Lilmike's LilWrecker - Page 16 - AVS Forum | Home Theater Discussions And Reviews
 70Likes
Old 01-26-2014, 11:17 PM
SvtFoci's Avatar
Quoted: 30 Post(s)
Liked: 24
Originally Posted by jeffm13 View Post
It apparently does in my room, and it's a pretty big room at about 5100 cu ft. I'm using a single lilwrecker with an Alpine driver and one channel of an iNuke 3000dsp to power it. I set up a 24db/oct high pass at 20hz and a -12db high shelf at 20hz, which apparently gets it down to about 15hz. I have yet to fiddle with other settings on the dsp, so I guess it's possible that it could even go a bit lower.
How big is your room?
SvtFoci is offline
Old 01-26-2014, 11:27 PM - Thread Starter
lilmike's Avatar
Quoted: 64 Post(s)
Liked: 160
Originally Posted by SvtFoci View Post
I have 2 plate amps that rol off around 30hz. Is this going to be too high for them? I'm thinking of building at least two.
Yeah, they're about an octave too high.
Your plate amps will be down at least 12 dB by 15 Hz, which is leaving a lot on the table with the LilWrecker (basically - the part that makes it worth building this cabinet over something like the T-6).
Depending on the driver you choose, two is a pretty good match for a mid-range pro amp or two. DSP isn't really optional, these need a highpass and a few cuts for EQ.
Something that makes around 600 watts stereo 4R/1200 mono 8R. Lots of choices, but only a few with decent integrated DSP.
lilmike is offline
Old 01-26-2014, 11:43 PM
SvtFoci's Avatar
Quoted: 30 Post(s)
Liked: 24
Well I have two others amps that have a lower roll off. Around 20 and one around 10. Which is the best driver would be best? I have a pretty small room.
SvtFoci is offline
Old 01-27-2014, 12:34 AM
Stumbo's Avatar
Quoted: 55 Post(s)
Liked: 88
Those plate amps might be modifiable. What brand are they?
If you are going to keep the factory 30hz HPF, there are a lot of horns that will get much louder with a much smaller cab.
Oppo 103D
Samsung pn64f8500
Pioneer vsx-82txs
And a bunch of DIY speakers and subs.
Coming soon: Dirac Room Correction
Stumbo is offline
Old 01-27-2014, 12:57 AM
SvtFoci's Avatar
Quoted: 30 Post(s)
Liked: 24
Do tell?
SvtFoci is offline
Old 01-27-2014, 03:11 AM
chrapladm's Avatar
Quoted: 823 Post(s)
Liked: 286
There are a LOT of 30-50hz designs out there.
chrapladm is offline
Old 01-27-2014, 06:33 AM
jeffm13's Avatar
The theater is open to the game room, so the combined size is about 615 sq ft, with 8' 3" ceilings, giving me about 5100 cu ft. With a single sub, it doesn't fully pressurize the whole room--I'd probably need a few more to do that. But it gets plenty loud enough to shake the seats, and the windows, and the rest of the house since I didn't do any soundproofing to speak of. Right now, I'm running everything at 8 ohms (dual 4 ohm voice coils wired in series), with about 440 watts from the amp. Since the amp is rated for 2 ohms, I may try to run the voice coils in parallel. Just to see what the combination can do with one channel at closer to full power.
jeffm13 is offline
Old 01-27-2014, 10:21 AM
SvtFoci's Avatar
Quoted: 30 Post(s)
Liked: 24
Are you using the anarchy driver or something else?
SvtFoci is offline
Old 01-27-2014, 11:25 AM
jeffm13's Avatar
No. I just have an anarchy driver sitting around unused right now. For the lilwrecker, I used an Alpine 15" Type S (SWS-15D4). List price on the driver is $230, but you can find them for half that price.
jeffm13 is offline
Old 01-27-2014, 11:31 AM
SvtFoci's Avatar
Quoted: 30 Post(s)
Liked: 24
Damn it, I thought this was the anarchy build tapped horn.
