Lilmike's LilWrecker - Page 3 - AVS Forum | Home Theater Discussions And Reviews
 72Likes
post #61 of 832 Old 02-14-2013, 01:13 AM
Stumbo's Avatar
Quoted: 55 Post(s)
Liked: 88
Just ordered a pair of CVX-15s
I just built my F-20 a month ago.
Wtf am I doing.
Oppo 103D
Samsung pn64f8500
Pioneer vsx-82txs
And a bunch of DIY speakers and subs.
Coming soon: Dirac Room Correction
Stumbo is offline
post #62 of 832 Old 02-14-2013, 04:37 AM
blackoper's Avatar
Quoted: 18 Post(s)
Wtf am I doing.
You were obviously practicing your building skills with the F20s and plan to pass them down as a birthday/Christmas present to someone in your family (that's what I do with my old stuff)
blackoper is offline
post #63 of 832 Old 02-14-2013, 08:13 AM
dRwOOD73's Avatar
Wtf am I doing.
dRwOOD73 is offline
post #64 of 832 Old 02-14-2013, 09:31 AM
radman12's Avatar
Liked: 27
its called, the sickness
radman12 is offline
post #65 of 832 Old 02-14-2013, 09:44 AM
jpmst3's Avatar
Quoted: 97 Post(s)
Liked: 233
I'm down with the sickness!
Joe = LFE Addict
Joe's LOWARHORN build
jpmst3 is offline
post #66 of 832 Old 02-14-2013, 09:51 AM - Thread Starter
lilmike's Avatar
Quoted: 66 Post(s)
Liked: 171
Yup....it most certainly is.
And once you've been bitten, there is pretty much no hope.
Oh man, I can't wait for my theater to be done...and I haven't quite got the remodel started yet.....
I've been craving "proper" bass since we uncorked radman12's lilwreckers the first time.
The sub I'm currently listening to isn't bad at all - I just leave about 4 Hz of extension on the table in comparison, definitely an improvement over the T-6s.
lilmike is offline
post #67 of 832 Old 02-14-2013, 09:53 AM
pgwalsh's Avatar
Quoted: 431 Post(s)
Liked: 303
You've got a fever and the only cure is more cowbell.....er bass..
Diy Sound Group - Information & Tips
Builds: Maelstrom 21 Ottoman Build, Dual Opposed MFW's x 2, Statements, SEOS-12/TD12M x 5.
pgwalsh is offline
post #68 of 832 Old 02-14-2013, 10:02 AM
louisdamani's Avatar
Lilmike what is the MicroWrecker?
louisdamani is offline
post #69 of 832 Old 02-14-2013, 10:29 AM - Thread Starter
lilmike's Avatar
Quoted: 66 Post(s)
Liked: 171
The MicroWrecker?
The littler brother of the LilWrecker. Guess I can let that kitteh out of the bag too...
It is a 20 cubic foot tapped horn that is tuned a little higher and gets a little louder.
Cabinet is approximately 4' by 2' by 2.5', I loaded mine with a CVX-15, cause that's what I have.
It's real, I've built the proof of concept/test mule, and am currently listening to it.
No accurate measurements that I 100% trust yet, but my preliminary ones suggest that the response is very similar to Ricci's Gjallerhorn,
though I'm leaving the top 6 dBs on the table cause the CVX-15 is a pea-shooter when compared to the LMS-Ultra...
Based on the issues I encountered with my first build, I have changed the design a bit.
I have wood ready to cut for the second, which is the build I'll document.
lilmike is offline
post #70 of 832 Old 02-14-2013, 10:50 AM
jpmst3's Avatar
Quoted: 97 Post(s)
Liked: 233
Awesome!
Joe = LFE Addict
jpmst3 is offline
post #71 of 832 Old 02-14-2013, 11:37 AM - Thread Starter
lilmike's Avatar
Quoted: 66 Post(s)
Liked: 171
Yes, there will be another thread soon.
The MicroWrecker will be fully documented in a separate thread once I am done with my second build (hope to make some dust this weekend, we'll see).
While it works OK, the cabinetry on the first build is not pretty...and paint alone won't fix it.
