Blown Kenwood SW36HT subwoofer - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 01-10-2013, 02:37 AM - Thread Starter
CleatusCat's Avatar
A friend asked me to look into a replacement woofer for this low fi sub. He's not into audio, just wants his sub working again.
Any ideas on a replacement 8" woofer for this 100watt piece? Perhaps an improved woofer?
Xbox Live- RumRiverKiller
HT Room- Samsung 550 64" Plasma, Tivo XL, Marantz SR-14 EX , BP3000TLs, CLR3000, BP2002 sides, Logitech 700
Music Room- Samsung 650 46" LCD, Tivo, Pioneer VSX-1120K , Canton GLE 409s, small cheap sub, Logitech 650
Garage- Kenwood VR606, Original Large Avents
CleatusCat is offline
post #2 of 7 Old 01-10-2013, 09:09 AM
filtor1's Avatar
Quoted: 203 Post(s)
Liked: 157
Kenwood SW36HT woofer PART NUMBER: T10-0848-05 and seems to be a discontinued item. I was unable to find any ts information to even begin to suggest an alternative driver.
I would recommend contacting Kenwood directly.
filtor1 is online now
post #3 of 7 Old 01-10-2013, 09:30 AM
mtg90's Avatar
Quoted: 477 Post(s)
Liked: 942
A few questions and a suitable replacement should be easy to find.
#1 Can you measure the internal dimensions of the enclosure?
#2 Can you measure the port diameter and length?
#3 Can you measure the cutout for the woofer on the box, don't want to get one that does not fit.
With those we can determine the enclosure volume and tuning frequency which should help in determining a good replacement.
Right now looking at some pictures I am guessing it is about 1.2cuft net and port is maybe 3” in diameter and about 10” or so long with would put tuning in the mid thirties. But I would like you to double check those estimates when you get the chance.
mtg90 is offline
post #4 of 7 Old 01-10-2013, 01:44 PM - Thread Starter
CleatusCat's Avatar
I think we'd be pretty safe going by your estimates. There is no port on it that I can see. The whole front face is covered by unserviceable black fabric. I will see if he will allow me to tear it off for a look and report back
post #5 of 7 Old 01-10-2013, 01:50 PM
filtor1's Avatar
Quoted: 203 Post(s)
Liked: 157
http://www.crutchfield.com/S-qKswE1V1q7D/p_113HTB505/Kenwood-HTB-505.html#
Subwoofer:
8" cone
100-watt built-in amplifier
bass-reflex design
11-13/16"W x 13-3/16"H x 19-1/4"D
It is definitely ported. I have been looking around to see if I can find what it is tuned to.
post #6 of 7 Old 01-10-2013, 09:50 PM - Thread Starter
CleatusCat's Avatar
I won't have a chance to disect this thing until this weekend. Seeing the Crutchfield specs, it says the "system freq response is 40-40000hz"? Could that mean that the sub goes to 40?
I was considering this driver. I know its a lot better quality than the Kenwood piece
http://www.parts-express.com/pe/showdetl.cfm?partnumber=295-484
post #7 of 7 Old 01-11-2013, 08:44 AM
filtor1's Avatar
Quoted: 203 Post(s)
Liked: 157
I don't see any reason why that driver would not work. As long as the built in amp is stable at 4ohm.
