Lilmike's LilWrecker - Page 22 - AVS Forum | Home Theater Discussions And Reviews
 72Likes
post #631 of 832 Old 03-20-2015, 03:09 PM
goonstopher's Avatar
Quoted: 311 Post(s)
Liked: 61
I am confused... are the lilwrecker and the microwrecker the same thing?
I can't find the microwrecker anywhere.
Also - Has Mike said why he likes the wrecker over the f20? I thought folded was better then tapped.
goonstopher is offline
post #632 of 832 Old 03-20-2015, 03:30 PM
Mr.Tim's Avatar
Quoted: 279 Post(s)
Liked: 182
Not the same thing. I don't think lilmike started his own thread for the micro. Try here.
Mr.Tim is offline
post #633 of 832 Old 03-20-2015, 08:27 PM
superedge88's Avatar
Quoted: 81 Post(s)
Liked: 40
The Lilwrecker is a folded horn and a tapped horn. The f20 is smaller but doesn't go as low as the Lilwrecker.
superedge88 is offline
post #634 of 832 Old 03-21-2015, 03:28 PM - Thread Starter
lilmike's Avatar
Quoted: 66 Post(s)
Liked: 171
Not as active on the forums as I used to be, sorry. No time for speaker R&D like I used to, and certainly no time to deal with another design/build thread.
The thread that was linked a couple posts up is the only place I've shared/posted the MicroWrecker plans on AVS, it is still very much a work in progress with me, it is just that I haven't done much work on it since I finished the test-build (not because it's that good, mainly because I've been that busy with the rest of life).
Rather than try to find a way to get it properly measured and tested, analyze everything, then re-fold/refine a few things that I'd like to change, then rebuild it and test it some more so I could present the finished product, I figured that I would share the interim plans I have at this point if people wanted to play along at home. The plans in that thread are current as of today. A couple ideas about things I want to do differently, but as yet, I've not changed a thing. When I posted them, I decided that it would be far easier for me to attach a file to a post here rather than distribute them via emails like I had been doing.
The MicroWrecker is much smaller (~20 cu. ft.) than the LilWrecker (~30 cu. ft.), it gives up a bit of extension, but it does get a bit louder. According to my measurements, the Micro's tune came in at 22 Hz. vs the LilWrecker at ~17 Hz. I don't have groundplane SPL measurements for the Micro that I 100% trust yet, the few measurements I do have for the Micro weren't done in ideal settings or conditions.
As far as preferences? Sure, I have mine, they may not be remotely close to anyone else's. This is audio after all, everyone has an opinion, and when it is your room and your speakers, who am I to say a thing if mine is different? For subs in my systems? I've tried a lot of different drivers and alignments over the years. Currently, I prefer the sound of a properly-done tapped horn over the other alignments I've played with, but that's just me, for now. I'm sure that there's someone conjuring up an even better way to make bass, we'll see what they come up with.
There is a technical reason that I prefer tapped horns vs. front-loaded horns when used as subs in a theater though, similar to ported boxes, there's an excursion minima at the tapped horn's tune. The cabinet is handling the heavy lifting at the low corner, not the driver. Nothing's free though, just like ported boxes, they unload below tune. I can deal with that via a highpass.
lilmike is offline
post #635 of 832 Old 03-21-2015, 05:38 PM
Quoted: 311 Post(s)
Liked: 61
Very interesting...
I might need to just go ported for simplicity ha
post #636 of 832 Old 03-23-2015, 06:41 PM - Thread Starter
lilmike's Avatar
Quoted: 66 Post(s)
Liked: 171
Very interesting...
Ports compress unless they're huge, and when they're huge, the build isn't simple.
Mfusick likes this.
lilmike is offline
post #637 of 832 Old 03-23-2015, 07:22 PM
Quoted: 311 Post(s)
Liked: 61
Killing me! ha... not sure what port compression is. Had big subs so maybe I never experienced in recent memory. Before I got bigger subs I nearly killer my HSU VTF-3 though ha
post #638 of 832 Old 03-23-2015, 07:38 PM - Thread Starter
lilmike's Avatar
Quoted: 66 Post(s)
Liked: 171
In a nutshell, the port has to be large enough to function as a port, not just be a leak in the box. It has been my experience that more displacement requires more port area for the same tune.
There's quite a bit of discussion out on the web, as well as plenty here if you look for it. No point cluttering this thread up further.
lilmike is offline
post #639 of 832 Old 03-23-2015, 07:42 PM
Quoted: 311 Post(s)
Liked: 61
Agree
I appreciate hearing a differing opinion.
Ported is the fad right now but horns have a reputation and it's great it hear from someone who has a great understanding of horns.
post #640 of 832 Old 03-23-2015, 07:51 PM
bryan.lynch's Avatar
"You need large ports to move lots of low bass without port noise or compression. With the HO, we went to dual 4" ports, which nearly doubles the port size compared to the VTF-3 Mk 2."
http://www.hsuresearch.com/products/vtf-3-ho-turbo.html
No free lunch
bryan.lynch is offline
post #641 of 832 Old 04-01-2015, 11:52 AM - Thread Starter
lilmike's Avatar
Quoted: 66 Post(s)
Liked: 171
Fi Q 15 added to proven drivers per cecaa850.
If you opt for the Fi, I recommend plain vanilla, no added options.
