Can someone give me a hand with a DIY sub project? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 15 Old 01-11-2013, 06:48 PM - Thread Starter
dimetera413's Avatar
Hey everyone. I want to build my own sub soon and I need some help modeling because I am no good with winISD and calculations. I can build very well with lots of carpentry experience so enclosures are not a problem. I wanted to do a 10" driver in a sealed box. I need the box to be as small as possible for WAF. Price isn't really a problem. I would like to use a plate amp to make the setup as clean as possible and I have no room for a pro amp. Can someone just tell me the best driver and amp and box size? I watch movies mostly so some deep extension would be nice and some decent SPLs. My room is also 1500 cubed.
dimetera413 is offline
post #2 of 15 Old 01-11-2013, 07:18 PM
Bill Fitzmaurice's Avatar
Liked: 5684
Originally Posted by dimetera413 View Post
I need the box to be as small as possible ... deep extension would be nice... and some decent SPLs.
Pick two of the above. Any two. You can't have all three.
Bill Fitzmaurice is offline
post #3 of 15 Old 01-11-2013, 07:25 PM - Thread Starter
Lol. I guess small enclosure and SPLs.
post #4 of 15 Old 01-11-2013, 07:34 PM
Jay1's Avatar
Quoted: 236 Post(s)
Liked: 221
What is your definition of small? Does that mean something like a 12" cube? Budget?
Jay1 is offline
post #5 of 15 Old 01-11-2013, 07:49 PM - Thread Starter
Small as in maybe a 14" cube. Budget is 700-800.
post #6 of 15 Old 01-11-2013, 08:00 PM
jpmst3's Avatar
Quoted: 97 Post(s)
Liked: 233
It's going to be real tough to get much from a 14" cube. You are pretty much limited to one 12" driver and a sealed setup.
You can only hope to get some monster driver, as in high excursion and throw a lot of power at it since you will need to EQ it down low.
Joe = LFE Addict
Joe's LOWARHORN build
jpmst3 is offline
post #7 of 15 Old 01-11-2013, 08:24 PM
jpmst3's Avatar
Quoted: 97 Post(s)
Liked: 233
You could try one of those new Dayton 12s and an affordable plate amp.
Joe = LFE Addict
jpmst3 is offline
post #8 of 15 Old 01-11-2013, 08:26 PM
Jay1's Avatar
Quoted: 236 Post(s)
Liked: 221
Since you have such a good budget I would encourage you to use a PR instead of a tiny sealed box. For example, this CSS APR 12, placed on any side of your 14" cube
http://www.creativesound.ca/details.php?model=APR12
The active driver could be down firing, and the amp placed on the back of the box. This will allow you to have a fairly low tuned sub that can handle a 500 watt plate amp
http://www.parts-express.com/pe/showdetl.cfm?partnumber=297-460
http://www.parts-express.com/pe/showdetl.cfm?partnumber=300-807
The best part about the APR is you can play with the tuning of the sub by adjusting the mass. The full 900g mass added will tune you to about 20hz at around -10 db. 630g mass around 25hz at -5 db. 450g mass around 30hz at -2 db. For output you're looking at about 110db from 40hz, down to whatever the tuning cutoff is.
Jay1 is offline
post #9 of 15 Old 01-12-2013, 07:40 PM
LTD02's Avatar
Quoted: 2526 Post(s)
Liked: 2869
agree. passive radiator is the way to go for a small enclosure, that will be loud, and tuned relatively low. the tradeoff is it costs a little more, but the op sounds like he has sufficient budget.
Listen. It's All Good.
LTD02 is offline
post #10 of 15 Old 01-13-2013, 08:48 AM
Stereodude's Avatar
Quoted: 3415 Post(s)
Liked: 2499
You can't cheat a few more inches to something like a 17" or 18" cube?
A 14" (external) cube built out of 18mm 13 ply Baltic Birch is going to have a usable air space of about 1ft^3 if you're really lucky (ie: skimp on the bracing some, have a driver with a small motor, and amp that doesn't have too much sticking in the box).
Stereodude is offline
post #11 of 15 Old 01-13-2013, 08:52 AM
Stereodude's Avatar
Liked: 2499
That amp will eat up a huge chunk of the interior volume in his 14" cube box. It wouldn't be my choice for a small box. The 500W Bash or Yung would be better in that regard.
post #12 of 15 Old 01-13-2013, 09:16 AM
Liked: 5684
Originally Posted by Stereodude View Post
That amp will eat up a huge chunk of the interior volume in his 14" cube box..
Don't mount it in the cab, put it in its own box, placed as close as possible to the receiver. Run a long speaker cable rather than a long interconnect, greatly reducing the potential for ground loop noise. On-board amplification was foisted on us by the industry under the guise of convenience; we're DIY, we don't have to settle for what they give us.
post #13 of 15 Old 01-13-2013, 10:06 AM
Stereodude's Avatar
Liked: 2499
Great idea except for this:
post #14 of 15 Old 01-13-2013, 11:32 AM
Liked: 5684
A plate amp in a box is far smaller than a rack mount amp, and can be stashed away behind other stuff. For that matter you don't even need to enclose many plate amps.
post #15 of 15 Old 01-13-2013, 01:01 PM
djkest's Avatar
Quoted: 35 Post(s)
Liked: 44
A Stereo Integrity 15" subwoofer will give you just about everything you want.
18.5 x 18.5 x 18.5" cube. Way under budget. $230 shipped.
Also, another one to consider would be the same size box with 2 TC Sounds Epic 12 subwoofers, dual opposed. $390 for both drivers. Would take a ton of power.
If you wanted something smaller than either of those, a single TC Sounds Epic 12 in a 15" cube would also work pretty well.
ETA: Could you make a sub to hide somewhere like behind the couch? If you made an odd shaped sub you could get a long port in there too maybe.
djkest is offline
