Lilmike's LilWrecker - Page 21 - AVS | Home Theater Discussions And Reviews
 8Likes
post #601 of 624 Old 01-05-2015, 09:19 PM
mfagains's Avatar
@lilmike ;
Thanks for your time and effort to design such a great sub. I am looking forward to building one in the spring and rocking the house for real...
I'm currently using an "old school" AudioPro B2-50 dual 6.5" push-pull which I have had for a long time.... it still rocks down to 25 Hz, I just feel like these "new" movies coming out have so much bass information that I am missing...... time to upgrade.
May the Bass be with you.....
mfagains is online now
post #602 of 624 Old 01-24-2015, 05:25 PM
superedge88's Avatar
Quoted: 12 Post(s)
Originally Posted by Stumbo View Post
Despite the cheap price of the drivers, if you add up the cost of drivers and wood, you may have better options....
Are you referring to my question about how many lilwreckers with type S drivers can an Inuke 6000dsp run? I am all ears if there are options out there that can save me time and money. I am currently planning to use 4 lilwreckers. I'll be enclosing these into an attic space, so they have to be perfect for the job.
superedge88 is online now
post #603 of 624 Old 01-24-2015, 05:32 PM
Stumbo's Avatar
Quoted: 48 Post(s)
Liked: 60
Good info in this thread:
http://www.avsforum.com/forum/155-diy-speakers-subs/1861842-lilwrecker-large-ported-dayton-18ho-full-marty.html
Stumbo is online now
post #604 of 624 Old 01-24-2015, 11:27 PM
Quoted: 12 Post(s)
Thanks for the link, I do appreciate it. I am still thinking that 4 lil wreckers will do great, the only thing that I will still entertain is a more powerful driver than the Alpine Type S so that I could have more head room.
post #605 of 624 Old 01-25-2015, 07:16 AM
mfagains's Avatar
@superedge88
The drivers that work with this box are on the FIRST PAGE.....
The Fi Q15 is a more powerful driver.....
post #606 of 624 Old 01-25-2015, 10:42 PM
Quoted: 12 Post(s)
Originally Posted by mfagains View Post
@superedge88
Thank you for the recommendation, I understand that it is a more powerful driver, but it makes me worried when it has been untested... or should I not worry?
post #607 of 624 Old 02-03-2015, 12:53 PM
Quoted: 12 Post(s)
Can the lilwrecker be used in conjunction with the microwrecker? An area of the attic that I need to use for placement of subs is not optimal for placement of two stacked lilwreckers as I had previously planned. I can instead fit 2 or 3 microwreckers. One lilwrecker would be in a completely different area of the room, 2 or 3 microwreckers would be coupled together in the other part of the room. So I could utilize my receiver's dual sub EQ and EQ the microwreckers seperately from the lilwrecker. I figured this shouldn't be an issue since they are both tapped horn subs, but just want to make sure.
post #608 of 624 Old 02-03-2015, 03:04 PM
Stumbo's Avatar
Quoted: 48 Post(s)
Liked: 60
You could do that. How will you be powering/eqing them?
post #609 of 624 Old 02-03-2015, 03:17 PM
Quoted: 12 Post(s)
I'll be using an Inuke 6000DSP to power them and an Onkyo PR-SC5508 receiver with dual sub EQ. Seems like the build cost of the microwrecker and lilwrecker is pretty low. I love my THT, but hate that the access to the woofer is behind a panel that MUST be sealed in order for it to work correctly. I love the idea of being able to access the woofer in these tapped horns from the mouth, makes for snugging down the woofer easy and worry free.
I also love the idea of being able to use a single amplifier since these are high efficiency designs. Since the Inuke can run 8 lilwreckers, I assume that it can run 8 microwreckers with the alpine type S driver?
post #610 of 624 Old 02-03-2015, 04:52 PM
Stumbo's Avatar
Quoted: 48 Post(s)
Liked: 60
Yes 8 alpines to one nu6000.
Building the boxes of the little wrecker is the most expensive part, at least $170 each.
