Lilmike's LilWrecker - Page 28 - AVS Forum | Home Theater Discussions And Reviews
 70Likes
post #811 of 830 Unread 10-21-2016, 12:23 PM - Thread Starter
lilmike's Avatar
Quoted: 64 Post(s)
Liked: 160
Thanks for taking the measurement. I made no effort to level-match or anything, just overlaid them quickly to determine how things matched up.
Not bad. Looks to me like there are some room effects and a lowpass in play, but the peaks and troughs match up pretty well to the predictions.
Hope you enjoy the sub.
Name:	LW SWR 15 comparison plot.JPG
lilmike is offline
post #812 of 830 Unread 10-21-2016, 10:55 PM
Wow just got done reading through the entire thread and I haven't really known about these tapped horns until now. of course I've got the bug and just have to build one for myself. I'm still trying to get a grasp on how loud these things are. I'm thinking of putting one of these in my living room that is open to my kitchen. My living room is quite large at about 9300 cu ft not including the kitchen. Any thoughts on how well this will fill that space? Currently I have one old alpine type R 10" in a sealed inclosure that just doesn't cut it by any means. I just recently bought my house and also just am recently getting more into some halfway decent sounding home theater. I have emptek r55ti towers and of course I wonder if those will not be enough and that I will have to build some better towers to pair with my lilwrecker. Anyways enough rambling, any thoughts one how this would fill the space of my living room? I know some people have multiples of these for half the space that I am trying to fill. I want the full frequency range the tapped horn provides but I don't feel like i need to massage my internals with enough bass to make my kidneys explode. Also is there anyone in Utah that has one that wouldn't mind me taking a listen?
keith1297 is offline
post #813 of 830 Unread 11-09-2016, 08:27 PM
urapnes1's Avatar
Quoted: 44 Post(s)
Liked: 36
Curious to know if anyone here has re-folded this design into something that is roughly half the height and double the length? I am trying to re-fold on my own, but just cannot get it right. Hoping someone else might have a bit more luck that I.
Thanks in advance,
urapnes1 is offline
post #814 of 830 Unread 11-11-2016, 03:15 PM - Thread Starter
lilmike's Avatar
Quoted: 64 Post(s)
Liked: 160
Thanks in advance,
Not really possible to fit all of what I did inside this design in a single folded design.
If you're twice as high and half as deep, there is only room for a single fold, which unless you complicate things, means a single flare rate. This design has 3 or 4 separate flare rates (can't remember, it has been a while).
That said, if you dig a little, the single fold designs are out there. Though Chassmain did the heavy lifting, I helped a bit with this design:
Wanted BIG BASS: Big room open to an even bigger room with lots of windows!
Due to the limitations of sheet stock, he stayed with an 8-foot long cabinet. There are plenty of ways to join stock to make a larger cabinet if you wanted to go that route.
Honestly - it would probably be easier to roll your own design along these lines to fit your space than to try to refold the lilwrecker.
lilmike is offline
post #815 of 830 Unread 11-11-2016, 07:54 PM
urapnes1's Avatar
Quoted: 44 Post(s)
Liked: 36
Thanks LM. I'll keep looking.
urapnes1 is offline
post #816 of 830 Unread 11-11-2016, 08:17 PM
Liked: 0
Whoa long thread. Awesome subs!
johnnyjo is offline
post #817 of 830 Unread 11-21-2016, 12:22 PM
Liked: 1
Is there anywere I can compare output between different elements?
Squeegie is offline
post #818 of 830 Unread 12-03-2016, 12:49 PM
duder1982's Avatar
Quoted: 14 Post(s)
Bumping this for coffee time tomorrow,
duder1982 is online now
post #819 of 830 Unread 01-06-2017, 09:04 AM
Liked: 1
Mike how do you think the new FI Q Neo will perform in there?
http://www.ficaraudio.com/product/q-series-q15neo/
Squeegie is offline
post #820 of 830 Unread 01-09-2017, 03:09 PM - Thread Starter
lilmike's Avatar
Quoted: 64 Post(s)
Liked: 160
Hadn't seen the Neo motored Q. Specs look solid, but still no mention of Le.
lilmike is offline
post #821 of 830 Unread 01-10-2017, 01:24 AM
chrapladm's Avatar
Quoted: 823 Post(s)
Liked: 286
Would be great if this was designed with minimal inductance but this is car audio so I wont hold my breath. Looks nice though.
chrapladm is offline
post #822 of 830 Unread 01-10-2017, 04:10 AM
Liked: 1
Will it fit? Alot deeper then the old one
Squeegie is offline
post #823 of 830 Unread 01-10-2017, 10:08 AM - Thread Starter
lilmike's Avatar
Quoted: 64 Post(s)
Liked: 160
Suppose I should have checked that.
