Lilmike's LilWrecker - Page 18 - AVS Forum | Home Theater Discussions And Reviews
 73Likes
post #511 of 833 Old 03-14-2014, 11:16 AM
philly_03's Avatar
philly_03 is offline
post #512 of 833 Old 03-14-2014, 07:27 PM
philly_03's Avatar
Question: Is it better to wire the sub in 4ohm so that it can take more power?
does it affect anything?
right now the lights are not clipping but getting a stinky smell from the driver.
I am just not sure if I should run MCAAC again?
I turned down the gain for now.
Anybody?
post #513 of 833 Old 03-15-2014, 07:41 AM
chilort's Avatar
Quoted: 16 Post(s)
Liked: 74
I made mine stink but I was running it full out for quite a while. I've made it stink again but only a little bit.
I would double check to make sure you have it wired correctly. With dual 4 ohm voice coils you can only wire it as 8 ohm (two coils in series) or as 2 ohm (two coils in parallel).
If you have the ability to measure the response you might want to do that and post the graph here.
chilort is offline
post #514 of 833 Old 03-15-2014, 08:23 AM
philly_03's Avatar
Thanks for the reply Chilort,
I triple checked wiring and it is driver wired in 8ohm ---> speakon --->Inuke in bridged mode ---> XLR/RCA ---> pioneer SC-65.
Gain knob in front of inuke was turned half way up and then ran MCAAC.
When done turned gain knob another 2-3 clicks (I like it hot biggrin.gif)
As for graphs, I do not have a mic yet and still do not know which one to buy, started reading rew....eek.gif and to be honest I was planning to do all of that this summer.
would it be better to wire it in 2 ohm?
I heard that you can set limiters, couldn't find how though? I do not know if that should be something I should do, Actually knowing myself....yeah that is something I should do tongue.gif
Any idea on the mic?
post #515 of 833 Old 03-15-2014, 10:21 AM
philly_03's Avatar
Update: There is a setting in the configuration remote app for the Inuke to set the OHM wiring of the speaker and that was not set.
Once I set it to 8ohm, it calculates the watts automatically and now I can get the volume all the way to +10 with no smell! cool.gif
I have a feeling a second one in the room might be in the near future.....biggrin.gif
Thanks John!
Now any idea what mic to get?
post #516 of 833 Old 03-15-2014, 11:11 AM
stormwind13's Avatar
Quoted: 62 Post(s)
Liked: 96
Minidsp Umik, if you're okay with waiting for one.
stormwind13 is offline
post #517 of 833 Old 03-15-2014, 08:03 PM
chilort's Avatar
Quoted: 16 Post(s)
Liked: 74
Yes, you need limiters. If you didn't hear any mechanical sounds you likely haven't damaged anything yet.
I am unfamiliar with the amp you are using.
Keeping the sub wired in 8ohms will put less strain on the amp.
chilort is offline
post #518 of 833 Old 03-15-2014, 08:35 PM
philly_03's Avatar
thanks guys!
Limiters set.
I will get that mic since I do not mind waiting.
post #519 of 833 Old 03-15-2014, 09:35 PM
moosifee's Avatar
Quoted: 16 Post(s)
Liked: 52
I got mine from Herb at Cross Spectrum Labs. Took about a week to get here, which gave plenty of time to get REW and read up on it; couldn't be happier.
moosifee is offline
post #520 of 833 Old 03-16-2014, 07:02 PM
chilort's Avatar
Quoted: 16 Post(s)
Liked: 74
I'm also a user of the UMIK, miniDSP, and REW. Expert help from the forum and Mike were greatly appreciated. I still haven't really had time to play with REW as much as I want. But I'm getting ready to build up a set of mains, including crossovers, so I'll be learning more.
chilort is offline
post #521 of 833 Old 04-05-2014, 11:20 PM
jleonard711's Avatar
Quoted: 21 Post(s)
Liked: 29
So has anyone built one of these with an Eminence LAB15 driver yet? I just picked one up for $100 from Amazon and am trying to look for a cabinet to build for it, and this sounds like it might work. I saw a few comments earlier in the thread about the LAB15 being a possibility based on its specs, I was just curious if anyone had actually built one with it yet.
jleonard711 is offline
post #522 of 833 Old 04-20-2014, 05:03 AM
Sigi Baes's Avatar
I'm gonna build this sub, but it's my first one, and I know this isn't an easy first project, still I'm gonna do it.