My proof of concept builds are put together as inexpensively as possible, using what I have on hand. There are three types of plywood in that cabinet...
lilmike is offline
post #72 of 832 Old 02-14-2013, 12:01 PM
Hey lilmike do you have a chart with an overlay of the MicroWrecker, LilWrecker and the F-20?
post #73 of 832 Old 02-14-2013, 01:44 PM - Thread Starter
lilmike's Avatar
Quoted: 66 Post(s)
Liked: 171
Sadly, no, and I am not sure that I will be able to.
I have data that I trust for the LilWrecker.
I don't have measurements of the Micro that I trust yet, but I will be able to get those soon, it just needs to warm up and stay dry.
Unfortunately, the original measurements of my F-20 may have died with my old laptop drive (at least I can't seem to find them on my server). I am still looking though.
lilmike is offline
post #74 of 832 Old 02-14-2013, 02:26 PM
WVSyd's Avatar
Liked: 42
Hey Mike - Do you have an estimated date for the aforementioned thread?
"Beware of Salesmen: They are the modern Svengali, immune to Science and Reality"
WVSyd is offline
post #75 of 832 Old 02-14-2013, 02:50 PM
WVSyd's Avatar
Liked: 42
I use Photoshop and make each jpeg a layer - then I can use Opacity to fade & Blend Modes. As long as the size and scale are the same it easy. Otherwise things may have to be rescaled.
Don't know if this is appropriate to this situation, but it's has helped me do comparison.
WVSyd is offline
post #76 of 832 Old 02-14-2013, 02:59 PM - Thread Starter
lilmike's Avatar
Quoted: 66 Post(s)
Liked: 171
Well, I'd like to get the second one built so that I can verify that I've addressed the "buildability" issues I encountered with the first cabinet.
I also need to update the cutlists, finish up my plans and drawings, as well as include all the the bracing I used on the drawings.
Not sure when I will get all of this done, but I hope to at least get things started this weekend.
Though I had grand plans, last weekend was pretty much a bust for me as far as shop time goes, hope that this one works out a bit better.
lilmike is offline
post #77 of 832 Old 02-14-2013, 04:10 PM
jpmst3's Avatar
Quoted: 97 Post(s)
Liked: 233
Looking forward to all things Microwrecker!
Keep us posted!
Joe = LFE Addict
jpmst3 is offline
post #78 of 832 Old 02-14-2013, 11:07 PM
jonathanc's Avatar
Liked: 48
Is it just me or does every single lilmike project thread start with a build and pictures of one project, and then part way through always ends up being a QnA session on a new design in the works. biggrin.gif
F20 thread leads to HouseWrecker
HouseWrecker thread leads to LiLWrecker
LiLWrecker thread makes it a whole 1.5 pages before the MicroWrecker discussion starts.
The MicroWrecker thread will end up the Inter-dimensional quantum tunneling Horn Wrecker the size of a Bose cube yet has the power of infinite amps driving infinite 1" drivers through infinite inter-dimensional horns. It will be flat to -10hz and when playing THX's deep note will send the space shuttle to Mars.
I think I've been stuck in work camp for too many days.
skipford likes this.
jonathanc is offline
post #79 of 832 Old 02-14-2013, 11:13 PM - Thread Starter
lilmike's Avatar
Quoted: 66 Post(s)
Liked: 171
Hey - they asked me....
Honest....
By the way - the Alpine Type S 15 looks decent in the LilWrecker. Runs out of linear excursion at the same time it runs out of RMS power handling.
Not sure on the mounting arrangement though - I have not actually looked at the driver in person yet, but face-mounting it may be a challenge. There are options though.
lilmike is offline
post #80 of 832 Old 02-15-2013, 12:26 PM
jpmst3's Avatar
Quoted: 97 Post(s)
Liked: 233
It is certainly affordable and attractive if it is indeed a viable drop in substitute.
It's easy on the eyes too.
Joe = LFE Addict
jpmst3 is offline
post #81 of 832 Old 02-15-2013, 12:37 PM - Thread Starter
lilmike's Avatar
Quoted: 66 Post(s)
Liked: 171
Not all a bad choice. I have actual measured specs from a friend, they are quite close to the published ones.
