Behringer Inuke LF performance with low impedance load - Page 3 - AVS Forum | Home Theater Discussions And Reviews
 1Likes
post #61 of 87 Old 03-13-2013, 05:42 PM - Thread Starter
zheka's Avatar
Quoted: 29 Post(s)
Liked: 26
Originally Posted by noah katz View Post
seems like the shallow slopes don't give a lot of protection; have you tried a higher order HP and more boost on the PEQ?
I did play with various settings but this one seemed to model very much like a 15Hz second order HPF which puts excursion @ max power slightly above Xmax in my system. I am not sure if this is conservative enough but that's the gamble I took. Generally I think if a second order HPF provides adequate protection in a given system, then using this workaround should work just as well. almost.
zheka is offline
post #62 of 87 Old 03-13-2013, 06:29 PM - Thread Starter
zheka's Avatar
Quoted: 29 Post(s)
Liked: 26
Originally Posted by The_Nephilim1 View Post
Ahhh Thank You SO Much for that Zheka, I hate being a Noob hehe!!
I am wondering How will I tell if I am at the Proper tunning I do NOT Want to go past the excursion limit as it is Only tuned to 16hz..(IS that the correct word??)
Also someone mentioned playing with WinISD How can I mess with WinISD to find out info they reccomended to do?? I thought WinISD ONly made the measurments for the hz rates in Db..
WinISD is modeling software. If you know specs of the driver, size and tuning frequency or port dimensions of the enclosure, then you can model how the driver would behave under given power and equalization settings.
http://www.hometheatershack.com/forums/diy-subwoofers-general-discussion/6330-winisd-pro-tutorial-download-detailed-guide-how-use-winisd-pro.html
What do you know about your driver and enclosure?
zheka is offline
post #63 of 87 Old 03-14-2013, 12:05 AM
The_Nephilim1's Avatar
Quoted: 48 Post(s)
here is what I know:
Thiele-Small parameters:
Fs = 17.7 Hz
Re = 3.4 ohms[dc]
Le = 6.09 mH
Qt = 0.37
Qes = 0.39
Qms = 5.59
Mms = 434.34 grams
Rms = 8.69 kg/s
Cms = 0.184 mm/N
Vas = 274.1 liters
Sd= 1029.22 cm^2
Bl = 20.51 Tm
Lp(2.83V/1m) = 91.60 dB
The Tune of the box is at 16Hz somebody else modeled it for me.. I will be pumping about 750 watts into it. If I can figure out how to set the amount of Wattage as the Amp I have is 850w..The driver is rated at 800W but Mark the guy from Mach 5 said NOT to pump that much power into it so I am going to start low wattage and work up..
I guess if the HPF is set to 16Hz it shouldn't go too 10hz.... I am going to try and do some modeling in WinISD PRo and see what I can come up with.. IF you can would you Please mind modeling this for me and see what you come up with??
Thnx
Gerald
The_Nephilim1 is online now
post #64 of 87 Old 03-14-2013, 05:49 AM - Thread Starter
zheka's Avatar
Quoted: 29 Post(s)
Liked: 26
Fs = 17.7 Hz
Re = 3.4 ohms[dc]
Le = 6.09 mH
Qt = 0.37
Qes = 0.39
Qms = 5.59
Mms = 434.34 grams
Rms = 8.69 kg/s
Cms = 0.184 mm/N
Vas = 274.1 liters
Sd= 1029.22 cm^2
Bl = 20.51 Tm
Thnx
Gerald
internal volume of the enclosure is also needed. there are online calculators you can use if it's not known
is that mach 5 audio IXL 18" driver?
zheka is offline
post #65 of 87 Old 03-14-2013, 03:21 PM
Quoted: 48 Post(s)
Yes it is the Mach 5 IXL 18.4 18" Driver wink.gif the volume of the cabinet is 285L
post #66 of 87 Old 03-14-2013, 07:49 PM - Thread Starter
zheka's Avatar
Quoted: 29 Post(s)
Liked: 26
here is the settings I think would work for you.
750W signal.
Gray - no HPF
Blue - 15Hz 2nd order HPF
Red - the workaround. 2dB Q=1 PEQ boost @20Hz and 1st order HPF @22Hz(this is different from the original 20Hz setting)
setting the HPF slightly higher provides better excursion control and still keeps the overall curve above tuning very similar to the real 15Hz 2nd order HPF. I willl probably use this setting with my subs.