SvtFoci is offline
Old 01-29-2014, 10:34 AM
jjjbrim's Avatar
Mike/others, once again thank you for your help.  I have ordered the Alpine speaker and it will be here in the next day or so.  I will pick up my wood and some more clamps and start on the construction based on the clarification that you provided on the drilling.  In a previous post you had mentioned that you would go with an Inuke 3000 with DSP for the amp (then I would not need to purchase any other items to filter the subwoofer).  I did look on UniqueSquared since you mentioned that you might be able to score one for $250 however they and many others seem to be out of stock of this amp.  That said it appears that I can still find a couple options for the amp at ~$350 new.  Any other options that might make more sense than spending $350 on the amp?  I have not dealt with amps in the past, my Sunfire was already powered and my receiver fed the main speakers with the built in amp so I am completely green in this area.
thanks,
Joe
jjjbrim is offline
Old 01-29-2014, 11:25 AM - Thread Starter
lilmike's Avatar
Quoted: 64 Post(s)
Liked: 160
thanks,
Joe
Interesting. A quick search this morning suggests that though they are for sale, but they're listed as "out of stock" or "pre-order" at the reputable online vendors. I think that they're scarce for a reason. I've got a hunch that there is a revised version of the iNuke right on the horizon. I checked and saw that Behringer had iNuke V2 models up on their website the day before NAMM started, but they've disappeared again for now. That's all I know. Might be the same, might be better, might be worse. May never get released.
The next best option would be a Balanced MiniDSP and whatever flavor of amp you want, there are lots of great options out there. Unfortunately - that's a 2-piece solution, and as a result, it costs a bit more. You could also shop your local Craigslist, I scored a nearly-new EP2500 for $150 that way.
When it comes to amps - there are brands to avoid and brands to embrace. The amp testing thread here is full of great information. I'm OK with the Behringer stuff, it offers decent value for the money and though the numbers are nowhere near what the ad copy claims, the actual performance is good. I'd also buy Crown, Crest, Peavey, QSC, and I'm sure I'm forgetting some. Personally, I have no issues with a proper Class D amp, some folks feel otherwise. There is plenty of junk out there too, and to further complicate things - not all amps by a given manufacturer work well as a subwoofer amp. If you stick with an amp that's a known quantity (one of the brands and models regularly used here in the power range that you need), you should be fine.
lilmike is offline
Old 01-29-2014, 04:03 PM
jjjbrim's Avatar
Mike,
I did find the Inuke 3000 DSP at the American Music Supply website for $299 shipped with no taxes and and extra year of warranty coverage (I have no idea what that really provides).  Anyways, I did find the unit and have it now.  If anyone else is interested here is the link:  http://www.americanmusical.com/Item--i-BEH-NU3000DSP-LIST
Joe
jjjbrim is offline
Old 01-29-2014, 10:18 PM - Thread Starter
lilmike's Avatar
Quoted: 64 Post(s)
Liked: 160
Mike,
Joe
Looks like you grabbed the last one - the site says "Pre-Order Today!" now.
lilmike is offline
Old 02-02-2014, 11:20 AM
jjjbrim's Avatar
Yeah, they did not show on there site that the item was back ordered and I got a notification after I purchased it that they had delays in shipping.  So I called them and they said they did not know when they would have the unit available again. So I checked back on Amazon and it is in stock at $279 and with tax it comes out to be a little over $300 so I ordered it from them on Friday.
jjjbrim is offline
Old 02-05-2014, 08:35 AM
jjjbrim's Avatar
LilMike/others, I have all of my supplies to build a single subwoofer now and want to obtain the information needed to purchase some of the other items needed so need direction.
1. I have never had an external amp so no knowledge in this area.  Here is what think I need to hook the subwoofer up to the receiver. Sub out from the receiver to the Inuke 3000 DSP in (something like PYLE-PRO PPSJ15) and then this type of cable from the  Inuke 3000 DSP out to the SpeakOn connector LilMike states in the materials list (Pyle-Pro PPSS30 30).  If it is not bullet proof please also describe how to wire SpeakOn connector to the Alpine SWS 15D4, I have just never done it before so need some hand-holding.
