2 Mal-21s in 50 cu ft? Ported to 12Hz? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 17 Old 01-08-2013, 04:06 PM - Thread Starter
MoFinWiley's Avatar
~50 cu. ft. enclosure with two Mal 21s in a dual opposed fashion, but manifold-like. Ported with a 12Hz tune.
I am considering doing this.
1. I need to use these two Mals.
2. It seems to model pretty well in WINISD.
3. I have talked the wife into this as part of our living room entertainment center.
4. I need to build a frame on this wall anyways, to hold the Black Diamond screen material I "acquired", so this will be "part" of it.
This sketchup was just a quick model to show the manifold placement i was thinking about.
Thoughts?
My concerns.
Manifold width. Curved corner to back of manifold? Angled wall in manifold? In the sketchup the manifold opening is 8x30.
Port size
I modeled it with two 2x20 slots about 19" deep. It show almost 37 m/s with 3200 watts at 11-12HZ
I'll do a model of the room and the entire box/entertainment center idea later today or tomorrow.
Steve
MoFinWiley is offline
post #2 of 17 Old 01-08-2013, 04:11 PM
Bass Enabler
Scott Simonian's Avatar
Quoted: 5282 Post(s)
Liked: 4167
Yup. Do it!
The Mal-X 21 models pretty good in about 25cuft and tuned as low as you can.
Scott Simonian is online now
post #3 of 17 Old 01-08-2013, 04:35 PM
N8DOGG's Avatar
Quoted: 967 Post(s)
Liked: 1038
N8DOGG is offline
post #4 of 17 Old 01-08-2013, 04:48 PM - Thread Starter
MoFinWiley's Avatar
Hahaha. "Coffin" build it is.
Scott, would I want to tune lower than 12? It seemed to fall off quite a bit going lower.
post #5 of 17 Old 01-08-2013, 04:53 PM
whiskey_face's Avatar
ermahgerd pls poast many pix.
k thx.
english: oh my god please post a lot of pictures.
whiskey_face is offline
post #6 of 17 Old 01-08-2013, 04:58 PM
Bass Enabler
Liked: 4167
That really depends on you and your desire for whatever cutoff. There will be a tapering off in output but your room will make up for it.
post #7 of 17 Old 01-08-2013, 05:00 PM
Bass Enabler
Liked: 4167
k thx.
post #8 of 17 Old 01-08-2013, 06:32 PM
noah katz's Avatar
Quoted: 879 Post(s)
Liked: 304
If feasible, I'd consider two separate boxes at opposite mid-wall positions to eliminate all odd-order modes, per Welti.
Noah
noah katz is offline
post #9 of 17 Old 01-08-2013, 07:06 PM - Thread Starter
MoFinWiley's Avatar
I wish, but I am pretty limited with this room. I have the lots of floor space in just one part of the room.
The room is our everyday living room on an open floor plan 1st floor.
When I get to do a dedicated HT in the basement the layout will be better (I really want to do a DBA)
post #10 of 17 Old 01-09-2013, 02:07 PM - Thread Starter
MoFinWiley's Avatar
LOL @ my use of "acquired" one of my coworkers said it makes me sounds like I stole the screen material, which I did not, FWIW. I have a friend that installs them. This one is a defect 104 inch one(defect is 4" from corner)...I currently have a cheap 92" screen...All I have to do is build a frame to tension it.
Steve
post #11 of 17 Old 01-11-2013, 11:33 AM
BassThatHz's Avatar
Quoted: 2031 Post(s)
Liked: 1547
That's like 5 whole 4x8 sheets glued directly together. biggrin.gif Coffin indeed.
BassThatHz is online now
post #12 of 17 Old 01-11-2013, 12:23 PM
stormwind13's Avatar
Quoted: 60 Post(s)
Liked: 96
Thank you for that.
stormwind13 is offline
post #13 of 17 Old 01-11-2013, 01:59 PM - Thread Starter
MoFinWiley's Avatar
I have been pondering that fact. I am going to redo this drawing to hopefully be around 6 sheets of 5x5 BB if I can find some in my area. I will have to resort to stick bracing because I would need another 4 sheets if I didn't.
post #14 of 17 Old 01-11-2013, 02:06 PM
gperkins1973's Avatar
I wouldn't be concerned with 37 m/s of air speed. I have had higher than that with no issues or chuffing. This is perfect for those drivers
gperkins1973 is offline
post #15 of 17 Old 01-11-2013, 05:06 PM
Stereodude's Avatar
Quoted: 3085 Post(s)
Liked: 2236
High port air speeds at subsonic frequencies seems like it would be a significant problem. More so than higher more audible frequencies. You're not so likely to hear the fundamental because reduced hearing sensitivity that low, but the chuffing / turbulence sure will be in your range of hearing and will be that much more obvious.
Stereodude is online now
post #16 of 17 Old 01-11-2013, 05:30 PM
Bill Fitzmaurice's Avatar
Liked: 4629
You don't hear low frequency waves passing through the duct at high mach as chuffing, you hear the friction of those waves against the duct, and that tends to be in the midrange.
Bill Fitzmaurice is online now
post #17 of 17 Old 01-13-2013, 02:21 PM - Thread Starter
MoFinWiley's Avatar
Thanks guys, I was hoping the ports weren't going to be an issue.
The are of the manifold openings match the SD of the driver, is this acceptable?
Steve