Nope, that driver will not physically fit inside the LilWrecker as I folded it. The mounting depth (minus the frame thickness) is the same as the cabinet dimension. When I add an inch for the frame depth, there's no way.
lilmike is offline
post #824 of 830 Unread 01-16-2017, 01:46 AM
Liked: 9
First post at AVS
First; thanks LilMike for sharing this awesome build, greatly apreciated.
Then my question; i built a Lilwrecker some time ago, and its great, however i sometimes get a "hollow boxy" sound on the low frequences, only from a LFE track, never from frequency sweeps.
I use a Inuke 3000dsp in dual mono (not bridged) and the Alpine SWS15D4 in 8ohms.
The noise get worse with a lower high pass (i use the inuke trick with shelving filters) so with the high pass on estimated 17hz (12db butterworth) i have to play pretty loud to hear the noise, but if i move HP down to 10hz it's pretty bad even on moderate SPL. i would guess around 80-85db, seing your measurements i believe 10hz @ 100db++ should not be a problem?
I have also changed gasket from the original rubber to a neoprene one without any noticable change.
Bear in mind that this is my first sub, and with limited experience i do not know how to find the problem...
Any suggestions?
Roadrune is online now
post #825 of 830 Unread 01-18-2017, 02:35 AM
Liked: 9
Originally Posted by Roadrune View Post
First post at AVS
Bare in mind that this is my first sub, and with limited experience i do not know how to find the problem...
Any suggestions?
Just thinking, could this be the "moving rubber thingy" (no idea what its called in english) toching wood with big excursion? The clearance from the rubber to the cutout in the baffle is aprox 5mm or 1/5"
post #826 of 830 Unread 01-18-2017, 07:21 AM
JohnDean's Avatar
Quoted: 430 Post(s)
Liked: 183
It's tuned to 17hz, so under that point you're reaching the excursion limits of the driver, like a ported design, it's unloading. You want the HPF at 17ish hz to protect the driver
JohnDean is online now
post #827 of 830 Unread 01-18-2017, 08:22 AM
Liked: 9
Ok, thanks.
How steap HPF will be required? Is 6db Bw sufficient?
post #828 of 830 Unread 01-29-2017, 05:04 AM
Liked: 0
I am looking in building two pico's, but I live in Europe. Apparently, the Alpine SWS 10D2 isn't distributed here, so I would need to get it from US. Including import duties, shipping etc. price is about 230 euro to get 2 here.
The SWR 10D2 is however better available and is currently on sale in the UK, so I can get 2 for 270 euro.
I compared specs and it seems like the SWR is just a better version of the SWS.
differences (SWR/SWS)
sensitivity 82/85 (here the SWS is better I guess because it has less mass)
freq response 26-200 / 28 - 200 (win for SWR)
RMS power 300-1000 / 150 - 500 (win for SWR)
Peak 3000 / 1500
VAS 18 / 25 (here i'm worried, as the box is calculated on this)
Fs 31 / 35 (less chance to break the SWR I guess)
Qts 0,51 / 0,49 (not clear, small diff?)
Xmax 20 / 15 (win for SWR on durability)
belgiansound is offline
post #829 of 830 Unread 01-29-2017, 05:13 AM
Liked: 9
The Lilwrecker will require a 15" woofer like sws-15.
I am quite shure it have been mensioned earlier in the thread that the swr is not suited for this build
7.1.4
DIY ER18MTM, DIY custom Overnight Sensation, DIY LilWrecker DIY Hypex poweramps, Denon AVR X6200W, Cambridge Audio Azur 751BD
http://www.avsforum.com/forum/155-di...und-atmos.html
post #830 of 830 Unread 01-29-2017, 05:15 AM
Liked: 0
I see i'm actually mistaken and should have posted in the picowrecker topic... but I guess the same applies there, will get my question there, apologies!