2. I am building this out of 3/4" maple plywood so great quality however plan on just plan on painting it black.  What is a normal cost effective means of getting paint onto the speaker (I have seen some info on dedicated speaker paint like DuraTex as well as bed-liner paint).  This speaker will just be placed and not moved around much, I am assuming the bed-liner or dedicated speaker paint is used for durability for someone that might use these speakers gigs, if I am incorrect just let me know.
Again, thank you very much for the helping hand.
jjjbrim is offline
Old 02-05-2014, 10:37 AM
jpmst3's Avatar
Quoted: 97 Post(s)
Liked: 233
You need an RCA to an XLR or 1/4" mono cable to get the output from the receiver to the input(s) on the amp.
Then you need a Speakon connection from the amp's output to the subwoofer(s). You don't need an actual SpeakOn cable. You can use a SpeakOn end and use it with standard speaker wire, preferably 12 gauge or better. The SpeakOn connector is made of 3 pieces that snap together with simple screw terminals inside that clamp onto the wire. All you need is a screw driver and wire strippers. The terminals are even labeled with a plus and minus. It is a no brainer.
Bedliner works perfectly. I have used on numerous builds. Durtex is probably the better choice but go with what is cheaper and you have access to.
You might want to consider cheaper ply rather than using hardwood ply that will be covered.
Joe = LFE Addict
Joe's LOWARHORN build
jpmst3 is offline
Old 02-05-2014, 11:23 AM
thebuckaman's Avatar
Quoted: 21 Post(s)
Liked: 80
+1 on Duratex. Easy to apply and looks great.
Getting things ready for a new theater room build at the new house.
Equipment so far- (8) SI HT18 mini martys, speakerpower SP2-12000, Denon 4311ci (will replace), MINIDSP 10x10HD, Crown CT8150, Oppo BDP-103D, (8)JBL 8320 , (3) EV EKX12 , Crestron CP3N control system, iso clips/Roxul
TBD- Projector, AT Screen, in room acoustics,
thebuckaman is offline
Old 02-05-2014, 11:15 PM - Thread Starter
lilmike's Avatar
Quoted: 64 Post(s)
Liked: 160
As others said, you need a signal cable. I use an RCA to 1/4" phono, works OK. An RCA-XLR will work too. No need for a bump box (unbalanced to balanced converter) in most cases.
Since I always wind up needing a custom length, I usually buy a spool of decent speaker wire, cut what I need, and buy some honest Speakons from Parts Express, because proper connectors matter. They're not expensive either. You need two of these to make the cable and one of these to put in your speaker cabinet. I install the cabinet speakon with a 15/16" drill bit, that seems to be a perfect fit. I use a little speaker caulk or duct-seal to make sure they are airtight though. They screw in with a pair of #6 X 1/2" wood screws.
Since the speakons I linked (and use) are 2-pole, they are pretty easy to wire up, just keep the (+) and (-) straight. I generally put the cable with the polarity indicator into the (+) pin. The cable can be assembled with a phillips screwdriver. The speaker connector I linked to will require soldering.
Wiring a dual-voice coil woofer can be tricky, you can choose series or parallel, and you have to keep polarity straight. There are lots of guides on the web. This is one of the best I'm aware of.
Painting? Simple 9" paint rollers like you'd use on a smooth interior wall work well. Seriously - a short-nap roller will work great. Before I started spraying, I rolled a LOT of my cabinets, and I still use the roller on the big ones, when I bother to paint them. Exterior latex will work fine, and you don't need the expensive stuff. The tougher coatings are definitely warranted when gigging, but gigging with LilWreckers would take a LARGE truck.
lilmike is offline
Old 02-06-2014, 02:59 PM
thewiz's Avatar
lilmike will the Tempest X2 (15") work? Thoughts?
I have the tempest in a 5.6 cube ported box tuned to 21hz. I have the space and feel like this driver could get a lot more use in a larger box. I want more lows! I'm currently powering it with a 900watt Bash plate amp but would get more power if needed smile.gif.
