DIY active mains with all Seas driver and DEQX - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 01-11-2013, 10:14 AM - Thread Starter
rezaN's Avatar
Been working on these for about 4 months now. All the wood was cut by Aloha cabinetry in Livermore CA using CNC. Design was by me and with the help of guys at Madisound. The towers are maid with stacks of 1" MDF than I used 3 layers of 1/8" bending Baltic Birch with wrap each tower. The total wall thickness is 2 inches and front baffle is 2.5 inches with 1/2" Baltic Birch sandwiched between MDF sheets. I will be veneering the whole thing and the front baffle and top part are gonna be pained black. The drivers are all Seas Excel. with 2 10" woofers per tower. I did make a change the the system. First it was going ported and now since I'm using the DEQX active crossover, I can boost the low end extension.
hope you enjoy:D:D:D
rezaN is offline
post #2 of 3 Old 01-11-2013, 10:52 AM
tuxedocivic's Avatar
Quoted: 2186 Post(s)
Liked: 2055
Wow! What happened in the last photo. The top was cut off the cab half way through the woofer?? Changes your mind?
My youtube channel: Impulse Audio
tuxedocivic is offline
post #3 of 3 Old 01-11-2013, 11:24 AM - Thread Starter
rezaN's Avatar
no. The top curved piece is connected to the front baffle and is gonna be painted. I'll go back on after the veneering is done.
rezaN is offline
