05:42 AM
Martycool007's Avatar
Quoted: 280 Post(s)
Liked: 176
Kind of off topic, but, have you guys ever gotten I to building custom furniture? I would love to build myself a nice dining room table, and perhaps a nice bookshelf. All made out of birch, and stained a very dark ebony.
Do you guys know of any websites that have existing designs for stuff like this, sort of similar to our DIY Subwoofer build gallery?
Martycool007 is offline
post #71 of 83 Old 01-17-2013, 06:52 AM
fperra's Avatar
Quoted: 50 Post(s)
Liked: 71
Get a subscription to Fine Woodworking. Here are some forums:
http://www.woodworkingtalk.com/
http://www.sawmillcreek.org/forum.php?s=f903b0c600e677d2487bad2657c305c8
http://forums.finewoodworking.com/
fperra is offline
post #72 of 83 Old 01-17-2013, 11:21 AM
dwightp's Avatar
A google search will point you to some websites that apparently offer free furniture plans. I don't have any experience with any of them.
Most of the woodworking magazines sell plans for projects they featured in their print magazines. The plans are usually not very expensive. If you're just getting started making furniture, you might look at the stuff offered by woodmagazine.com or woodsmith.com.
The projects featured in Fine Woodworking often feature interesting designs that can be more challenging to carry off. They seldom use plywood. They usually assume the user has a certain level of knowledge and access to a fairly well-equipped shop. I love this publication -- I have subscribed for 20 years -- but their furniture plans might not be well suited to someone who's just getting started building furniture.
Achieving a fine finish on your newly-built furniture is another important skill set. I found one of Bob Flexner's books, Understanding Wood Finishing, to be very helpful. Rather than derail the thread with a bunch of unsolicited advice about wood finishing, I will offer one suggestion: If you're going to build more than one piece of furniture, you will thank yourself in the long run if you invest in an inexpensive HVLP spray system.
dwightp is offline
post #73 of 83 Old 01-17-2013, 02:59 PM
Quoted: 288 Post(s)
Liked: 55
Would like to make it match. Could I build it to fit in the stand but sound treat around then leave the back with heavy sound panels
post #74 of 83 Old 01-17-2013, 03:41 PM
brian6751's Avatar
Quoted: 881 Post(s)
Liked: 676
You want it to match your TV stand? Got any pictures of it?
Rivers Edge Theater
post #75 of 83 Old 01-18-2013, 01:03 PM
Quoted: 288 Post(s)
Liked: 55
Would be building both at the same time so could use the same wood then put cloth over the components also
Make it into one big semi hidden setup was kid of the idea
post #76 of 83 Old 01-18-2013, 01:04 PM
Quoted: 288 Post(s)
Liked: 55
I saw some 11 ply maple at Lowes - 2' x 8' and it was pretty cheap - I think $26-28
post #77 of 83 Old 01-18-2013, 02:07 PM
Point Source
beastaudio's Avatar
Quoted: 3496 Post(s)
Liked: 2826
That is a nice deal! basically two of those for a little over $50 to equal a single 4x8 sheet of lesser-grade ply. Seems like a no brainer. Did you find those in the back with all the construction panels?
beastaudio is offline
post #78 of 83 Old 01-18-2013, 02:10 PM
Gorilla83's Avatar
Quoted: 370 Post(s)
Liked: 513
At one point my HD had the maple in full 4x8 sheets for 45.00. It was really nice looking wood and I should've bought a bunch because I never saw it again. frown.gif
Gorilla83 is offline
post #79 of 83 Old 01-18-2013, 02:44 PM
Point Source
beastaudio's Avatar
Liked: 2826
WOW!!! I would have bought a whole pallet.
post #80 of 83 Old 01-18-2013, 03:23 PM
skeeter99's Avatar
Just to chime in here for local suppliers of BB ply and other variations thereof, in Seattle and Portland there is an AWESOME store called Crosscut Hardwoods. They have a huge supply in stock in 4x4 and 4x8 sheets in all the thicknesses too. As the name implies, they also have huge amounts of hardwood planks in stock, some really beautiful stuff. I bought a couple planks of Cumaru (Brazillian Teak) that I turned into a set of speaker stands. Pricing is very good too. I don't know off hand how much a sheet of BB is but the 60-70 dollar range sounds about right. Anyway, thought I'd plug in for a reputable place to pick this stuff up at.
Scott
skeeter99 is offline
post #81 of 83 Old 01-18-2013, 07:41 PM
Quoted: 288 Post(s)
Liked: 55
No it was by the higher grade wood
Maybe ill make my tv stand from this then
post #82 of 83 Old 01-20-2013, 08:07 PM
Audiophile1178's Avatar
Correct me if i'm wrong but I think that i've seen the same ply at my lowes as well. It looks very nice but the veneer looks to be paper thin which is why I went with the Arauco at HD.
Audiophile1178 is offline
post #83 of 83 Old 01-20-2013, 09:27 PM
Point Source
beastaudio's Avatar
Liked: 2826
I know the pine in question's veneer is that thin, and why I use it as scrap now.