Since the lil wrecker and micro need different HPFs, your mixing and matching won't work well with a nu6000dsp.
post #611 of 624 Old 02-03-2015, 10:08 PM
Quoted: 12 Post(s)
Gotcha, I didn't realize that the inuke didn't have the option to select different filters for different channels. I'm going to do some crawling around in the attic and see what I may be able to squeeze into some spots. I am still holding out hope for 4 lilwreckers if I can fit them in.
post #612 of 624 Old 02-03-2015, 10:54 PM
Stumbo's Avatar
Quoted: 48 Post(s)
Liked: 60
You can, but there are only 2 channels to work with.
post #613 of 624 Old 02-03-2015, 10:59 PM
Quoted: 12 Post(s)
Then it's no problem to run a lilwrecker on one channel and microwreckers on the other channel, or am I missing something? I can use a combination of series and parallel wiring to make sure that the amplifier is seeing the correct resistance on either channel.
post #614 of 624 Old 02-04-2015, 12:14 AM
Stumbo's Avatar
Quoted: 48 Post(s)
Liked: 60
Sure! With 3 sws15d4 You'll get a 6 ohm load which is about 1600 watts from a nu6000, or ~530 watts per infinity. Should be loud!
With 3 sws15d2 you'll have a 12ohm load and ~800 watts, or ~280 watts per box. This will probably be 2 or 3dbs quieter. However, if you decide to add a 4th, you'll have a nice 4ohm load to get the full 2200 watts from the NU6000!
Either the d4 or d2 will need a gain limiter set from the nu6000 on your single lil wrecker.
One option would be to go with the the nu4-6000 and a 2x4 balanced minidsp. This will give you 4 independent channels to work with and a lot more flexibility.
post #615 of 624 Old 02-21-2015, 06:00 PM
cecaa850's Avatar
I just smoked an Alpine driver. Would THIS work? http://www.soundqubed.com/HDS315_p_229.html
120@20@14'
cecaa850 is offline
post #616 of 624 Old 02-22-2015, 10:35 AM - Thread Starter
lilmike's Avatar
Quoted: 20 Post(s)
Liked: 104
Dunno, incomplete specs.
If I assume an Sd of 825, an Re of 8R, and an Le of 8 mH, it actually models pretty well.
I have no idea how close those values are to "reality" though. Without real measured specs, it is a bit of a risk.
1500 W will take it 10 mm past xmax (14 mm one way), but that suspension looks stiff enough to keep the moving parts out of the stationary ones. I have no idea what the xmech is on that driver though.
---EDIT
OK, with "proper" parameters, things don't look nearly as rosy. BL is lower, and as a result, Qes is higher.
Maybe not a deal-breaker on the response prediction, but there's more to a good result than a flattish frequency response. As I've "been there and done that" with respect to using an undermotored driver like this in a tapped horn, I would not recommend it at all. I'd suggest a different driver.
ID:	560593   Click image for larger version
Last edited by lilmike; 02-23-2015 at 01:06 PM. Reason: Embed image, update post and embed second image
lilmike is offline
post #617 of 624 Old 02-23-2015, 12:13 PM
cecaa850's Avatar
These should be actual parameters.
Model: HDS315
* Piston Diameter = 330.2 mm
* f(s)= 35.66 Hz
* R(e)= 7.27 Ohms
* Z(max)= 68.69 Ohms
* Q(ms)= 7.836
* Q(es)= 0.927
* Q(ts)= 0.829
* V(as)= 56.730 liters (2.003 cubic feet)
* L(e)= 8.87 mH
* n(0)= 0.26 %
* SPL= 86.33 1W/1m
* M(ms)= 361.60 grams
* C(ms)= 0.06 mm/N
* BL= 25.20
120@20@14'
cecaa850 is offline
post #618 of 624 Old 02-23-2015, 12:15 PM
Mfusick's Avatar
Quoted: 289 Post(s)
Liked: 1277
http://www.parts-express.com/tc-soun...oofer--293-662
plus with a 10% coupon ^
"Too much is almost enough. Anything in life worth doing is worth overdoing. Moderation is for cowards."
Mfusick is online now
post #619 of 624 Old 02-23-2015, 12:55 PM
cecaa850's Avatar
Thanks but I need the amp to see a final load of 8 Ohms.
120@20@14'
cecaa850 is offline
post #620 of 624 Old 02-23-2015, 01:12 PM
Mfusick's Avatar
Quoted: 289 Post(s)
Liked: 1277
You can't run 4ohm ?
What amp?
BTW that link wasn't specifically for you.
post #621 of 624 Old 02-23-2015, 01:56 PM
cecaa850's Avatar
What amp?
I almost felt special for a moment
120@20@14'
cecaa850 is offline
post #622 of 624 Old 02-23-2015, 02:18 PM
Mfusick's Avatar
Quoted: 289 Post(s)
Liked: 1277
post #623 of 624 Old 02-23-2015, 02:34 PM
cecaa850's Avatar
I feel better now!
120@20@14'
cecaa850 is offline
post #624 of 624 Old Today, 03:00 PM
bryan.lynch's Avatar
Subscribed
bryan.lynch is online now