Is the Behringer A500 with it's 375W RMS & 600W piek in bridged mode (8Ω) capable of driving an Alpine SWS-15D4 with a jumper (8Ω) wich is is 500W RMS & 1500W piek?
I like the amplifier above the INUKE because of it's silent working. It will be used for playing games and music, but I hope it will still have power enough to make my butt shake. xD
I'm now ordering the materials needed so tell me what you think, thanks :D
Sigi Baes is offline
post #523 of 833 Old 04-21-2014, 06:38 AM
Sigi Baes's Avatar
Bump.
post #524 of 833 Old 04-21-2014, 07:11 AM
moosifee's Avatar
Quoted: 16 Post(s)
Liked: 52
While I waited for my iNuke3000DSP to arrive, I ran one channel of an Emotiva UPA-7 (175W @ 4 ohm) to each voice coil of an SI15 D4 in a Lil'Wrecker. Output was substantial, but I can't say it was really in butt-shaking territory.
What will you do for EQ?
moosifee is offline
post #525 of 833 Old 04-21-2014, 10:31 AM
Sigi Baes's Avatar
Well, I'll connect it to an Essence STX II 7.1  with some custom Op-Amps when it comes out :)
So, I'll control it with the sound card. Also my room is like only 7 x 16 so :P don't know what that will give, hope my room doesn't explode...
post #526 of 833 Old 04-28-2014, 06:04 PM
TedO's Avatar
Quoted: 26 Post(s)
Liked: 27
I have a question about the braces. It doesn't seem like adding windows to the braces would make a difference. When you look at a cross section of the horn, a center brace subtracts from volume which you don't get back with the windows. Does this sound right?
TedO is offline
post #527 of 833 Old 05-04-2014, 07:15 AM
TedO's Avatar
Quoted: 26 Post(s)
Liked: 27
I laid out this design in Solidworks and it looks like adding internal corners would help the sound flow better through the horn and strengthen the corners. I also thought the voids in the corners could be filled with expanding foam. Note that the corners do not change the volume of the horn, the are scaled to the smallest opening in the corner, they just eliminate the large dead volume in the corners.
TedO is offline
post #528 of 833 Old 05-04-2014, 05:58 PM
BadmanSound's Avatar
the issue with that is that in many cases, the "dead Volume" can be beneficial, because it adds to the horn volume.
generally you want horn reflectors when you have paralel panels seperated by a straight horn flare that are at least 3 feet apart, as they can cause standing waves in the sub passband.
BadmanSound is offline
post #529 of 833 Old 07-09-2014, 01:50 PM
AnnArborJayhawk's Avatar
Liked: 26
Hey guys, i'm hearing some weird sounds coming from my new lilwrecker. Hoping someone can shed some light on what to look for. This was my first sub build. I think it went alright, but I had one brace loose that I've fixed with a few extra 4" screws. I'm using an alpine SWS-15D2 and a inuke 3000. Feeding a miniDSP from my pioneer receiver. I have the alpine wired in series at 4ohms and am using a single channel of the inuke. I've done a few measurements in REW and the response looks fairly similar to what i've seen posted in this thread. My problem is that there's a noise at any volumes above quiet when playing sinewaves or music. After some googling I think the best way to describe it is a plastic bag noise, it sounds like a plastic bag vibrating. It's really hard to pinpoint where it's coming from but it sure sounds like it's the driver and not the cabinet. Running it at low volumes in open space doesn't produce the sound, but i've been a little hesitant to push it too hard when it's not in an enclosure, not sure if that's hard on the driver or not.
I sure don't think i'm clipping as I've checked the output of my minidsp with a cheap oscilloscope and i don't see any distortion in the sine waves. I've remounted it a few times and no change. I'm using the gasket included with the alpine, i haven't tried the duct seal stuff yet. I can feel air movement on the front side of the driver in the mouth, but it doesn't seem to be coming from the mounting holes. I'm not sure what to expect since this is my first sub.
Does anyone have any ideas what I could look for? Even if they seem overly basic, i don't know what kind of damage to look for on a driver.
AnnArborJayhawk is offline
post #530 of 833 Old 07-09-2014, 01:58 PM
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2697
Cat climbed inside ?? There's another dude on here that happened too... lulz.
Mfusick is offline
post #531 of 833 Old 07-10-2014, 07:24 AM
Liked: 26
Haha no, but i saw his post. It gave me hope for being able to fix my rattling brace.
post #532 of 833 Old 07-10-2014, 11:40 AM - Thread Starter
lilmike's Avatar
Quoted: 70 Post(s)
Liked: 178
It sounds like an air leak to me.
