Lilmike's LilWrecker - Page 27 - AVS Forum | Home Theater Discussions And Reviews
 67Likes
post #781 of 798 Old 03-25-2016, 01:19 AM
muzz's Avatar
Quoted: 483 Post(s)
Liked: 239
I can't believe I'm seriously considering building at least 1 of these things, 2 days ago I was convinced I wouldn't be able to get it right, but after reading, discussing with folks, and looking at pics, I'm certain I was wrong about that.
Gonna order a couple Alpines, as the weather is getting warmer, and I'll be able to build out on the deck very soon.
Sent from my XT1575 using Tapatalk
Michael Mitten and mishaux like this.
Why waste $ on more cheap stuff, it's like challenging a dragon with a pocket knife.
muzz is offline
post #782 of 798 Old 03-25-2016, 10:06 AM
mishaux's Avatar
Originally Posted by muzz View Post
I was convinced I wouldn't be able to get it right...
Go for it, its really not that bad!
Unless you have a great table saw, I think the hardest part to get right is the cutting work. If your baffle cuts are wavy or imprecise its hard to get everything together tight and square and strong and airtight.
Lots of millworks, custom cabinetry, lumber yard type places will do custom cut work for amazing prices. There is a millworks shop a few miles from me that sells fancy wood and does custom moulding. They charge maybe $45 an hour to have one of their guys do custom work on their huge cabinet table saw. I think it cost me $30 to give them wood and a cut sheet and get back sub 1/16" precision parts. I dropped the stuff off, grabbed lunch, and came back and picked it up.
mishaux is offline
post #783 of 798 Old 03-25-2016, 10:23 AM
muzz's Avatar
Quoted: 483 Post(s)
Liked: 239
I have a table and chop saw, looks like a circular saw and guide would be good for this.
muzz is offline
post #784 of 798 Old 03-25-2016, 10:48 AM
Mfusick's Avatar
Quoted: 598 Post(s)
Liked: 2543
Mike did you actually post on AVS recently... wow, and I missed it. lol.
"Too much is almost enough. Anything in life worth doing is worth overdoing. Moderation is for cowards."
Mfusick is offline
post #785 of 798 Old 03-27-2016, 06:51 PM - Thread Starter
lilmike's Avatar
Quoted: 53 Post(s)
Liked: 153
Is there any possible way to make this 23-24" tall instead of 25 3/8" @lilmike ?
Sorry to ask, but my 1st will hopefully be a stand for my DIYSG Pures, and they wanna be 23" or so above grade.
Sorry to ask such a question, I'd love to build 1 Without having to tilt my 3 mains.
Thank You
I doubt that the inch is worth the effort. What's your seating distance? You might be a degree off axis, tops. Not worth the hassle IMO. That's the "or-so" in the height spec. If it were my room, I'd worry a lot more about proper toe in.
My concern with the width is compression. If it gets too high, the low corner rounds off, killing output where I want it most. I've built and measured horns like that, didn't bother to share those designs.
lilmike is offline
post #786 of 798 Old 03-27-2016, 06:51 PM - Thread Starter
lilmike's Avatar
Quoted: 53 Post(s)
Liked: 153
LOL...
It has been known to happen on occasion...
lilmike is offline
post #787 of 798 Old 03-27-2016, 06:55 PM
muzz's Avatar
Quoted: 483 Post(s)
Liked: 239
Kinda what I figured, but was hoping to get an answer from the designer himself.
Lil different from ported /sealed, and this will be my 1st horn build.
Appreciate you dropping in to answer that lilmike.
I will build it to spec...
I AM building this biotch!
Ty Sir
muzz is offline
post #788 of 798 Old 03-27-2016, 07:00 PM
muzz's Avatar
Quoted: 483 Post(s)
Liked: 239
Btw, Thanks for the hard work designing, sharing, and answering tons of questions regarding these horns.
Totally different animals.
Gary
muzz is offline
post #789 of 798 Old 04-06-2016, 07:21 PM
mishaux's Avatar
My TARDIS build got picked up by Hackaday tonight!
I made sure there were links back here on my blog, and they picked up a link in the article.
I keep saying this, but thanks again for the designs lilmike!
lilmike likes this.
mishaux is offline
post #790 of 798 Old 04-13-2016, 03:56 PM
muzz's Avatar
Quoted: 483 Post(s)
Liked: 239
Anyone found another/more power handling driver other than the fi(that hasn't been measured), or the ridiculously priced CVX that DEFINITELY works in this box?