Noah, what do you think?
zheka is offline
post #67 of 87 Old 03-14-2013, 09:05 PM
noah katz's Avatar
Quoted: 1107 Post(s)
Liked: 387
That actually looks pretty good, thanks.
I didn't even know WiNISD had parametric EQ.
Noah
noah katz is online now
post #68 of 87 Old 03-15-2013, 05:24 AM
Quoted: 48 Post(s)
750W signal.
Gray - no HPF
OK I was close in some stuff when I applied the T/S Paramaters.. I am wondering how do I make it a 1st order HPF?? is that the Butterworth with 612db??
post #69 of 87 Old 03-15-2013, 06:47 AM - Thread Starter
zheka's Avatar
Quoted: 29 Post(s)
Liked: 26
Yes, 1st order HPF is Butterworth 6dB.
The settings are the same as in the snapshots I posted in #58, only the HPF is set @ 22Hz instead of 20Hz.
zheka is offline
post #70 of 87 Old 02-08-2014, 12:13 PM
corradizo's Avatar
Quoted: 1183 Post(s)
Liked: 909
"The only issue I have with my iNuke 3000DSP is the lack of any DSP functionality below 20 Hz. My subs need a slightly lower highpass than that...."
i believe that you can "wing it" with a combination of a 2nd order high pass and a low shelf with *negative* gain.
a second order high pass filter set to 20hz will have a -3db point at 20hz and will be down -12db at 10hz.
a high shelf 12db/octave (hs12) set to 20HZ will have a +3db point at 20hz and will be up +9db at 10hz.
together, these two filter produce the same thing as a second order high pass filter set to 10hz.
of course, you don't have to use 20hz for a 10hz net, you can set both filters for 30hz in order to achieve a 15hz high pass net.
the only downside is that the noise floor will be higher, which may not be a problem.
So if I'm building a dual opposed or 2 single sealed (on the same amp bridged) do I apply the same technique on my 3000dsp? Can it do a linkwitz transform? Is that better?
Pete
corradizo is online now
post #71 of 87 Old 06-07-2014, 12:09 PM
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2698
here is a picture of the filters.
divide the frequencies by 10, i.e. 100hz in the picture is 10hz. winisd gets screwed up with filters down under a few hz.
yellow line is a second order high pass filter at 200hz.
red line is 12db/oct high shelf filter at 200hz with -12 gain.
green line is the net of the two filters--a second order high pass filter at 100hz.
Mfusick is offline
post #72 of 87 Old 08-02-2014, 09:28 PM
Jeff in Canada's Avatar
Quoted: 167 Post(s)
Liked: 62
Thanks as well LTD
Audio: Denon AVR-4520, Fusion 12 Tempest (LCR), Fusion 8 Alchemy (4xSurrounds+2xWides+2xHeights),4 x 15" Dayton Ultimax
Video: Sony VPL-HW40ES, Darbee Darblet, SMX 2.35:1 Screen
Seating: Fusion Lagoon Chairs
Theater Build
DIY Speaker / Sub Build
Jeff in Canada is offline
post #73 of 87 Old 08-02-2014, 09:35 PM
Quoted: 167 Post(s)
Liked: 62
Did I do this correctly?
ID:	194169   Click image for larger version
Theater Build
post #74 of 87 Old 08-02-2014, 10:33 PM
LTD02's Avatar
Quoted: 2553 Post(s)
Liked: 2888
couple of points there jeff.
for about a 15hz high pass:
set the high pass freq 1 to 20hz.
on filter 1, set the frequency to 20hz and change the shelf to -5db.
the low pass filter is a separate issue. that should not be at slope 48db, as that will mess up your phase bigtime. if you are using an lfe/subwoofer output on an avr, just turn the low pass off because it will be taken care in the avr itself.
Listen. It's All Good.
LTD02 is offline
post #75 of 87 Old 08-02-2014, 10:58 PM
BassThatHz's Avatar
Quoted: 2391 Post(s)
Liked: 2167
That will make it 16 times harder to get the maximum watts out of the amplifier above 30hz; which depending on the conditions may cause you to clip the amp input trying make the higher frequencies sound powerful (which may be impossible at that point).
A positive low-shelf would be better with the inukeDSP, it avoids clipping or reducing sensitivity; as the XO is likely applied before the PEQ, so you are just bringing back some of the ULF that was already removed.
BassThatHz is online now
post #76 of 87 Old 08-03-2014, 05:57 AM
Quoted: 167 Post(s)
Liked: 62
Thanks LTD02
BassThatHz & LTD02: What should I put my settings at then? I have a 15" Ultimax (x2) and wanted to extend down. I have the iNuke6000.