Mfusick likes this.
lilmike is offline
post #642 of 832 Old 04-01-2015, 07:48 PM
moswald80's Avatar
Liked: 2
[QUOTE=lilmike;33132353]Fi Q 15 added to proven drivers per cecaa850.
cecaa850, I would love to hear your thoughts on the differences between the Alpine and the Fi Q 15. I am seriously considering upgrading to the Fi in my LilWrecker.
Mickey
moswald80 is offline
post #643 of 832 Old 04-01-2015, 09:33 PM
Quoted: 81 Post(s)
Liked: 40
So with this woofer capable of 3 times the Alpine RMS, would that make a little wrecker loaded with the FI Q 15 about 3 times as loud? I'm sure I'm wrong, but I'm wondering how to quantify the upgrade to this new woofer.
post #644 of 832 Old 04-02-2015, 08:55 AM - Thread Starter
lilmike's Avatar
Quoted: 66 Post(s)
Liked: 171
Doesn't quite work that way, because power and SPL have a logarithmic relationship.
Log 1500 - log 500 = 0.47
0.47*10 = 4.7 dB increase
So, tripling the power nets you about 5 dB. It's significant, provided you have enough amp to take advantage of it.
superedge88 likes this.
lilmike is offline
post #645 of 832 Old 04-02-2015, 09:11 AM
Quoted: 81 Post(s)
Liked: 40
Thanks for explaining that.
I think that a good option for me would be to do get 4 of the FI Q 15 dual 1 ohm woofers, wire the coils in series, then wire a pair of lilwreckers in series per channel of the Inuke 6000DSP and call it a day.
post #646 of 832 Old 04-02-2015, 12:58 PM
cecaa850's Avatar
dRwOOD73 likes this.
120@20@14'
cecaa850 is offline
post #647 of 832 Old 04-02-2015, 01:01 PM
cecaa850's Avatar
Above is a picture of a Ficaraudio Q in a Lil Wrecker I built. I started off with the alpine and eventually smoked it (my fault, not the drivers). This is a serious upgrade. The box has more punch and output. If you can swing it, this is the way t go.
120@20@14'
cecaa850 is offline
post #648 of 832 Old 04-02-2015, 01:02 PM
cecaa850's Avatar
Alpine vs Ficar.
120@20@14'
cecaa850 is offline
post #649 of 832 Old 04-02-2015, 01:05 PM
cecaa850's Avatar
This is not a drop in replacement however. Luckily, the bolt pattern is the same but the opening needs to be cut out about 3/16" bigger. I just built a template with my Jasper Jig out of 1/2" plywood, centered the hole, screwed it in place and traced the larger hole with a flush bit and router.
120@20@14'
cecaa850 is offline
post #650 of 832 Old 04-02-2015, 01:10 PM
cecaa850's Avatar
Template installed.
120@20@14'
cecaa850 is offline
post #651 of 832 Old 04-02-2015, 01:11 PM
cecaa850's Avatar
Larger opening traced.
120@20@14'
cecaa850 is offline
post #652 of 832 Old 04-02-2015, 01:15 PM
Did you finish the cabinet with Duratex? If so, how do you like it?
post #653 of 832 Old 04-02-2015, 01:16 PM
cecaa850's Avatar
The Q is currently getting 1200 watts RMS and pretty much laughs at it.
120@20@14'
cecaa850 is offline
post #654 of 832 Old 04-02-2015, 01:17 PM
cecaa850's Avatar
Bryan, I've Duraex a bunch of times and like it This one however is Semi gloss latex.
120@20@14'
cecaa850 is offline
post #655 of 832 Old 04-02-2015, 01:20 PM
cecaa850's Avatar
This is Duratex on a box I built with a pair of old Epik Empire drivers I was given.
120@20@14'
cecaa850 is offline
post #656 of 832 Old 04-02-2015, 01:21 PM
That looks really nice.
post #657 of 832 Old 04-02-2015, 01:28 PM
cecaa850's Avatar
Thanks Bryan. This is Duratex with a little paint spatter. I built this for my son's truck.
120@20@14'
cecaa850 is offline
post #658 of 832 Old 04-02-2015, 01:28 PM
cecaa850's Avatar
Sorry for the thread crap Mike. Back to Lil Wrecker talk.
120@20@14'
cecaa850 is offline
post #659 of 832 Old 04-03-2015, 07:33 PM
chilort's Avatar
Quoted: 16 Post(s)
Liked: 74
I think I've asked this before (went back a few pages so maybe it was an email) but it takes some serious power to drive that Fi Q, right? I couldn't drive the 2ohm load with my XLS 1000 anyway.
chilort is offline
post #660 of 832 Old 04-28-2015, 07:57 AM
Patzig's Avatar
Quoted: 119 Post(s)
Liked: 243
Got my first one done this weekend . Thanks for the awesome design and plans Mike. This think is scary. Got a SI HT15-D2 in it right now. It's crazy, but the horn is easily more powerful than 2 sealed SI 15's. I took some measurements. I trust the line, but REW was being weird. I know I was playing well above 100dB, but it was showing me around 75dB. I used the correction file for the UMIK-1 and I've never adjusted the sensitivity on the mic, dunno what was up. Anyway, the response looks pretty great to me. I ran through audyssey xt32, and I think it helped smooth out the peaks, but I haven't measured in room yet. Sounds great. I've been playing some of the scenes from Interstellar at reference with the sub at around 3-5dB hot...I swear I'm flexing my drywall like 1/2 an inch.
Patzig is offline