I'm betting that the driver isn't properly sealed to the baffle. Try some duct seal on the gasket and make sure that the screws are snug.
lilmike is offline
post #533 of 833 Old 07-14-2014, 06:36 AM
Liked: 26
Thanks! You were right, got some duct seal on there and it worked like a charm. Should have taken your advice the first time you posted, guess I was just too eager to hear the thing! It sounds awesome, now I just need to find where to put it to flatten out my room response.
post #534 of 833 Old 07-14-2014, 10:45 AM - Thread Starter
lilmike's Avatar
Quoted: 70 Post(s)
Liked: 178
Glad it was an easy fix.
lilmike is offline
post #535 of 833 Old 08-04-2014, 01:35 PM
the_abbot's Avatar
Quoted: 228 Post(s)
Liked: 38
I am about to begin a theater room build, and am pretty sure that I will be using two of these as the foundation of sound.
I am curious though. I am currently using a single eD A7-450. How does the Wrecker compare to a sub like that?
the_abbot is offline
post #536 of 833 Old 08-04-2014, 03:56 PM
chrapladm's Avatar
Quoted: 937 Post(s)
Liked: 350
I do believe the LW will extend down lower with more SPL. If you go to Data-bass you can see your subwoofer tested there. The tests have been published on this subwoofer here.
chrapladm is online now
post #537 of 833 Old 08-04-2014, 04:59 PM - Thread Starter
lilmike's Avatar
Quoted: 70 Post(s)
Liked: 178
A7-450 or A7S-450? In other words, is the cabinet sealed or ported?
That's a pretty hefty 18 in either cabinet, and it comes with a fair bit of amp behind it. The sealed version managed 120 dB in the Data-Bass testing, so I'd expect the ported version to behave similarly, but have additional extension. The tune is down below 20 Hz, but I have not seen an impedance chart for the ported version to know for sure.
Regardless, that is a decent sub you have.
A LilWrecker will keep up with what you have (given a big enough amp and a proper driver). I'd recommend stepping up to a bit more driver than the Alpine if you need the output. The CVX we tested with was running out of gas once we passed 120 dB (but then, so was my amp). A Fi Q 15 (basically stock, no added spider, low Qts, but the cooling/P chamfer options should be OK) should be a decent step up from the CVX, which is a step up from the Alpine, and it fits inside the cabinet as drawn. Unfortunately the Sundown X series doesn't physically fit inside the LilWrecker.
As far as I know, the Fi Q 15 has not been tested in the LilWrecker, but the simulations look fine. I've assisted others with measurements of a Q 15 with an additional spider, parameters were generally as expected (suspension parameters were stiffer, motor was unchanged) suggesting that the Fi numbers are reasonably accurate.
lilmike is offline
post #538 of 833 Old 08-04-2014, 05:20 PM
the_abbot's Avatar
Quoted: 228 Post(s)
Liked: 38
Thanks for the response!
Mine is ported. It has treated me well. I would like to utilize dual subs, but since eD is out of business I will need to get two matching subs elsewhere. Or maybe I should just add a LW to my A7...... using the driver you mentioned. Hmmmmm......
Regardless, I can't wait to begin building a sub to your specs!
post #539 of 833 Old 08-09-2014, 03:17 PM
chilort's Avatar
Quoted: 16 Post(s)
Liked: 74
What would one expect in terms of the gain going from the Alpine to the Fi Q 15? Would a Crown XLS 1000 be enough amp?
chilort is offline
post #540 of 833 Old 08-10-2014, 10:01 PM - Thread Starter
lilmike's Avatar
Quoted: 70 Post(s)
Liked: 178
Nothing at a watt, but the potential is there for a LOT more power handling. The Q is rated at 1500 W, and has 27 mm of xmax.
1500 watts will take it a touch past xmax in this cabinet, but should still be well within xmech. It models a touch over 125 dB at that point.
In a nutshell, you're looking at a gain of about 6 dB, provided you have enough amp to get there and the effects of power compression are similar for both drivers. I'm not sure about distortion profiles, I've not done detailed measurements of either driver. Some day when I have the spare time and spare cash...
The XLS 1000 isn't nearly enough amp, if I was shopping in the XLS section, I'd look at the XLS 2500, bridged, I'd consider the XLS 2000 bridged as an absolute minimum.
lilmike is offline