Alpine in black, CVX in gray, both at a watt.
Sure, the Alpine runs out of linear throw a touch sooner, but the limit happens to correspond to the 4-ohm power output of an EP2500/4000 or similar amp...and that limit gets you precariously close to the 120 dB at 20 Hz 1M groundplane club. With something like 32 mm of one-way mechanical clearance, clanking the driver should not happen under normal use with a 15 Hz highpass in place.
I'd definitely run em if I had em, and for the money (assuming mounting is a non-issue) I'd recommend them over the CVX currently, cause I can get two shipped for about the cost of a single CVX.
lilmike is offline
post #82 of 832 Old 02-15-2013, 12:41 PM
jpmst3's Avatar
Quoted: 97 Post(s)
Liked: 233
Wow, that it is impressive. Great curve and you can't argue with the price!
Looks like ~$130 on ebay, including shipping!
Joe = LFE Addict
jpmst3 is offline
post #83 of 832 Old 02-15-2013, 02:28 PM
zora's Avatar
Quoted: 51 Post(s)
Liked: 55
It is good to see an "inexpensive" driver like the Type S work in this enclosure. I wonder if my spare AV15's would drop into these boxes confused.gif ?
zora is offline
post #84 of 832 Old 02-15-2013, 05:21 PM
Stumbo's Avatar
Quoted: 55 Post(s)
Liked: 88
I received the wrong drivers, D2 instead of D4, however, it sounds like I may be better off with the alpines.
It seems like the lilwrecker may end up costing almost the same as an F20.
Oppo 103D
Samsung pn64f8500
Pioneer vsx-82txs
Stumbo is offline
post #85 of 832 Old 02-15-2013, 07:45 PM
bdubs1's Avatar
I just finished 2 F-20's 5 days ago. They are great but I am starting on 2 Lilwreckers tomorrow. Ya, ya, I got it bad.
Will the dual 4 ohm Alpine Work? I would like to run 2 ohm stereo or 4 ohm bridged.
Any other drivers to consider? I would like to order drivers by Monday.
bdubs1 is offline
post #86 of 832 Old 02-15-2013, 09:46 PM - Thread Starter
lilmike's Avatar
Quoted: 66 Post(s)
Liked: 171
No worries, the D2 works fine. Same SPL where it matters, differences less than 2 dB otherwise.
I chose D4 since there were only going to be two cabinets and radman12 started with one amp, but was considering adding another.
With one amp, you can wire it 2 ohm and feed a pair in series with an EP4000 bridged, with two amps, you can wire it 8 ohm and bridge an EP4000 per cabinet.
lilmike is offline
post #87 of 832 Old 02-15-2013, 09:51 PM - Thread Starter
lilmike's Avatar
Quoted: 66 Post(s)
Liked: 171
According to the published specs, yes, Alpine's SWS-15D4 should work fine.
I am still not 100% sure on the driver mounting, but I have alternate ideas should they prove to be difficult to face mount.
lilmike is offline
post #88 of 832 Old 02-15-2013, 09:56 PM - Thread Starter
lilmike's Avatar
Quoted: 66 Post(s)
Liked: 171
AV15H's? My data says it should work fine. Got specs?
lilmike is offline
post #89 of 832 Old 02-16-2013, 05:07 AM
chrapladm's Avatar
Quoted: 876 Post(s)
Liked: 315
AV15H-D4
FS: 22Hz
Qms: 4.86
Vas: 197L
Cms: .22mm/N
Mms: 235g
Rms: 6.7
Xmax: 23mm
Xmech: 32mm
Sd: 794sqcm
Vd p-p: 3.67L
Qes: .29
Re: 5.4ohm
Le: .56mH
Z: 8ohm
Bl: 24.75Tm
Pe: 1000W
Qts: .27
1WSPL: 90.7db
2.83V: 92.29dB
Here ya go
chrapladm is offline
post #90 of 832 Old 02-16-2013, 05:30 AM
bdubs1's Avatar
From looking at the pictures, it doesn't look like it would be an issue. Might have flip the rubber gasket around or take it off and use gasket tape.
bdubs1 is offline