Fs: 19.5 Hz
Le: 0.95mH
Re: 3.8 Ohms (Voice Coils wired in series)
Qms: 3.82
Qes: .47
Qts: 0.42
Mms: 238g
Cms: 0.28 mm/N
Vas: 255L
Sd: 807 cm^2
BL: 15.3
X-max: 26mm
Pmax: 1000W
SPL: 87.9 db/1W/1M
thewiz is offline
Old 02-06-2014, 05:27 PM
Michael Mitten's Avatar
Quoted: 189 Post(s)
Liked: 164
Fs: 19.5 Hz
Le: 0.95mH
Qms: 3.82
Qes: .47
Qts: 0.42
Mms: 238g
Cms: 0.28 mm/N
Vas: 255L
Sd: 807 cm^2
BL: 15.3
X-max: 26mm
Pmax: 1000W
SPL: 87.9 db/1W/1M
I'd say based on what the other drivers are suggested to use, the specs look to be in the same ballpark so you should be good to go. lilmike may know something I'm not seeing.
Michael Mitten is offline
Old 02-06-2014, 09:47 PM - Thread Starter
lilmike's Avatar
Quoted: 64 Post(s)
Liked: 160
Re the Tempest X2:
I'm familiar with that driver.
A quick run through the model suggests that it doesn't work too well. The motor is just too weak for the driver to perform well in this tapped horn.
The Tempest X2 is a great driver for my F-20, actually.
lilmike is offline
Old 02-07-2014, 07:36 AM
thewiz's Avatar
Re the Tempest X2:
Sweet! thanks mike!
BTW I have 2 Anarchy TH in my bedroom setup, great stuff! Thanks for all your contributions, you're the man!
thewiz is offline
Old 02-07-2014, 08:16 AM
Quoted: 189 Post(s)
Liked: 164
Re the Tempest X2:
To help me learn, is it because the BL is too low?
Old 02-07-2014, 10:32 AM
jpmst3's Avatar
Quoted: 97 Post(s)
Liked: 233
Yes, BL is motor force.
Joe = LFE Addict
jpmst3 is offline
Old 02-07-2014, 11:20 AM - Thread Starter
lilmike's Avatar
Quoted: 64 Post(s)
Liked: 160
For the amount of cone area and the resistance of the voice coil, yes.
There has to be enough motor force per unit of cone area for the driver to perform well in a tapped horn. Certainly, there are other considerations too, like power handling, linear and mechanical excursion limits, cone strength, and driver Q. At a first glance though, I look at BL, voice coil resistance, and cone area.
lilmike is offline
Old 02-07-2014, 12:55 PM
Quoted: 189 Post(s)
Liked: 164
OK thanks! I knew it was a combo of T/S parameters, but wasn't sure the main ones to check out first with tapped horns.
Old 02-08-2014, 06:12 PM
jjjbrim's Avatar
I have gotten to the point in the build where I have cut the speaker hole in the baffle.  I have a couple questions:
*  I am using the Alpine speaker, does the thick rubber stay on the speaker when mounted?
*  Home Depot only had 1 1/2 inch socket head cap screws, I have not constructed the inserts yet so do not know if this is too short, anyone know if I need the 1 3/4 inch version per the instructions?
*  Since there is no nut that will attach to the end of the screws how do they keep from coming loose?
Might be crystal clear once I put the inserts in, just wanted to see if anyone knows off hand.
Joe
jjjbrim is offline
Old 02-08-2014, 07:24 PM - Thread Starter
lilmike's Avatar
Quoted: 64 Post(s)
Liked: 160
The inserts simply provide threads to screw the screws into. The compression of the gasket and the wood will serve to keep the screws tight, but it doesn't hurt to check them from time to time. Since you can just reach in the mouth, it is pretty easy. Make sure the flange side of the insert is in the throat.
I had to use 1 3/4" with the CVX, but it has a pretty chunky frame. The 1 1/2" should be OK. With the Alpine, I think the gasket stays on, maybe one of the guys that has built with them can confirm that.
lilmike is offline
Old 02-08-2014, 08:09 PM
chrapladm's Avatar
Quoted: 823 Post(s)
Liked: 286
I took my gasket off. Although I have never tried using it with the gasket on. SO either may work. I am so used to adding sealant tape that I do it without thinking anymore.