What would be your suggestion? I'd like to extend them as low as is reasonable considering that i have. I have them in a 3cuft box based on the kit Parts Express offered. I have 4 total, but the two first ones I purchased have a Bash 500s plate amp. I thought drivers would extend to 15 Hz....perhaps I'm wrong
I'll eliminate the low pass at 100Hz.
Theater Build
post #77 of 87 Old 08-03-2014, 10:54 AM
corradizo's Avatar
Liked: 909
Originally Posted by Jeff in Canada View Post
Thanks LTD02
Are you in sealed boxes? If so, you do not need to HP or LP at the inuke, just LP in your avr. If sealed then extending the bottom end would be more like doing a ls12 at 20hz +9 db and then cutting with PEQ at 20hz -9db or -6db q=2 depending on what you need in room to attain a house curve you like. Measuring the subs response with REW and a mic would be the best way to figure out where to start your ls12 (20hz, 25hz, 30hz) and how much boosting you need to get it dialed in.
My 2 newb cents.
post #78 of 87 Old 08-03-2014, 11:01 AM
blake18's Avatar
Quoted: 315 Post(s)
Liked: 191
Is the consensus on these amps that they do provide enough output below 20hz for home theater use?
Lumenlab "Community driven video lab".
blake18 is offline
post #79 of 87 Old 08-03-2014, 11:09 AM
V.X.Donique's Avatar
Quoted: 52 Post(s)
Liked: 45
I'm curious on how to implement an L/T with the 6kdsp as well. Sealed here.
V.X.Donique
Introducing the Vier Systems Xero.1/Midbasiks Subwoofer builds....
Creator of the AVScience DIY Speakers and Subwoofers Forum
"Don't concentrate on the finger or you will miss all that heavenly glory." -Bruce Lee
V.X.Donique is online now
post #80 of 87 Old 08-03-2014, 01:07 PM
corradizo's Avatar
Liked: 909
Inukes are great, get down well below 20. I get output to 10hz at least.
post #81 of 87 Old 08-03-2014, 04:12 PM
Quoted: 167 Post(s)
Liked: 62
LTD / Bass How should I configure the iNuke for what I'm looking for with a 15" Ultimax in a sealed 3 cuft box?
Theater Build
post #82 of 87 Old 08-04-2014, 05:29 AM
Martycool007's Avatar
Quoted: 280 Post(s)
Liked: 181
These iNukexxxxdsp amps are perfect for home theater as they are extremely cost efficient offering plenty of current/watts as well as having built in EQ/DSP capabilities for a very small amount of cash. There are work-a-rounds that are available to extend the response down below 20hz. These are what we are currently discussing.
Martycool007 is offline
post #83 of 87 Old 08-04-2014, 09:44 AM
blake18's Avatar
Quoted: 315 Post(s)
Liked: 191
Awesome, definitely getting one later this month. Could you tell me about or link me to the work arounds? Are they difficult to do?
blake18 is offline
post #84 of 87 Old 07-05-2016, 01:17 AM
henningdalgaard's Avatar
I am considering an Inuke 6000 DSP for a pair of buttkickers LFE on one channel and a SVS PC13 ultra on the other channel (the built in amp in the SVS died). Would this be possible? It would save me a lot of money.
Is it possible to completely separate and adjust the two channels - or would I need to buy two Inuke 3000 DSP instead?
henningdalgaard is offline
post #85 of 87 Old 07-05-2016, 06:19 AM
baniels's Avatar
Quoted: 219 Post(s)
Liked: 357
Yes - it's a stereo amp with 2 x input and 2 x output, and while I don't have the DSP version, I'm sure you have full DSP control over each channel. It should work just fine. Y
ou'll be wiring the two 4 ohm buttkickers in series for an 8 ohm load, which should still give you ample power for them. I'm guessing the SVS is 4 ohm, and you'll have plenty of power for that on the other channel.
baniels is offline
post #86 of 87 Old 07-05-2016, 06:43 AM
corradizo's Avatar
Liked: 909
You can use bi-amp1 to feed in the sub signal and it splits the signal internally to each channel that can be controlled independently. Alternatively you can split your sub signal externally from a y cable and feed each input indipendantly and control them independently as well.
post #87 of 87 Old 07-06-2016, 02:25 AM
great, thanks. I guess maybe just split the signal internally instead of splitting it before and lowering the voltage/input power.
I was considering the Inuke 3000 but I am unsure if it will have enough power? To be safe, go with the 6000 I guess.