While the price of the drivers listed is sweet, I don't wanna do this twice..or 5 times...
muzz is offline
post #791 of 798 Old 04-13-2016, 10:26 PM - Thread Starter
lilmike's Avatar
Quoted: 53 Post(s)
Liked: 153
Wish I had the time and cash to test all the maybes. This isn't my day job, which is why the plans cost what they do.
lilmike is offline
post #792 of 798 Old 04-14-2016, 04:40 AM
muzz's Avatar
Quoted: 483 Post(s)
Liked: 239
Heheh. I hear ya. Thanks
muzz is offline
post #793 of 798 Old 07-25-2016, 02:59 PM
ctmart's Avatar
Hi,
Just wanted to thank LilMike for the Lil'Wrecker design!
THANK YOU!
About the build:
Im using the Alpine SWS-15D4 as the driver.
But, as "bass insanity" is kicking in the more I use it, Im eyeing the Kicker as a future 'upgrade'.
Ive included a few pics of the sub, fwiw.
It's mounted on casters, and if I had to make one recommendation, it would be to add another piece of plywood to the bottom if using casters.
The amount of vibration/air moving about in the mouth of this sub is impressive!
It's for use in our outdoor theater.
The L/R are Yamaha S115's.
The sub is driven by an inuke 3000, the L/R amp is a Yamaha avr with about 100w/channel.
The measurements were done outdoors @ 3' with REW and a UMM-6 mic.
The first scan of the sub is w/o any eq, the second is with several dsp filters to match the target curve.
Again, THANKS Mike!
-Cliff
ID:	1564785   Click image for larger version
ID:	1564793   Click image for larger version
ID:	1564801   Click image for larger version
ID:	1564809   Click image for larger version
mishaux likes this.
ctmart is offline
post #794 of 798 Old 08-13-2016, 09:48 AM
Chris Young's Avatar
Quoted: 27 Post(s)
Liked: 25
Originally Posted by ctmart View Post
Hi,
THANK YOU!
About the build:
Again, THANKS Mike!
-Cliff
Nice job Cliff and thanks for the info on the sub using casters and needing an extra board. When I do build one of these cabinets I plan to use casters so this is good to know.
I was wondering if you added a HPF somewhere below 20hz and if not how is the subwoofer handling it?
Have fun,
Chris
"The Boy has no patience" Yoda
"He will learn patience. Was I any different when you taught me?" Obi-Wan
Work is what we do to pay for our HT.
My attempt living room build The Story Time Theater
Chris Young is offline
post #795 of 798 Old 08-13-2016, 11:53 AM
ctmart's Avatar
Have fun,
Hi Chris,
Im using a set of dsp filters in the iNuke amp to limit response below 20hz.
I used the dsp setup as described in this thread: "how to extend high pass filter below 20hz" as a starting place*.
Then applied filters as advised in the thread "basic REW inuke" *.
I also setup the amp's limiter to 500w (ish) so the iNuke is less likely to 'nuke' the speaker.
The iNuke amp has a very useful set of dsp filters and limiter (and a ridiculously loud fan).
*apologies, forum wont let me post links yet.
-Cliff
ctmart is offline
post #796 of 798 Old Yesterday, 12:54 AM
latexii's Avatar
Would this work with Alpine Type-R SWR-15D4 (or D2) have anyone actually tried ? Cant buy SWS here in Fin, couldnt find 'em on whole EU while searched.. Too freaking expensive to ship from US.
latexii is offline
post #797 of 798 Old Yesterday, 01:17 PM - Thread Starter
lilmike's Avatar
Quoted: 53 Post(s)
Liked: 153
As far as I know, no one has tried the Type Rs.
If the specs I dug up at Alpine are accurate and current, either impedance option for the Alpine Type R 15s should work fine.
The biggest challenge will be to physically fit the drivers into the horn, the Alpine driver is a bit deeper than the Kicker CVX. It should still fit inside, but there's not a lot of room.
lilmike is offline
post #798 of 798 Old Today, 07:13 AM
J_P_A's Avatar
Quoted: 570 Post(s)
Liked: 427
These subs are insane! I ran an Atmos demo clip last night, and there's a thunderstorm clip that made my room feel like it was about to come apart!
The Plains Theater Has Begun
J_P_A is online now
